installing a 2nd gpu using a pci extension cable?
554 (1.20/day)
so using davinci resolve studio it allows you to configure 1 gpu to do only the gui and 1 gpu to do only the computing and Id like to try this. 1 1070 for gui and 1 3090 for compute
the board is a b500m which means, a 3090 will sit over the 2nd pci slot, but using a pci cable I could get the pci slot extended down and then install the card to that. maybe rivet the cable to the back panel of the case and then use the support bracket? 1070 doesnt weigh much but maybe theres a better way then ghetto modding
case is mid tower so it should have the room to move that 1070 gpu (in the picture) down mounted to the extension cable
whats your opinion?
370 (2.82/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
What he said.
Going to gimp your 3090 on pci-e lanes too.
636 (1.76/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
The slot is only pinned out x4 but should be fine as long as it's working in g4.
I have limited understanding of the 3090 VRMs and avoid entirely but this is a perfectly fine compute.
554 (1.20/day)
I have a hard time believing the GUI is a heavy enough burden to have a dedicated GPU for it.
cheap to try though. its only a cheap extension cable. and it makes a difference in tests I have seen and what editors say.
they also support multi gpu. there must be a reason why they have these options
ir_cow
4,581 (0.77/day)
USA
What exactly does it improve? I haven't found anything to support these claims. Unless you are simply talking about CPU preview rendering vs GPU. In which case you still don't need a 2nd card just for that.
In fact probably the opposite card is required for 8K Full resolution. I know Adobe Premiere struggled with a Titan Xp card at 6K RED footage just a few years ago. I would assume whatever is not supported by the GTX 1070 will be offloaded to the CPU if you assign the RTX 3090 just to encoding.
554 (1.20/day)
I cant find the video from the channel "johns films. export out times was faster and why wouldnt you want to use the feature if you could for a few bucks? I dont think ill ever do 8k. im not using premiere.
Toothless
Tech, Games, and TPU!
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Puget systems did a benchmark of this with multi GPU and it's not worth it. You're better off with a single stronger card.
I happen to also know this because my wife uses this program and I did some research just to find out it's not worth it.
ir_cow
4,581 (0.77/day)
USA
Well, do what you want. Since you said its free. Install the 2nd card and if you get no performance gains or decreases, you can take it back out
554 (1.20/day)
show me a link with multi gpu.
im thinking of this
ir_cow
4,581 (0.77/day)
USA
Unless you have 2 RTX 4090s to spare, for 18% extra, there is no point. That is best outcome too.
Toothless
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Whole lotta' extra power for whole lotta' not extra gain.
554 (1.20/day)
well investment is minimal to try. just the pcie cable thats cheap. nothing in the bench says anything about 1gpu for gui/1 for compute. and when doing NR and some fusion work, thats heavy on gpu. why wouldnt I want to get any performance I can.
28% is not little. people here spend tons yearly for 10% gain
ir_cow
4,581 (0.77/day)
USA
18% for $5,000 is very little for the return. At that point I would rethink my entire setup.
1,493 (3.66/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
How are you going to run a 16x card in a 4x slot? I do not think this is possible.
You can run 1x and 4x in a 16x slot however, but I don't think it works the other way around.
Am interested and watching.
Do it.
ir_cow
4,581 (0.77/day)
USA
what is 18% /$5000 youre talking about? 4090 cards?
Look at the puget scaling. 1x vs 3 RTX 4090s. Extra $5000 assuming 2k each+tax. Considering only 18% gains for that much is silly. The extra card benefit goes down with lower end cards, so expect zero gains from 3090+1070. Might actually hurt perf because stuff is offloaded to the wrong card.
Like I said before since it's a free card and you have everything you need. Try it out. Best case, you don't see a difference.
Toothless
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Also got a look at how strong the 1070 is. You'll maybe see 5% performance bump if you scale the differences.
de.das.dude
Pro Indian Modder
9,130 (1.72/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
if it aint broke dont fix break it
7,068 (4.83/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Keyboard IBM Model M type 1391405 (distribución española)
You'd probably have a better time in Resolve selling both and buying an Ada card with dual NVENC (4070 Ti SUPER or higher). Though, stick to the 3090 for now and plan ahead for an RTX 5090 upgrade.
554 (1.20/day)
I wrote it before. I ALWAYS buy older gen top gear. waiting for 5950x to come in. waiting to find a gpu for the prices I have set im willing to pay and im strict and patient. 2080ti/3080ti/3090. no 40 series. they are crazy thieving prices. ill move to 50 series just before 70 are about to be released. this way I never pay the beta premium prices. look at the 5950x. that sold for $800!! got it now for $320. its still a killer cpu.
if you got a ferrari from 10 years back, doesnt mean its now crep. theres always better, but the problem is people compare newer to older. I only compare the gear with what I want it to do. I never chase new. I dont conform and I dont follow. I do the opposite of what mainstream does. I feel its always a ripoff to buy newest.
in this video they test a few cpu and a few gpu which shows the 3090 is still no slouch
even 2080ti (11gb) or 3080ti 12gb will be fine but may run out of vram for multi cam/heavy effect/fusion/grading/NR. shame they didnt make a 14gb 3080ti.
Toothless
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
You mean to say NVIDIA has cornered the production market with CUDA and keeps gimping VRAM on all but their top end cards? What a concept! /s
7,068 (4.83/day)
São Paulo, Brazil
Well, used 4090's (which have about a month left as the current generation flagship) have stratospheric pricing right now, and I don't expect this to change outright once the 5090 lands (will likely have patchy availability). Guess you've got it as good as you can if you're imposing yourself that limitation.
Disagree with the Ferrari analogy, though. Such a sports car will more than likely increase in price, as its scarcity and exclusivity only increased, but an old graphics card is just obsolete technology.
