Installing Classic Zalman Flower cooler to a modern system
4 (4.00/day)
Processor Intel Core i7 12700K
Memory Corsair Vengeance RGB DDR4-3200 C16
Video Card(s) Yeston Geforce RTX 4060 Cute Pet MA
Storage Samsung 990 PRO
Display(s) LG 38GL950G-B + 2x Gigabyte G27Q
Case Be Quiet! Pure Base 500
Power Supply Superflower LEADEX III Gold 650W
Mouse G502X Lightspeed
Keyboard Realforce R3
Hey Guys
Recently I managed to get a hold of a 15 year old Zalman CNPS 9900 LED CPU Cooler that I thought was so cool (and still do to this day) and am going to try install it to my PC
Why I think its cool:
-Its full copper! (nobody does this anymore)
-it has a really unique looping heatpipe design that looks really clean from above and is quite the manufacturing marvel
-the clear fan with blue LEDs make it look like some futuristic reactor when its running
-Zalman had smaller coolers which got nicknamed 'Flower' coolers, this one being their largest cooler of that time was dubbed the 'Super Flower'
Back when the cooler was new it supported Intel LGA775, 1366 and AMD 754, 939, 940, AM2/+ Sockets. Obviously these are ancient and I can't use those to mount it to my LGA 1700 PC (plus I didn't actually get any mounting hardware with the cooler anyway)
So after doing a little napkin math, my ultimate plan is to do some modifications so that it can work with Noctua's Secufirm 2+ system which should give it a long lasting life for future upgrades.
The kit in question is the Noctua NM-M1-MP78 which contains the most critical part - the NM-SFB4 78mm pitch bracket that's usually only provided with Noctua's coolers but is included by itself in this kit.
My system specs:
System Specs:
Gigabyte Z690 AORUS Elite AX DDR4
Corsair Vengeance 32GB DDR4-3200 C16
Yeston RTX 4060 Cute Pet MA
Superflower LEADEX III Gold 650w PSU
Samsung SSDs (990P + 980P + 2x970E)
Thermalright AXP-90 x53 (The subject being replaced)
Here's the cooler:
Teardown of the cooler
A pic of my system that this cooler is going into :)
Noctua kit is on its way so wish me luck!
13,694 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
I have a feeling that cooler would work better if the motherboard was horizontal.
4 (4.00/day)
Oh and here's my plan for how to modify Secufirm 2+ to make it work
The bottom of the Zalman cooler has a removable plate that's a part of their own mounting system, from my research this is a standard component used by Zalman across the entire range of CNPS and FX coolers excluding the low profile ones.
There are two versions of this plate, both have similar same shape but differ in hole positioning for the intended fan mounting bracket.
Version 1 (The one I have) appears to be older and is used for the CNPS 9900 LED, 9700 and 9500. There are fan bracket holes for fans mounted towards one side of the heatsink like the 9700 and 9500. On the 9900 LED, these holes are left unused as the fan is mounted via a piece of plastic through one of the 'donut holes' on the heatsink
Version 2 is newer and has holes for both side and center fans and is used on later revisions of old coolers and newer coolers such as the CNPS 9900A and CNPS 9900 MAX
The thickness of the nub on Version 2 appears to be thicker so whatever I do here may not translate directly to newer coolers but imo Version 2 is better as the fan is mounted with a steel bracket to the cooler base rather than the heatsink itself which may help reduce vibrations and noise.
So back to the plan, I found that the top of the Zalman has a 'nub' (~10mm Diameter) and the center of the Noctua NM-SFB4 bracket has a hole (~4mm Diameter)
If I drill out the Noctua plate I can get it to fit through the nub and it will act as a lateral hold of the heatsink which should make a solid mount. (it wont stop the heatsink from rotating but I don't expect this to be much of an issue)
I even made a very low quality NM-SFB4 myself! out of paper!
This should work pretty well so the only other factor is thickness to ensure there's enough contact force
I did a few measurements of the Zalman cooler and references a scale image of a Noctua U9S which uses the NM-SFB4 bracket to measure the differences in thickness if any.
It turns out that there's roughly a 2mm difference in thickness from where the NM-SFB4 will make contact with the cooler down to the surface of the cold plate.
The Zalman is thinner which means there's not going to be any issues mounting it, however potentially it is possible to over-tighten the mount (of noctua's spec)
I could fix this by putting a washer around the nub or sticking some kind of foam/silicon sticker under the bracket to add some space and also help stop the cooler from rotating.
Its great its this close though, I expect Noctua's sprung loaded screws will deal with the ~2mm margin and it will work perfectly.
yeah I think so too, the weird shape would passively radiate more heat horizontally I reckon.
5,568 (4.22/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
Interesting. I would worry about overtightening, though, especially the tension that might place on your motherboard. Less might as well be more, be very careful here. I have a suspicion that I damaged my MSI Z690 Ace by doing the same thing, an unofficial, aftermarket cooling mount that caused its PCB to warp a little. At the time I was so excited about my build that I didn't even notice...
Oh btw, that GPU is adorable. Did you make that shroud?
4 (4.00/day)
Yeah I will definitely be careful of the mounting pressure, Ideally I can fill in that 2mm difference and it should be the same pressure as Noctua's spec.
haha no, it would be incredibly talented if I did.
Its a Yeston GPU, part of their Cute Pet series.
224 (0.14/day)
Filthydelphia, USA
System Name Regular PC | Server HP Z440
Processor 9700k | E5-2698v3
Motherboard Gigabyte Z390 Gaming X-CF | Stock mobo
Cooling Scythe Mugen 5 rev. B | Stock HS
Memory 32 GB (8x4) | 112 GB (8x2 + 16x6)
Video Card(s) RTX 2070 Super | K4000
Storage 970 EVO+ 1TB | 860 1TB x2
Display(s) XV340CK x2, 1080p x2
Power Supply Corsair RM750x | Corsair RM750e
Software Pop!_OS | Proxmox
1,544 (1.09/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
I've always liked the Zalman Flower HSF design. Still running its GPU variant, the VF900Cu, in my WinXP retro rig.
I wonder how many watts this old beast will manage to cool. With realistic loads, the 12700K can consume around 200 W (power limits removed, as per TPU's testing).
1,688 (6.67/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Case Fractal Design Torrent
Mouse Razer Viper (Original)
Software Windows 11 Pro (23H2)
Oh, I remember those coolers, they were quite decent at the time when they were actively around. Not outstanding, but decent. I am incredibly curious how it would hold up on a modern CPU considering the higher thermal density (even on Intel chips) and boosting algorithms. I assume you plan on gradually lowering the target TDP in BIOS once installed until the cooler can hold its own and not throttle?
4 (4.00/day)
I wonder how many watts this old beast will manage to cool. The 12700K can consume around 200 W with power limits removed, as per TPU's testing.
The newer version of this cooler (that had a larger fan) advertised a qMax of 300w, whatever that means haha
same, I can't wait to test it. I reckon it will handle stock TDP. It's quite large, about the same size as a dual 120mm tower cooler and being full copper has a fair amount more thermal mass than those.
1,688 (6.67/day)
Depends on what "stock TDP" is, with the MoBo settings and all. But, ehhh.... size ain't everything (yeah-yeah), the design of the HS itself is... well, there is a reason why they went outta fashion and copper is not the advantage you'd think. But yeah, would be interesting to see.
Ruru
S.T.A.R.S.
11,778 (2.77/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X Alphacooled
Motherboard Gigabyte B550M Aorus Elite
Cooling Custom loop
Memory 48GB Kingston DDR4-3200C16
Video Card(s) Asus GeForce RTX 3080 TUF OC 10GB EKWB
Storage ~3TB SSDs + 6TB external HDDs
Audio Device(s) Asus TUF H3 Wireless
VR HMD Oculus Rift CV1
Software Windows 11 Pro UK English
Even though there has been numerous better designs during the years, I also see the charm of these older high-end air coolers.
I have a VF700Cu on my 6800 Ultra AGP. :)
268 (0.56/day)
System Name Can it run Warhammer 3?
Processor 7800X3D @ 5Ghz
Cooling Enermax Liqmax III 360mm
Memory Teamgroup DDR5 CL30 6000Mhz 32GB
Video Card(s) Gigabyte 4090
Storage Silicon Power XS70, Corsair T700
Display(s) BenQ EX2710Q, BenQEX270M
Case NZXT H7 Flow
Audio Device(s) AudioTechnica M50xBT
Power Supply SuperFlower Leadex III 850W
Definitely post a picture once it's installed @WonderSnail. Zalman flower cooler + yeston GPU = cute rare build.
5,568 (4.22/day)
São Paulo, Brazil
Yup, make sure to double check it :)
Sweet! That one flew under my radar completely. I love the white and blue aesthetic. My wishlist is a ROG Strix 5080/5090 with a Genshin or Star Rail collab... I admit I would get into debt for that :oops:
