Intake fans positioning
39 (0.04/day)
System Name Stupid First Build
Processor Ryzen 7 3700x
Motherboard ASUS B550M TUF
Cooling Nox Hummer H224-ARGB CPU, Scythe Kaze Flex 140mm RGB Round (2x Exaust Top) Lancool III Stock Fans
Memory Crucial Flare X 16gb DDR4 (8x2 3200mhz CL14)
Video Card(s) PALIT RTX 3060TI DUAL
Storage ADATA SX8200PNP 512gb,ST1000DM010 1TB and CT1000MX500SSD1 1TB
Display(s) LG ULTRAGEAR 23.8 1920x1080 144hz IPS
Case Lian Li Lancool III
Audio Device(s) KZ ZSN PRO X
Power Supply Superflower Leadex III 850W GOLD
Mouse Logitech G502 HERO
Keyboard Redragon Mitra K551RGB
I have the case from the attached image , Redragon Whelljack it can fit three 120mm fans or two 140mm fans on the front panel (my case) they can be mounted inside or outside considering the glass panel and mesh filter what position would be better ? (Currently getting 74c at 1950mhz@950mv 8000mhz VRAM at my 3060ti under full load and 75c PBO@1.334v full load on my 3700x)
AMF
674 (0.52/day)
USA
System Name MR T System price 2280$
Processor Ryzen 9 3900x 325 $4.7Ghz boost pbo +50 +50 enhance - offset auto voltage -.1875 offset soc
Motherboard ROG STRIX X570-E Gaming 125 $ open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.395v 16-19-16-20-38-58-1T $96
Video Card(s) Asrock RX 6950XT Oc formula Oc edition 705$ 2700 2800 boost 1090v 2376mhz mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie16x4
Display(s) V505-J09 Vizio 4k HDR 299$ oc 5hz
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) TV junk ewww
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Logitech ERGO Trackball 35$
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 pro modded by me no ai no remote connections free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
inside mount as air intake closer to gpu the better 3x 120mm
41,963 (6.61/day)
ATX, front and bottom are intake, aft and top are exhaust. 140MM fans can run a little quieter than 120 mm while moving the same amount or more air.
3,094 (2.49/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
Naturally RGB 120mm intake fans should be outside mounted for aesthetics.
For performance, inside mounted 120mm intake fans will generate less turbulence since the air from the fan encounters fewer obstacles.
825 (0.45/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
So the front is a glass panel? I would install them inside to avoid the fans being too close to the glass and obstruct airflow
768 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
@joemama the front is of a mesh screen like type, by the looks of it.
39 (0.04/day)
39 (0.04/day)
izy
1,012 (1.17/day)
I currently have them installed like the picture, wondered if moving them inside would improve thermals.
Well i guess the best way to find out is just to move them inside and see.
39 (0.04/day)
Reporting back GPU Temperatures with the change Superposition 1080p Extreme 1950mhz@950mv 8000mhz RAM at 74c (peak) (no changes) Cinebench R23 12441cb PBO@1.334v at 70c(peak) (5 c drop).
I got a clearance of about 5 centimeters from the intake fans to the gpu. Could turbulence be the reason because GPU temps stayed the same?
825 (0.45/day)
Taiwan
Processor i5-9600K
Well if mounting the fans outside doesn't get obstructed by the glass, then there shouldn't be much difference between installing outside or inside.
I think turbulence is too small of a issue when considering case airflow as it is almost inevitable. The main affecting factors should be how much is the airflow and the path the air flows through.
41,963 (6.61/day)
39 (0.04/day)
Thats retarded, id remove the glass completely and have the mesh only with fans inside
I Actually tried it no difference whatsoever, perhaps my gpu has shitty dissipation and that's it.
AsRock
TPU addict
19,069 (3.00/day)
UK\USA
OOh i would have so much fun with a dremal on that case ha. It would at least fit 3 140mm fans in the front haha.
Be bye bye glass too, and find some nice open stamped metal to let air flow in, and that PSU cover would have to be altered.
Yes must be the GFX card at fault, sure.
39 (0.04/day)
But yeah stupid first build, perhaps i could try to exchange the case for a 4000d airflow or something similar
It's really stupid like the third 120mm fan has to be mounted with water cooler radiator screws if mounted from the inside because it uses screw holes from the non removable hdd cage instead of having it's own for the bottom ones.
2,201 (1.25/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
If possible, leave the glass and remove the mesh.
39 (0.04/day)
Redone the power cable routing holding the gpu and removed the glass, and runned superposition at same settings again 72c peak yeah really doesn't make much difference.
3,094 (2.49/day)
If you have the opportunity to return this case, do it.
There are a number of thoughtfully designed, relatively attractive mid-tower cases that prioritize proper airflow. The Corsair you mentioned is one.
Here's another one to consider:
I own the Lancool II Mesh Performance and it's very easy to work in, something a novice PC builder will appreciate.
However based on your most recent test with the glass removed, a case with better airflow won't likely improve GPU temperature much further, at least not with your current graphics card.
39 (0.04/day)
However based on your most recent test with the glass removed, a case with better airflow won't likely affect GPU temperature.
Can't return it, had it running with a low tdp gpu since 2020 only now i got a higher tdp gpu that i runned into this issues. I considered a swap to the Lancool II Mesh but i been watching stock for months but it nevers come back.Only options in my budget are the Corseir 275r airflow,Cooler Master H500p or the Lian Li Lancool 205.
57 (0.06/day)
System Name MESIN TEMPUR
Processor INTEL XEON L5420
Motherboard MSI P35 NEO2
Cooling Deep cool ice edge mini fs v2.0
Memory 8 Gb
Video Card(s) Radeon HD 7770
Storage SSD 512Gb + HDD 2Tb
Display(s) LG Monitor 24 inch
Case Dark Flash Aigo
Power Supply Corsair CV 450 W
I think front and back it's should be enough
39 (0.04/day)
Some people told me that too, well got to find a use for the other two fans.
9,340 (5.41/day)
Louisiana
Keyboard G710+x3
Put the extra fans on top as intake.
39 (0.04/day)
Stupid question(I might be severely wrong), doesn't hot air go up? Placing them up there wouldn't force the hot air back down again?
9,340 (5.41/day)
Louisiana
Keyboard G710+x3
Only if there is no air to move it otherwise
The back is open for a reason so air can be pushed out
Top if filtered for intake same as front is.
You obviously need another cool air source the front is shit.
