Intel 10700K system - need advice
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Cooling Stock Intel Cooler
Video Card(s) Dell RTX 3080
Display(s) LG 32" 1440p
Case Phanteks Evolve itx
Here is the listing I have so far. My understanding is the cooler isn't included so I need a cooler. Any suggestions? His budget is $1300 CAD.
The powersupply and case are kind of a placeholder as I haven't fully decided on PSU and the case I think my friend may want isn't listed on partpicker.
Friend will be using his Vega 56 GPU for now waiting for the next series of GPU's. As well, I am covering $200 (so I will be buying the SSD and the RAM) as I am getting his old computer out of that deal (Alienware Aurora R5).
Thank you!
7,412 (2.73/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
change the case for something more airflow - oriented.I can vouch for p600s but there's very good cases that sell cheaper.
adata ssd is not bad,but I wouldn't buy a micron tlc based drive since it's by far the worst nand out there,imo get a mp510,cs3030 or something else bics-based
psu - focus,prime,superflower or rmx - best quality and noise levels.
better boards can be bought for 240 dollars.strx z490 g is matx but has all the features of an atx.
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
adata ssd is not bad,but I wouldn't buy a micron tlc drive since it's by far the worst nand out there,imo get a mp510,cs3030 or something else bics-based
Let me remind you, case is a placeholder. As I said, the case I selected isn't listed on pcpartpicker.
As for PSU, we are very limited to what I can buy out here. And due to his budget being very limited, cant find much (especially locally) for around $150 without getting garbage. So if you can check out memoryexpress.com or amazon.ca and help me find one of a good deal, then great! if not, then I am forced to use something else.
And matx is fine but what is wrong with the board I selected? It has a USB-C front port which is needed too.
Edit: Oh, forgot, the NVME drive was a placeholder for this: https://www.memoryexpress.com/Products/MX77531
Edit 2: here is this PSU I may select: https://www.memoryexpress.com/Products/MX70909 but I may go for a bit cheaper depending on my friends budget adjustments.
2,259 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
A Corsair h115i 240mm cooler or any good 240mm aio cooler.
7,412 (2.73/day)
Poland
Cooling Noctua D15S
newegg canada okay ?
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
7,412 (2.73/day)
Poland
Cooling Noctua D15S
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Should have mentioned, no AIO. My friend is illiterate when it comes to maintaining PC's and last thing I want to do is get an AIO which may have issues. So fan cooling is ideal.
5,571 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
You wont enjoy the Alienware Aurora R5 it's cramped and noisy as all hell
2,253 (1.01/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 3700x . 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. Rog b450 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
change the psu to a seasonic gx750, other wise it looks good.
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Will 650W be sufficient since I heard the new intels require power plants as is, add in a RX Vega 56 I would figure maybe a nuclear reactor...
It aint for me. I am just taking it, getting a cheap GPU in it, and re-selling it. Just mentioned it as its his payment to me and I know I can get about $600 CAD for it.
7,412 (2.73/day)
Poland
Cooling Noctua D15S
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
7,412 (2.73/day)
Poland
Cooling Noctua D15S
ssd
if you want pretty good nand,phison e12 and an actual heatsink instead of fancy trash
2,259 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Mouse Logitech G403
if you want basic air cooler, can do away from hyper 212 evo (180w) i wont try oc with this cooler
if you want something more powerful can get noctua's or be quiet brands
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
cant, thats beyond budget as I am paying for the SSD and RAM. Since all I am getting is his older computer, paying for parts and putting it together I am not gonna go over my agreed amount. I'll go over it with him and see if he will pay the difference.
Edit: I may just pay the $10 difference anyway. If it is that much better.
Any specific BeQuiet you suggest?
I should have mentioned that Memory Express allows price matching. Here is their listings of SSD's
Thanks for the help so far guys.
7,412 (2.73/day)
Poland
Cooling Noctua D15S
tabascosauz
8,197 (2.35/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Shadow Rock 3, Dark Rock Slim, or Dark Rock 4 Pro. I'd probably stay away from the regular Dark Rock 4 if you want to use any RAM taller than Corsair LPX. DRP4 fits Trident Z almost perfectly.
The Silent Wings 120mm on the Dark Rocks (also 135mm on DRP4) are hands down the quietest fans even at 100% speed. Tradeoff is that Noctua usually takes the performance crown slightly in each segment.
The new STIM purportedly works wonders for the 10600K/10700K/10900K as they seem to run quite cool in comparison to their power draw. I'd still go for at least a Dark Rock Slim.
For the best value, look for an Arctic E34. However, things have gotten real expensive as of late on amazon.ca.
7,412 (2.73/day)
Poland
Cooling Noctua D15S
arctic liquid freezer available in CN ?
5,847 (0.80/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
What is his intended usage? He would save a LOT of money by going for AMD over Intel, as well as having a cooler and quieter system. Plus the AMD CPU I'd suggest (3600) comes with a good quality stock cooler.
For example, 3600 is $290, a B450 board with WiFi is $140. That's $430 against the $814 for the Intel CPU + board you have listed, which is a saving of $384.
If he needs 8 cores and 16 threads, the 3800X is $475 which is still cheaper than the Intel chip, and it can still be paired with a cheap-ish B450 board.
If he is really adamant on Intel, rather go for the i5-10600K over the i7-10700K - the two extra cores are not likely to make much of a difference. And not sure why you would be going for a Z490 (overclocking) board if he isn't going to be using its features, the Asus Prime H470-PLUS/CSM is only $163.
He doesn't want water cooling as per post #8.
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
It is indeed mostly gaming. I was aiming at Intel currently simply because Its close to same price (x570 motherboards all seem to be sold out for something half decent and hard to come by), with the Intel being slightly better at gaming. I was also thinking that it would be cheaper to use AMD just because it comes with a stock cooler.
As for the 8 cores / 16 threads it is mostly because since the new consoles will be using 8c/16t was trying to "future proof" as best as I can without going the extreme (12 core / 24 threads or 10 core / 20 threads).
Heck, even Memory Express is jacking up prices. If I can get free shipping I would be looking at Canada Computers.
dgianstefani
TPU Proofreader
5,158 (2.01/day)
Swansea, Wales
System Name Silent/X1 Yoga
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader/1185 G7
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Benchmark Scores Legendary
Noctua U12A - quiet and cool.
Mobo I would go for the MSI Unify, but that's a little more expensive.
+1 on the Intel 10th gen chips running cooler than their power draw would otherwise suggest (as long as you have cooling capacity), I've been playing around with a couple of 10900k to find a good bin and am pleasantly surprised I don't even need water to cool them at all core 5.2.
7,412 (2.73/day)
Poland
Cooling Noctua D15S
silly
consoles will be using 8/16 ryzen at 3.5-3.9ghz
a 10400f would smash that.
I suggest 10700f or 10600kf
3,371 (0.48/day)
Canada
System Name PCGR
Processor 12400f
silly
Sticking with either 10700k or 3700x. Simply as I said, the cores and threads. 10400 won't smash that as soon as something becomes demanding in multithreaded use, it will get smashed itself.
And the KF series don't seem to be available here, just the K models. Otherwise I would have used the ones without GPU's built in to save about $50.
I truly think the upcoming consoles will throw a wrench in the way for anything less than 8/16 just because games will be optimized for that. 10400K is good and all, but I don't believe for anything in near future.
7,412 (2.73/day)
Poland
Cooling Noctua D15S
100% untrue,spread by fake news YT channels like MLID or AdurrrrrdTV,backed by 0 evidence
