mixa
- Jun 29, 2005
- 117 (0.02/day)
- Aden Castle Town
Processor | AMD Athlon64 2800+ @ ~2.3GHz |
Motherboard | Asus K8N4-E Deluxe |
Cooling | Zalman CNPS7000B Al-Cu |
Memory | 2 x 512MB Vitesta (TCCDs) @ 255MHz , 2-3-3-9 |
Video Card(s) | Sapphiretech X700 Pro @ XT |
Storage | 2 x 80Gb Hitachi DeskStar 7k250 , RAID 0 |
Display(s) | LG L1710B |
Case | CoolerMaster ATC-210C-AX2 |
Audio Device(s) | Sound Blaster Audigy 1 |
Power Supply | FSP Group Fortron 400W w/silencer |
Software | Windows XP SP2 / fbsd 5.xx |
Intel Corp. and Corning Incorporated have entered into an agreement to develop ultra low thermal expansion ULE glass photomask substrates required for Extreme Ultraviolet (EUV) lithography technology. These substrates are needed to develop low defect EUV photomasks to enable 32nm node high-volume production using EUV lithography.
Lithography tools are used in chip making to "print" patterns on a silicon wafer. Today, the industry uses lithography tools that use a 193nm wavelength of light to "print" transistors as small as 50nm. That is equivalent to a painter trying to draw very fine lines using a thick brush. EUV lithography technology will use light that is only 13.5nm wavelength of light, so it can provide chip makers with a very "fine brush" to "draw" smaller transistors in the future.
EUV lithography has been identified by the International Roadmap of Semiconductor Technology as the leading technology solution for next-generation lithography after the current 193nm generation of lithography tools.
"Driving down EUV photomask defect levels is a critical issue for the commercialization of EUV technology. Corning and Intel plan to address the mask substrate contribution to this issue," said Janice Golda, Intel's director of lithography. "The development of higher-quality EUV masks, along with Intel's related efforts in light sources, lithography equipment and new photo resists, will help create the infrastructure needed to position EUV lithography as the key technology for the future."
The joint development program will help to enable chip production using EUV technology starting in 2009.
Source : X-bit labs
Source : X-bit labs
