Intel "Arrow Lake-H" SKUs Leak: Up to 16 Cores, with LPE Cores Resurfacing
AleksandarK
2,606 (0.98/day)
As we await the launch of Intel's "Arrow Lake-S" Core Ultra 200S series of processors for desktops, we are getting some new leaks about Intel's mainstream mobile "Arrow Lake-H" update. A month ago, we got the specification table of the high-end mobile "Arrow Lake-HX," and now, thanks to Jaykihn X, we have the mainstream laptop chip specifications as well. The top-of-the-line includes Intel Core Ultra 9 285H, a 45 W TDP SKU with six P-cores, eight E-cores, and two LPE cores. The CPU packs integrated Xe2 graphics with eight cores and 24 MB of total L3 cache and has a maximum boost of 5.4 GHz for P-cores.
Moving down the stack, there are Core Ultra 7 265H and Core Ultra 5 255H SKUs, which feature the same P/E/LPE core configuration. However, these SKUs are rated for 28 W TDP, having lower maximum frequencies and the same iGPU configuration. This time, we also have two Core Ultra 3 SKUs, with Core Ultra 3 235H and 225H bringing four P-cores, eight E-cores, and two LPE-cores in the 28 W package. The Core Ultra 3 235H has eight Xe2 cores in its iGPU, while the lowest-end Core Ultra 3 225H has only seven Xe2 iGPU cores. For a complete set of specifications, including all clock speeds in base and boost, please check out the table below.
1,021 (0.64/day)
System Name Dirt Sheep | Silent Sheep
Processor i5-2400 | 13900K (-0.02mV offset)
Motherboard Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline
Cooling Scythe Katana Type 1 | Noctua NH-U12A chromax.black
Memory G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz
Video Card(s) Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV)
Storage 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1
Display(s) LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27
Case Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot)
Audio Device(s) Beyerdynamic DT 990 (or the screen speakers when I'm too lazy)
Power Supply Enermax Pro82+ 525W | Corsair RM650x (2021)
Mouse Logitech Master 3
Keyboard Roccat Isku FX
VR HMD Nop.
Software WIN 10 | WIN 11
Benchmark Scores CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500
What's "LPE"?
I missed this one..
tabascosauz
8,159 (2.36/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
What's "LPE"?
I missed this one..
The new "island" E-cores that came with Meteor Lake and disaggregation. They're not on the compute tile with the rest of the cores, instead they are integrated into the SOC tile (ie. Intel's IO die).
Basically even more E-core than E-cores, to get the most [idle and low load] efficiency out of laptop silicon that have the LP E-cores. More efficiency-oriented V-F curve than the regular E-cores with separate voltage regulation, and obviously its voltage/power is not reliant on what the compute tile is doing at the time.
123 (0.05/day)
Processor AMD Ryzen 5 3600
Motherboard Asus ROG Strix X470-F
Cooling Reeven RC-1205
Memory G.Skill F4-3200C16D-16GTZKW TridentZ 16GB (2x8GB)
Video Card(s) Powercolor x470 red devil
Storage Mushkin MKNSSDPL500GB-D8 Pilot 500GB
Display(s) Samsung 23"
Case Phanteks PH-EC300PTG
Audio Device(s) SupremeFX S1220A
Power Supply Super Flower SF-650F14MT(BK) Leadex 650W 80 Plus Silver
Mouse Cooler master m530
Keyboard Cheapo
Intel losing the plot, they should rather focus on getting their P cores more efficient. All these other E cores not doing Intel any favours with heat and power consumption.
1,021 (0.64/day)
VR HMD Nop.
So Low Power Ecores, as I suspected
39 (0.07/day)
This is just Meteor Lake H rebranded. Specs like cores and cache match.
3,765 (1.32/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
That is actually a pretty nifty idea. This should allow powering down compute tiles and only leaving SOC tile powered at idle. And SOC tile is the only one that needs to be. No idea whether this actually works all that well in reality though.
395 (3.16/day)
Even more lower power consumping cores than E core, here is an article from MSI explaining that:
I'll watch and see how the software support is for processors with mixed cores and for processors with many cores.
My software will crash on processors with mixed cores which have mixed instruction sets.
151 (0.11/day)
System Name Upgraded CyberpowerPC Ultra 5 Elite Gaming PC
Processor AMD Ryzen 7 5800X3D
Motherboard MSI B450M Pro-VDH Plus
Memory CM4X8GD3000C16K4D (OC to CL14)
Video Card(s) XFX Speedster MERC RX 7800 XT
Storage TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB
Display(s) AOC Agon AG241QX 1440p 144Hz
Case Cooler Master MasterBox MB520 (CyberpowerPC variant)
Power Supply 600W Cooler Master
It almost certainly isn't.
Meteor Lake and Arrow Lake have the same amount of L3 per core. The 245K and 155H are both 6P+8E, and both have 24MB L3. That doesn't make them the same, the CPU core architectures are different.
Arrow Lake H is expected to use the same I/O tile as Meteor Lake, but the compute tile should be new, with Lion Cove and Skymont, instead of Redwood Cove and Crestmont.
