So I hope this is the correct forum in which to ask about this. I purchased a Geekom Mini IT8 back in April. It uses an Intel Core i5-8259U that is clocked nominally at 2.3GHz, but supports Turbo-Boost under 100% load up to 3.8GHz. The system is shipped with Windows 11 with Turbo-Boost enabled (i.e.: Maximum Processor State = 100%.)
When I run a program that pushes all 4 cores (or all 8 threads) to 100% (for example HandBrake rendering an H264 video, or the Intel Processor Diagnostic Tool), and measure core temperature with the Core Temp (1.17.1) utility, I see that cores 0 and 2 almost instantaneously run up from 40-50 degrees Celsius (computer idle) to 95-100 degrees Celsius; cores 1 and 3 hover in the 80-90 degrees Celsius range. Since TjMax for this processor is 100 degrees Celsius, I am more than a little bit concerned.
After approximately a minute with cores 0 and 2 at that high temperature, the processor throttles down to less than 3.8GHz (with an accompanying decrease in thruput) and those core temps drop into the low to mid 90s, which is still very high according to the internet.
So my question is: Will running HandBrake for a half hour to an hour now and then and allowing those cores to run at such high temperatures be detrimental to my processor (i.e. will its lifetime be reduced or can I expect it to fail prematurely)? Of course other programs may also, from time to time, use 100% of all 8 threads, but are not as likely to run that way for long periods of time.
Regarding heat sinking in the Geekom IT8 Mini, it is to my mind a bit strange. There is a fan which sits on top of the heatsinked CPU and GPU that pushes air (at a good clip when temperatures are running high) through a finned copper heat exchanger and out the back of the case. But the heat exchanger is remote from the chips (that is, not on top of them) with copper plates on top of the chips and a strange arrangement to conduct the heat to the heat exchanger. Here is a picture of this arrangement (with the fan removed):
What do you all think of this heat sink and my temperature issues? Had I never downloaded and run the Core Temp utility, I would have been blissfully unaware of the whole issue, but still this has clearly been going on since April, and it's still up and running. Am I needlessly worrying? For right now, I've turned off Turbo-Boost by setting the Windows 11 power parameter Maximum Processor State to 99%, and everything runs cool as a cucumber, but it takes a bit longer to render a video.
Thanks in advance for any advice this community can offer.
