Intel Foundry Unveils Technology Advancements at IEDM 2024
GFreeman
1,558 (2.41/day)
Today at the IEEE International Electron Devices Meeting (IEDM) 2024, Intel Foundry unveiled new breakthroughs to help drive the semiconductor industry forward into the next decade and beyond. Intel Foundry showcased new material advancements that help improve interconnections within a chip, resulting in up to 25% capacitance by using subtractive ruthenium. Intel Foundry also was first to report a 100x throughput improvement using a heterogeneous integration solution for advanced packaging to enable ultra-fast chip-to-chip assembly. And to further drive gate-all-around (GAA) scaling, Intel Foundry demonstrated work with silicon RibbonFET CMOS and with gate oxide module for scaled 2D FETs for improved device performance.
"Intel Foundry continues to help define and shape the roadmap for the semiconductor industry. Our latest breakthroughs underscore the company's commitment to delivering cutting-edge technology developed in the U.S., positioning us well to help balance the global supply chain and restore domestic manufacturing and technology leadership with the support of the U.S. CHIPS Act," says Sanjay Natarajan, Intel senior vice president and general manager of Intel Foundry Technology Research.
As the industry heads toward putting 1 trillion transistors on a chip by 2030, breakthroughs in transistor and interconnect scaling - multiplied by future advanced packaging capabilities - are critical for delivering on the endless appetite for more energy-efficient, high-performing and cost-effective computing applications such as AI.
The industry will also require additional support in the form of new materials to augment Intel Foundry's PowerVia backside power delivery in relieving interconnect crowding and for continued scaling, which is vital to the continuation of Moore's Law and driving the semiconductor forward into new eras for AI.
Intel Foundry has identified several paths that solve anticipated limitations of copper transistors in interconnect scaling for future nodes, improve upon existing assembly techniques, and continue to define and shape the transistor roadmap for gate-all-around scaling and beyond:
  • Subtractive Ruthenium (Ru): To help improve the performance and interconnections within chips, Intel Foundry showcased subtractive ruthenium, a new key alternative metallization material that uses thin film resistivity along with airgaps to deliver a significant advancement in interconnect scaling. The team was first to demonstrate, in R&D test vehicles, a practical, cost-efficient and high-volume manufacturing compatible subtractive Ru integrated process with airgaps that does not require expensive lithographic airgap exclusion zones around vias, or self-aligned via flows that require selective etches. The implementation of airgaps with subtractive Ru provided up to 25% of line-to-line capacitance reduction at pitches less than or equal to 25 nanometers (nm), illustrating the benefits of subtractive Ru as a metallization scheme to replace copper damascene in tight pitch layers. This solution could be seen on Intel Foundry's future nodes.
  • Selective Layer Transfer (SLT): To enable up to 100x higher throughput for ultra-fast chip-to-chip assembly in advanced packaging, Intel Foundry is first to demonstrate Selective Layer Transfer (SLT), a heterogeneous integration solution that enables ultra-thin chiplets with much better flexibility to enable smaller die sizes and higher aspect ratios versus traditional chip-to-wafer bonding. This allows higher functional density and leads to a more flexible and cost-efficient solution for hybrid or fusion bonding of specific chiplets from one wafer to another. This solution offers a more efficient and flexible architecture for AI applications.
  • Silicon RibbonFET CMOS: To push gate-all-around RibbonFET silicon scaling to its limits, Intel Foundry showcased silicon RibbonFET CMOS (complementary metal oxide semiconductor) transistors at a gate length of 6 nm with industry-leading short channel effects and performance at aggressively scaled gate length and channel thickness. This advancement paves the way for continued gate length scaling, one of the key foundational cornerstones of Moore's Law.
  • Gate Oxide for Scaled GAA 2D FETs: To further accelerate gate-all-around innovation beyond CFET, Intel Foundry showcased its work on the fabrication of GAA 2D NMOS and PMOS transistors with scaled gate length down to 30 nm with a specific focus on gate oxide (GOx) module development. The research reports on the industry's investigation of two-dimensional (2D) transition metal dichalcogenide (TMD) semiconductors, which may be a future replacement for silicon in advanced transistor processes.
Additionally, Intel Foundry continued to advance research with the industry's first 300 millimeter (mm) gallium nitride (GaN) technology, an emerging technology for power and radio frequency (RF) electronics that can deliver higher performance and sustain higher voltages and temperatures than silicon. This is the industry's first high-performance scaled enhancement-mode GaN MOSHEMTs (metal-oxide-semiconductor high electron mobility transistors), fabricated on a 300 mm GaN-on-TRSOI ("trap-rich" silicon-on-insulator) substrate. Advanced-engineered substrates like GaN-on-TRSOI can achieve better performance in applications such as RF and power electronics by reducing signal loss and achieving better signal linearity, enabling advanced integration schemes that may be realized through backside substrate processing.
At the conference, Intel Foundry also laid out its vision for the future of advanced packaging and transistor scaling to meet demands across applications including AI. Three key thrusts for innovation were identified to help drive the next decade toward more power-efficient AI.
  • Advanced memory integration to eliminate capacity, bandwidth and latency bottlenecks.
  • Hybrid bonding for interconnect bandwidth optimization.
  • Modular system expansion with corresponding connectivity solutions.
Intel Foundry also shared a call to action to develop critical and revolutionary innovations for continued transistor scaling for the trillion-transistor era. Intel Foundry outlined how developing a transistor capable of ultra-low voltage operation (less than 300 millivolts) will help address increasing thermal bottlenecks and result in dramatic improvements in energy consumption and thermal dissipation.
For more information on Intel Foundry's technical papers presented at this year's IEDM, please visit the IEDM website.
1,274 (0.53/day)
"Intel Foundry continues to help define and shape the roadmap for the semiconductor industry."
Really? The whole industry should follow them at failing their own fabs and outsource?
Low quality post by AcE
AcE
104 (11.56/day)
Typical Intel delusions/arrogance. It's how they ruined the company in the first place.
898 (0.84/day)
It takes hundreds of millions in r&d to make little advancements on a tool chain that involves many companies all over the world, intel is and has been a huge contributor to global advancement since the start.
225 (0.29/day)
Even if the "Intel Foundry" had the most advanced lithography process in the world and a high yield of functional chips per wafer, I would not hire it to manufacture the chips for the company of which I was CEO. Any sane CEO would do the same.
The company that hires Intel's chip manufacturing services will provide all of its industrial secrets, well in advance, to Intel, which is a major competitor of almost all other hardware companies.
For these and other reasons, Intel has to sell its factories and only keep the most advanced one, if it makes profit for Intel.
14,142 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
No you got that wrong, they are helping the industry by showing what not to do.
575 (0.11/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
So what is it “we are broke” (previous news)…or “we’re so bright, gotta wear shades”?
