Intel Issues PCN to Improve NUC Cooling
47,061 (7.59/day)
Intel issued a product change notification (PCN), marked 112432-00, which attempts to improve the reliability of the system under heavy wireless network stress. A design flaw in Intel's reference NUC boxes equipped with wireless LAN and Thunderbolt came to light late last year, when a reviewer at TechReport discovered that when under stress, the mPCIe WLAN card can overheat, causing the neighboring mSATA SSD to malfunction. In its latest PCN, Intel included a 9.5 mm-thick flexible thermal pad on the top panel, which draws heat from the SSD, and conducts it to the chassis.
3,755 (0.87/day)
System Name Skunkworks
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software openSUSE tumbleweed/Mint 21.2
why not a single, silent, slow 120mm fan? or a fan that would fit, if that is too large. that would fix a lot of problems...
895 (0.21/day)
Another day, another product defect from Intel. No wonder their sales continue to drop.
Fourstaff
10,070 (1.86/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Even if that product is completely wiped out Intel's sales will barely register a blip. When you introduce new products teething problems are bound to happen, especially with miniaturisation.
746 (0.12/day)
Nobody wants a failure-prone fan if the NUC is destined to be a "Media Center" type hub. Passive cooling > active cooling for these purposes.
Deleted member 24505
wonder if they have had any mSATA SSD failures because of this? or does malfunction mean the mSATA SSD failed.
6,757 (1.39/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
If I were to get one of these I would not want a fan if it could be cooled passive. Although a slightly bigger passive body I would not mind.
59 (0.01/day)
What are you talking about? The reference design already uses a fan.
887 (0.15/day)
Processor Intel Core i3-8100
Motherboard ASRock H370 Pro4
Cooling Cryorig M9i
Memory 16GB G.Skill Aegis DDR4-2400
Video Card(s) Gigabyte GeForce GTX 1060 WindForce OC 3GB
Storage Crucial MX500 512GB SSD
Display(s) Dell S2316M LCD
Case Fractal Design Define R4 Black Pearl
Power Supply Corsair CX600M
Mouse Logitech M500
Keyboard Lenovo KB1021 USB
So, rather than directly address the heat output from the WLAN card, Intel decided to drain the heat from the mSATA SSD that was being cooked. Nice.... :shadedshu
