Intel Larrabee Capable of 2 TFLOPs
47,076 (7.59/day)
German tech-journal Heise caught up with Intel's Pat Gelsinger for an article discussing the company's past and future as the silicon giant heads towards 40 years of service this 18th of July.
Among several topics, came up the most interesting one, visual computing and Intel's plans on it. 'Larrabee' strikes as a buzzword. It is the codename of Intel's upcoming graphics processor (GPU) architecture with which it plans to take on established players such as NVIDIA and AMD among others.
What's unique (so far) about Larrabee is that it's entirely made up of x86 processing cores. The Larrabee is likely to have 32 x86 processing cores. Here's a surprise: These processing cores are based on the design of Pentuim P54C, a 13+ year old x86 processor. This processor will be miniaturised to the 45nm fabrication process, they will be assisted by a 512-bit SIMD unit and these cores will support 64-bit address. Gelsinger says that 32 of these cores clocked at 2.00 GHz could belt out 2 TFLOPs of raw computational power. That's close to that of the upcoming AMD R700. Heise also reports that this GPU could have a TDP of as much as 300W (peak).
With inputs from Heise
2,116 (0.31/day)
System Name Not named
Processor Intel 8700k @ 5Ghz
Motherboard Asus ROG STRIX Z370-E Gaming
Cooling DeepCool Assassin II
Memory 16GB DDR4 Corsair LPX 3000mhz CL15
Video Card(s) Zotac 1080 Ti AMP EXTREME
Storage Samsung 960 PRO 512GB
Display(s) 24" Dell IPS 1920x1200
Case Fractal Design R5
Power Supply Corsair AX760 Watt Fully Modular
wow 300 watts eh? Could heat the lower level of my house. I get the strange feeling this is either going to horribly flop or do incredibly well. Very little middle ground :p
Morgoth
Fueled by Sapphire
4,236 (0.68/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
I want actual pics of the card...
i'm not sure but i tough it was an Intergrated GPU on Nehalem with 2 cores + Ht :S
now i have seen this
i'm starting to get confused lol
btarunr Its spelled Larrabee
47,076 (7.59/day)
So, that 150W connector is 10-pin? (I'll eliminate 12-pin since two 6-pin connectors have a blank pin each that could be shared with pin #3)
746 (0.12/day)
300 watts. Can you say nuclear reactor? What happened to efficiency, Intel? :(
I don't like where GPU's are heading. There's too much power draw for so little performance increase. This goes for all GPU makers. Something needs to be done to bring power demands back in line with the rest of computer components. They have enough trouble as it is squeezing last-generation high-end GPU's in notebooks, but this is just ridiculous.
7,180 (1.15/day)
most wack gpu ive ever seen
whoever thought that having 32 old cpus and makign a gpu based out of it is either incredibly stupid or amazingly crafty
im not even going to bother saying much because we all know nothing matters untill we get results
STILL i know for a fact 300w is alot for gpu i mean you could run a full pc on that nearly
5,106 (0.81/day)
Kansas
Processor Core i5 3570K
Motherboard AsRock z77 Pro4
Cooling Zalman CNPS10X Extreme
Memory 2x4GB GSkill Sniper
Video Card(s) MSI GTX970 Gaming
Storage 240GB OCZ ARC 100, Samsung Spinpoint F3 1TB
Display(s) LG 23" 1920x1080
Case Antec P100
Power Supply Antec Edge 750W
Software Windows 8.1 Pro 64
I'd never have to run the heater in the winter; I'll just play more games!:p
7,180 (1.15/day)
wonder if you could run programs on the gpu instead of the cpu LOL this card boggles me completely
47,076 (7.59/day)
Why so much fuss about its TDP? Wasn't the HD2900 XT like 200W (peak)?
Mussels
Freshwater Moderator
58,413 (8.00/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Pentuim? is that some CPU i never heard of?
*cough spellcheck*
300W TDP... gack.
3,946 (0.63/day)
Police/Nanny State of America
Processor OCed 5800X3D
Motherboard Asucks C6H
Cooling Air
Memory 32GB
Video Card(s) OCed 6800XT
Storage NVMees
Case Freebie glass idk
Audio Device(s) Sennheiser
Since when is a general purpose cpu going to be able to process graphics at a respectable rate?
If that was the case, everyone with a quad core would be getting 50 FPS in 3dmark with the cpu test (I don't care if it has high speed ram and cache attached or not). I'm calling intel retarded, again.
edit: Or it's more fud. Like that 10 GHz pentium 4 they just had laying around :laugh:
47,076 (7.59/day)
If a ~70 GFLOPs Core 2 Extreme can do ~6 fps, guess what 2000 GFLOPs can.
dracoonpit
17 (0.00/day)
Germany
I disagree. Comparing to performance-increase, GPUs have been more efficient with every new model. Performance per Watt ratio of new GPUs is better - no matter if they need 200 watts ..
3,946 (0.63/day)
Cooling Air
Memory 32GB
Storage NVMees
That's 100% theoretical max. I have a lot more faith in a c2e than some untested, whack design that supposed to be from old architecture. If it's new architecture or at least mostly from the ground up, then I'll be quiet. What they're claiming is just ridiculous.
To me, this is like M$ saying the xbox 360 is fast b/c it has tri-core and runs at 3.2 GHz. But in reality there's not many transistors and it just can't push much data.
41,479 (6.58/day)
intel can claim this and claim that, by the time they release the card it will already be obsolete by Nvidia and AMD, hell even Via.
Mussels
58,413 (8.00/day)
Oystralia
the only thing this has over video cards, is the x86 architecture. that means you can effectively add 32 CPU cores to any machine. ANY app should be able to use it (games, encoding/decoding apps, etc)
3,946 (0.63/day)
Cooling Air
Memory 32GB
Storage NVMees
VIA!!! Fastest. Stuff. Ever. :laugh:
Seriously, though, VIA was cool back in the day, but they pissed me off when the athlon 64s came out. Those boards were slow and buggy.
47,076 (7.59/day)
Just as you say you'd be silent if it was something built from scratch, you can't be loud about this either. As for scratch, these are 'old' processors, but shrunk, clocked to 2 GHz, .....etc. When something of this sort comes from Gelsinger, it's better we not jump to assumptions that it's a 'bad' architecture, since we've seen nothing to prove it's bad just as yet.
Mussels
58,413 (8.00/day)
Oystralia
since the core architecture (core solo/duo, and then onto core 2 duo/quad) designs came from a pentium 3 tualatin, his argument really falls down anyway. old cores that hit a tech limit can really be revilatised with new tech and die shrinks.
panchoman
Sold my stars!
9,595 (1.53/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
WTF you call that a gpu? thats not a gpu! thats 32 p4 cores stuck together on a card with a 300w tdp after a huge ass die shrink! WTF intel.. i expected much much much more from you, come on.. 32 p4 cores stuck together to make a gpu...
47,076 (7.59/day)
A quad-core QX9770 draws 130W, isn't 32 cores @ 300W an improvement?
Mussels
58,413 (8.00/day)
Oystralia
well 300W TDP isnt so bad... oh wait yes it is. TDP means its not max, so it could even go upto 400W real draw.
That said, this is intel. they could easily throw in some power saving features and have its power usage scale really well (modified speedstep, for example)
