- Apr 3, 2019
- 44 (0.02/day)
- London, UK
System Name | Custom Water-cooled Server / Desktop |
Processor | Dual Intel Xeon E5465 / i5-11400 |
Motherboard | Asus Z8NA-D6 / Prime H570-plus |
Cooling | Custom built: DangerDen MC-TDX / H100i |
Memory | 24GB DDR3 / 16GB DDR4-3200 |
Video Card(s) | GTX470 / RTX2080 |
Storage | SSD + 1TB HDD / P5-Plus + BX500 |
Display(s) | BenQ GW2765 1440p |
Case | CoolerMaster Full Tower / Cosmos |
Power Supply | PC Power & Cooling 750w (both) |
Software | Ubuntu / Windows 11 |
I have an issue with the Intel NIC as it disconnects (restarts) multiple times a day. My motherboard is Asus Prime H570-Plus which has onboard the Intel I219-V NIC. Windows 11 is fully updated as are the Intel Ethernet drivers (12.19.1.37). I have used Intel ProSet Config Utility to run all diagnostics which all Pass.
Windows Event Log shows:
The network interface "Intel(R) Ethernet Connection (14) I219-V" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets. Reason: The network driver detected that its hardware has stopped responding to commands. This network interface has reset 6 time(s) since it was last initialized.
Anyone else getting this? Any solution?
Thanks
Russ
Thanks
Russ
