- Aug 19, 2017
- 2,753 (1.01/day)
According to the report from Volksstimme.de, Intel has delayed its Magdeburg fab construction until 2025 due to difficulties in acquiring suitable land. The company had initially planned to begin construction in 2024, but the process has been slowed significantly due to the availability of suitable land. The Magdeburg plant is a significant investment for Intel, with the company planning to invest around €30 billion in the facility. The plant is expected to create thousands of jobs and play a crucial role in the company's European expansion plans. However, the delay in construction is likely to impact these plans and may result in a longer timeline for the plant's completion.
The delay is attributed to the difficulty in finding suitable land for the plant. Intel's original plan of producing a factory on the land concluded that there was humus-rich black soil up to 40 cm in the ground, which would get removed for usage by agricultural fields in Germany. However, now the top layer of black soil, which needs to be excavated, is measured up to 90 cm in depth, which doesn't allow fab construction to start and requires the removal of the soil in order to satisfy the safety regulations. This useful soil has to be extracted first before being "contaminated" with concrete and other types of foundation soils like gravel. The state of Saxony-Anhalt postponed the construction until the required soil was removed and regulations were met. This will supposedly happen by the end of 2024, and construction will start in 2025.
