Intel Yorkfield 6GHz Sky-High Overclock
malware
5,422 (0.75/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
The OC guru, Shamino has broken the 6GHz (12x500MHz) clock barrier using Intel Core 2 Extreme QX9650 cooled with LN2 on a modded Foxconn Quantum Force board. Check out his achievement here.
Easy Rhino
Linux Advocate
15,559 (2.38/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software The Matrix
that is pretty fast.
malware
5,422 (0.75/day)
Bulgaria
Why is cpuz showing 3002.2 mhz?
I think it displays the multiplayer wrong...I already hate cpuz for that reason, it shows my E6300 working at 6x multi for some reason. Last 3 new versions of cpuz didn't help fix the issue.
JC316
Knows what makes you tick
9,397 (1.38/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
Thats probably because you have speedstep, c1E, and/or thermal management on. It lowers the multiplier when not in use to consume less power.
malware
5,422 (0.75/day)
Bulgaria
At 3.2GHz do you think I have the thermal managment on? ;) I'm aware of all the options you mention, but that's not the problem here. Lots of users have this issue with cpuz.
11,920 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Oh no, it is a Clockgen overclock, so it isn't valid. Everyone start flaming him.......
JC316
9,397 (1.38/day)
Storage 1TB Sata2
Case Generic black
Hmm, thats odd, your board might have something of it's own. I had all of those turned off and then found a reduced power option on my board that was doing it.
DOM
7,628 (1.14/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
I just disable C1E Support, have you tryed that ? I even have speedstep enabled I find it only works at default settings so try the dis. C1E it should work ;)
malware
5,422 (0.75/day)
Bulgaria
Just like I said...yeah I am aware of all the options and I've tried them all, no change. Anyways, my CPU works at 3.2GHz 24/7 I don't care what cpuz says.
To be honest, my wrong cpuz freqs started from version 1.39, before this version everything worked right for me, with 1.38 I had no problems.
P.S. btw this is Shamino's 6GHz thread, not my cpuz bug, stick to the topic. :)
kwchang007
3,962 (0.61/day)
Severn, MD, USA.
Processor C2D T7200@2 ghz vcore: .9875
Motherboard generic laptop board
Cooling fan control and antec notebook cooler
Memory 2 GBs@ 533 mhz ddr2
Video Card(s) x1400 mobile, overclocked: 526mhz core/ 882mhz ddr
Storage 120 GB@ 5400 rpm fujitsu
Display(s) 15.4" 1440x900
Audio Device(s) integrated
Software vista 32 bit home premium
SWEET, I wanna see some benchies
2,116 (0.31/day)
System Name Not named
Processor Intel 8700k @ 5Ghz
Motherboard Asus ROG STRIX Z370-E Gaming
Cooling DeepCool Assassin II
Memory 16GB DDR4 Corsair LPX 3000mhz CL15
Video Card(s) Zotac 1080 Ti AMP EXTREME
Storage Samsung 960 PRO 512GB
Display(s) 24" Dell IPS 1920x1200
Case Fractal Design R5
Power Supply Corsair AX760 Watt Fully Modular
Meh only 6ghz, i can run faster than that.
2,490 (0.39/day)
Your house.
System Name Jupiter-2
Processor Intel i3-6100
Motherboard H170I-PLUS D3
Cooling Stock
Memory 8GB Mushkin DDR3L-1600
Video Card(s) EVGA GTX 1050ti
Storage 512GB Corsair SSD
Display(s) BENQ 24in
Case Lian Li PC-Q01B Mini ITX
Power Supply Corsair 450W
Mouse Logitech Trackball
Keyboard Custom bamboo job
Benchmark Scores Finished Super PI on legendary mode in only 13 hours.
p_o_s_pc
F@H&WCG addict
13,006 (2.04/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
I have got my highest clock using Easytune 5... I don't care how you get the OC all that i care about is what you are running at. You can get the clock anyway you want.
2,116 (0.31/day)
p_o_s_pc
F@H&WCG addict
13,006 (2.04/day)
Newark ohio
Did you just call me hot? :eek:
no i don't think he called you hot but he called your CPU hot but this is HOT!!
WarEagleAU
Bird of Prey
10,812 (1.62/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
haha, nice pic. Amazing OC too, first 6GHZ I have seen verified.
2,276 (0.35/day)
Cairns QLD, Aussie
System Name GaMEr / HTPC
Processor FX8320 4.5ghz so far NB- 2815mhz / X2 255 @ 3.2ghz (Temp till BD)
Motherboard 990FX-UD5 / GA-MA785GPMT-US2H
Cooling XSPC - 240rad 480rad 5 x 120mm out, 6 x 80mm in / H220-edge 1/2" & 2 x 120mm Magma
Memory 4gb PI 6,8,6,18 1T 1706mhz / 4gb Crucial D9's 1400 @ 6,6,6,18,1T
Video Card(s) 3gb HD7950 / Onboard
Storage 2 x 120gb Sandisk ultra plus 2tb WD / 60gb vertex 2 + 2 x 2tb WD Greens
Display(s) 3x24in Dell Ultra (portrait) / NEC 32" FullHD LCD
Case LL PC71A Full tower / Antec fusion black with Imon remote Modded for WC
Audio Device(s) OB / Auzentech cinema 7.1
Power Supply TT 700w TR2 / TT 600w Litepower modded with Noctua S12 fan.
Software 7 Ult / 7 premium x64
he only had 1.59 on the core... Surely a watercooled setup could handle that???
Then again I know how hot the friggin quads get, even at 1.4v.....
Superpi would be pretty quick on that thing... :)
Wile E
Power User
24,318 (3.70/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
I doubt it was only 1.59. CPU-z tends to misread vcore when you pass a certain point.
3,942 (0.62/day)
System Name Widow
Processor Ryzen 7600x
Motherboard AsRock B650 HDVM.2
Cooling CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5)
Memory 32GB Gskill Flare X5
Video Card(s) GTX 1080 TI
Storage Samsung 9series NVM 2TB and Rust
Display(s) Predator X34P/Tempest X270OC @ 120hz / LG W3000h
Case Fractal Define S [Antec Skeleton hanging in hall of fame]
Audio Device(s) Asus Xonar Xense with AKG K612 cans on Monacor SA-100
Power Supply Seasonic X-850
Mouse Razer Naga 2014
Benchmark Scores FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x
I just want to see these kids play a game or use a 3d intensive application for two hours, then come back and tell us it's 'stable.'
hat
Enthusiast
21,744 (3.33/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
liquid nitrogen, 2.5v probably, and most likely stable
liquid nitrogen can do anything :D
