Intel's statement on IHS warping
1,065 (0.29/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
read this on TMG and since the first thing i saw here today was a i9-12900K temp issues thread.
the problem
unlocked/locked
"We have not received reports of 12th Gen Intel Core processors running outside of specifications due to changes to the integrated heat spreader (IHS). Our internal data show that the IHS on 12th Gen desktop processors may have slight deflection after installation in the socket. Such minor deflection is expected and does not cause the processor to run outside of specifications. We strongly recommend against any modifications to the socket or independent loading mechanism. Such modifications would result in the processor being run outside of specifications and may void any product warranties." Intel Spokesperson to Tom's Hardware.
some further questions:
  • Are there any planned changes to the ILM design? This condition might only exist with certain versions of the ILM. Can you confirm that these ILM are to spec?
  • "Based on current data, we can’t attribute the IHS deflection variation to any specific vendor or socket mechanism. However, we are investigating any potential issues alongside our partners and customers, and we will provide further guidance on relevant solutions as appropriate." - Intel Spokesperson to Tom's Hardware.
  • Some users report reduced thermal transfer from the deflection issue, which makes sense as it clearly impacts the ability of the IHS to mate with the cooler. Would Intel RMA the chip if the mating was poor enough to lead to thermal throttling?
  • "Minor IHS deflection is expected and does not cause the processor to run outside of specifications or prevent the processor from meeting published frequencies under the proper operating conditions. We recommend users who observe any functional issues with their processors to contact Intel Customer Service." - Intel Spokesperson to Tom's Hardware.
  • The chip deflection issue also impacts motherboards – as a result of the deflection on the chip, the socket ends up bending the rear of the socket, and thus the motherboard. This raises the possibility of damage to the traces running through the motherboard PCB, etc. Is this condition also within spec?
  • "When there’s backplate bending occurring on the motherboard, the warping is being caused by the mechanical load being placed on the motherboard to make electrical contact between the CPU and the socket. There’s no direct correlation between IHS deflection and backplate bending, other than they can both be caused by the mechanical socket loading." - Intel Spokesperson to Tom's Hardware.
TLDR: as long as the chip runs base speeds and doesn't thermal trip, its still within specs. . . i guess.
1,978 (1.48/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
aka Intel doesn't give a shit and they are fine with bent boards, since they can shit blame to board OEMs
freeagent
8,985 (3.91/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
1,065 (0.29/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
that looks much better than the washer mod neowin warned about:
For those wondering if there's any unofficial workaround for the problem, there does exist a washer mod which has been tested by Igor'sLAB. However Intel has cautioned that, such modifications, among others, will void your warranty.
578 (0.34/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
Ahh xxxx here we go again (last time it was skylake afaik). There is always gonna be some bending, afterall you are mouning the cooler to the board, and you want it to sit tight.
42,781 (6.69/day)
Some tension is good, but too much cracks traces and distorts pins. I remember the Socket A shim
2,100 (0.48/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
509 (0.25/day)
Processor AMD Ryzen 7 5700X3D
Motherboard AsRock B550M Pro4
Cooling Arctic Freezer 34 Esports One
Memory 32GB (4x8) Team Group DDR4 3600 CL18
Video Card(s) ELSA RX5700XT w/ 2x Arctic P12 MAX fans
Storage Sabrent Rocket Q 1tb NVME 3.0
Display(s) Dual Monitors: 27in Sceptre 1440p 165hz IPS (Main) + 27in MSI 1080p 144hz (Left) on monitor arms
Case I don't want to talk about it
Audio Device(s) Logitech X530 5.1 Spearkers + Sennheiser HD58X Jubilee
Power Supply Corsair HX850i 80+ Platinum
Keyboard Leopold FC750R Cherry MX Brown
Software Microsoft Windows 10 Professional x64
Socket a coolers themselves were hard enough to install. Some barely had any lip for a screwdriver to slide into when installing the cooler as well.
12,024 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Does Intel make their own branded mobos anymore? Not for this socket. So either they knew of the issue and decided to sit this one out for some reason or they just haven’t had the time or resources…..
Sounds like a lot of pass the buck to me.
21,572 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
They have not made consumer boards for some time...
qubit
Overclocked quantum bit
17,865 (2.87/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Socket A shim was a sham. Totally unnecessary.
Just use some care when installing the cooler.
Yup, I remember trying that out at the time. Hardly any CPU contact with the cooler overheated it massively. Shim went in the bin straight away after that.
1,978 (1.48/day)
Lithuania
System Name Shizuka
Aka they spend as little as possible on RnD and try to dodge as many problems as they can by shifting blame.
