iPad Air 11 inch M2 128gb
534 (0.08/day)
West Bend, Wisconsin
System Name DELL Inspiron 5400 AIO / HP 17 ca1065cl
Processor 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz / Ryzen 5 3500u
Memory 16GB /12GB
Video Card(s) NVIDIA MX 330 / Radeon Vega 8
Storage 1TB +SSD
Display(s) 23.8 inch touch screen 17.3 touch screen
Case DELL AIO / HP LAPTOP
Mouse Dell Wireless /LOGITECH
Keyboard Dell Wireless / HP LAPTOP
Software WINDOWS 11
Hi there everyone. It’s been a while since l last posted on here. I just recently got a new iPad Air 11 inch. And I also have a  WATCH se 2nd gen now.
27 (0.27/day)
New Jersey, United States
System Name Dumpster PC MAX Edition
Processor AMD Ryzen 7 5700X3D
Motherboard ASRock B550 Phantom Gaming 4/ac
Cooling AMD Wraith Spire Stock Cooler
Memory Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz C16
Video Card(s) NVIDIA RTX 3070 Founder's Edition
Storage Crucial 2.5" SATA 1TB + Samsung 990 EVO 1TB + ADATA SU750 1TB
Display(s) Acer EK271U Ebiip 27" 2K QHD (2560 x 1440) 100Hz LED
Case Fractal Design North (Black)
Audio Device(s) AirPods Pro 2nd Generation
Power Supply Thermaltake Smart 600W
Mouse E-Waste Dell Mouse
Keyboard Keychron K10 Pro
Software Windows 11 (Latest Release)
Sweet. How's the new iPad been working out for you? I have an M1 iPad Air, so I'd have to upgrade to an iPad Pro if I want a real difference, lmao.
2,899 (4.74/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
Never used iPads since iPad 2. iOS and iPad OS, unfortunately, don't support the only reasonable Telegram app so I don't consider them. How does this bad boy fare by the way?
27 (0.27/day)
Know your question probably wasn't directed at me, but I'll answer anyways since I have nothing better to do RN, lmao. My M1 iPad Air has been more than sufficient for most of my needs. I mainly use it to play mobile games on the side while I do other things on my laptop/PC, and the M1 SoC is plenty for that. I like the iPad so much that I've considered switching to one full-time in place of my laptop, though that's not necessarily the best idea since I'm a computer science student and have heard that coding is a huge pain on an iPad. Also, if I were to switch to an iPad, I'd have to get a better keyboard for it, which would be an extra expense. I'd be able to sell my laptop, though, which would make up for that expense and then some...
If you couldn't tell, I'm thinking out loud here.
560 (0.11/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
while the iPad is a great machine, it is not quite a laptop… yes you can replace a laptop, but it is best to just get an apple laptop, instead of an iPad mainly because on the laptop easy to open many windows and run “any” software. i am not knocking the iPad i use one all the time to surf the web…
an M1 cpu in it, will last forever.
will not need to replace it, unless you get tired if it… the iPad pro won’t get “tired”
on a M series iPad, IMO anything written for a m4 will work on a m1. and the M1 iPad have 8G ram …)
i have a iPad pro 9.7. (a9x) and it is really slow.)
i want the new iPad air with the m2, but don’t have the money for it… and the m4 one, at almost double is kinda out of reach
3,460 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.8.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2033), upgraded from Win10 to Win11 on Feb 2024
Got an iPad Pro 2021 (M1) 11" 128GB about 2.5years ago.
Primarily used for gaming, and also videos and some browsing.
Doesn't show any signs of tiredness running things, battery still going good.
I dont see replacing it any time soon.
Its my 3rd iPad after Mini2 7.9" and a entry level 2018 9.7"
I'm considering never buying anything else again than a Pro
