is a 700 Watt Power supply good or okay for a RTX 4070 Super and an AMD R7 8700f
Tazkari
1 (0.11/day)
I bought a PC, and I changed from 600 Watt to 700 Watt, but I don't know if 700 Watt is good for the PC. My other specs are
MSI-B650M-P
32 GB DDR5-RAM, Dual Channel (2x 16 GB), 5600 MHz*, Kingston Fury Beast
1000 GB M.2 PCIe 4.0 SSD Kingston NV3
700 Watt BoostBoxx Power Boost, ATX2.53, 92% Efficience, 80 Plus Gold zertified (I don't know much about the Power supply but it was cheap)
I don't know if its necessary but i got a Deepcool Gammaxx C40 Processor fan
Toothless
Tech, Games, and TPU!
9,634 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Yes if it was a known quality brand like Corsair or Seasonic
FreedomEclipse
~Technological Technocrat~
24,128 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
If it was cheap. Its probably terrible.
I can find it for 70 Euro which tells me its probably a mid-range 700W unit which seems OK. Not heard of the brand before so I personally wouldnt trust it but thats just me.
332 (2.89/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Should really get a better PSU. Should have an atx 3.0 or 3.1 for rtx 4000 series, and from a reputable brand. BoostBox is questionable at best.
55 (0.52/day)
Shanghai
System Name UESTC_404
Processor AMD R9 7950x3d
Motherboard Gigabyte B650E Aorus Elite X Ax Ice
Cooling Deepcool AG620 digital
Memory Asgard ValkyrieII 6800c34->6400 16g*2
Video Card(s) Yeston 7900xt SAKURA SUGAR
Storage Zhitai TiPlus7100 1T
Case RANDOMLY PICKED TRASHBIN
Power Supply Thermalright TGFX850W
DONT BY ANY TERRIBLE PSU OR YOU WILL BE BLOWN UP FOR THIS BOMB
3,543 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2454), upgraded from Win10 to Win11 on Jan 2024
MSI-B650M-P
Why the PSU change? (curious)
This PC can be powered easily with a 550~600W PSU.
If the budget is limited its better to go with lower watt but a known quality one instead of a bigger but unknown, potentially inferior PSU.
PSUs are the heart of PCs
332 (2.89/day)
Texas, USA
1,402 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
you can look at what my specs are which are bit more higher on power draw then what you have and under load with a 4070 super is only around 400-450watts of load. granted i have a little bit under volting on my 4070 super but you would still be under that.
162 (1.21/day)
Processor AMD Ryzen 7 5700X
Motherboard ASUS ROG Strix B550-F Gaming Wifi II
Cooling Noctua NH-U12S Redux
Memory 4x8G Teamgroup Vulcan Z DDR4; 3600MHz @ CL18
Video Card(s) MSI Ventus 2X GeForce RTX 3060 12GB
Storage WD_Black SN770, Leven JPS600, Toshiba DT01ACA
Display(s) Samsung ViewFinity S6
Case Fractal Design Pop Air TG
Power Supply Corsair CX750M
Mouse Corsair Harpoon RGB
Keyboard Keychron C2 Pro
VR HMD Valve Index
Shell looks the same as an MSI MAG A-GL box (picture below), probably skimmed down to non-modular to save on price. Internals are probably similar if it's the same factory. Should get the job done.
610 (1.77/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
Brand doesn't matter. Check the rail ratings. This is yet another stupid minutiae.
We rate power supplies by wattage output which is the entire point.
Nobody changes out power supplies very often. Myself included. Last one was 15 years ago.
We use these flat ratings of 600/750/850/etc to quickly compare this and that and there's a LOT of junk getting sold today.
How? Critically important designs change over time, like that ATX 3.0/3.1 cert and completely insane 12VHPWR connector.
Will it burn the house down? We don't know but so far ANY search of 12VHPWR nets this instant image result:
So...Yeah. My semi-modular 2009 era Antec EA-750 has a split rail design that tops out at a grand total of 25A.
The other day I chose this thing. 1KW rating, fully modular, tons of PCI-E cables and a pair of high current 12V rails that top out at 83A.
I'm good for the next few generations of accelerators or until my completely insane overclocking demonstrations get the better of it.
Other than that, pick a supply that has good length and strength cables, a pleasant no/low noise and you're solid.
Your 58A rail might be a valid contender for now with whatever you decide to run next but we will all eventually come back to this issue.
