Is dual tower always better?
101 (0.30/day)
I would like to know if dual tower coolers are always better than single tower?
I see some review that says Arctic Freezer 36 is just as good as Noctua D15.
18,455 (2.72/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
Also check the diameter and amount of heatpipes used.
My single tower Noctua NH-U12A is a 120mm cooler but with 7 heatpipes and 2 fans.
4,199 (0.87/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
way too generic of a question, as @P4-630 stated fans, heat pipes, how well the tower is built and tower specs all play a role
10,368 (1.70/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
the best 2 aircoolers are dual tower, so if you're getting one of those than yes it's better
Frick
Fishfaced Nincompoop
19,077 (2.83/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
346 (0.08/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB + 2 x Kingston NV2 2TB
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Generic
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun Software programs just have to run nicely....
All above is thru, but with these aspects in mind, the bigger the heat dissipiating surface is (cooling fins), the more efficient (not better) a air cooler can function. So, yeah a dual tower has more fin surface to dissipiate heat to the air so in theory it should be more efficient as a single tower cooler (but only if all other specs are the same).
Regarding the question in the title; for example, a well build single tower cooler can perform better than a poorly build dual tower model.
Best is to know how much heat you want to dissipiate (which CPU and OC or not) and check the reviews to be able to that cooling capacity than you should be OK.
Depends on how much they cost where you live, what case and other cooling you have and what you're planning to cool. Between those two I'd go for whichever is the cheapest.
As above, this is unique for every situation; available budget, does it fit in your case, noise levels, are the 'looks' are important? and so on.
As long as you just make sure the cooling capacity is suited for what you are going to cool.
It takes some research, but sometimes it's all about the journey, not the destination.
Have fun.
4,199 (0.87/day)
assuming the glacier black performs the same as the glacier rgb (they look identical and have identical specs) than the glacial black is the better cooler
It's a basic budget cooler, it may do the job depending on your needs but it's not as good as the Noctua D15
silentbogo
5,497 (1.41/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
They are not "better" per-se, they just have space for 3 fans to push more air through. With a decent-enough single-tower, more case fans and enough airflow you can do just as good as D15. Heck, my old Thermalright Ultra 120 did miracles on my ancient LGA1366 rig. I think it was able to cool around 300W of heat when I was going for my 4.7+GHz runs of Cinebench and 5GHz OC just for fun and bragging screens.
But under normal circumstances - yes, I'd likely go for Glacier Black as well.
#22
359 (0.75/day)
Warszawa
Cooler performance is mostly about fans, so there exist dual towers being worse than some single tower. That's why if we want to form some universal rules, let's talk about the best ones - it only makes sense.
Dual tower coolers with two fans tend to be the best. They are the most powerful, but also the lower you normalize the noise, the more they tend to win cooling wise, especially bigger ones. If we talk the best ones on the market, these tendencies transform into facts. One exception are dual tower coolers with only one fan and here it depends. E.g. Noctua D15S performs totally similar to U14S being like half of that - no matter if we talk low noise or high wattages, whatever man would trow this pair into, they will score similarly.
101 (0.30/day)
Depends on how much they cost where you live, what case and other cooling you have and what you're planning to cool. Between those two I'd probably go for whichever is the cheapest.
Gelid costs like 24 euro and Arctic 28 euro. Phanteks P400A case with two P14 intake and one P12 exhaust, It will be used on a Ryzen 5 5600.
572 (0.64/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
Single tower coolers are more than enough for that cpu. The stock cooler is basically enough for that cpu. Since it is the non-X version.
