Is Edge browser flashing/flickering periodically for you on win11?
276 (0.09/day)
I have the latest version of win11 and edge installed and on youtube and other sites edge browser will flash itermittently.
Does this happen to any of you all out there?
I have repaired Edge but yet on certain websites I get flickering and flashing in it.
Anyone else?
Based on Chromium, edge and chrome have both done it for me from time to time. You can try disabling hardware acceleration in the browser's settings and see if that helps. Otherwise, I would advise testing your system RAM and GPU stability.
Yeah my ram and gpu are fine. Not sure what is causing this. Disabling hardware acceleration seemed to fix the problem. Thanks.
You need to make sure it is actually Edge and not your entire display. Make sure the Edge window is NOT maximized. That is, make sure you can see other objects on the desktop besides the Edge window. Then pay attention and see if you can notice what happens next time it flashes. If the other objects and desktop background flash too, it is not an Edge problem.
The desktop is NOT flashing. It is contained within edge. I have been watching this problem for awhile now. This didn't happen on my old install on win11. Maybe it's a 24H2 issue. I have no idea but the flashing is without question contained within edge and the desktop doesn't flash at all. Disabling gpu acceleration fixed the issue. I just did it and have been testing for 15 min. No more issue.
Well, not sure 15 minutes is long enough to determine the problem is fixed (unless it was previously happening pretty much all the time). Regardless I am glad it seems to be fixed and thanks for the update.
Reinstalled win11 fresh and the problem is gone. I can use graphics acceleration in edge now with no issues.
Thanks.
If reinstalling fixed it, maybe next time, if it happens again, try sfc /scannow from an elevated command prompt first, instead of going through the ordeal of a fresh install. These days (beginning with W7) the actual need to do a fresh install is extremely rare. Reinstalling should be a last ditch effort.
I have found if a simply reboot does not fix the issue, then just waiting it out works most often to resolve issues. This is because, unless an actual hardware fault/failure, it is highly unlikely I am the only one with the problem. And in that case, it is very likely Microsoft will soon release an update to address it.
And on the rare occasion a system file becomes corrupt, running System File Checker (SFC) will typically fix that too. I have 5 systems here and have not needed to do a fresh install since migrating them all to W10. And with the 2 that have W11, no need to reinstall with them either.
Microsoft has not been sitting on their thumbs since the early days of Windows when "format and reinstall" was almost a periodic, routing requirement. Windows, particularly W10 and W11 are very good at self-healing, if given time.
But of course, if it is an actual hardware fault, no update or re-install will help.
Another observation I have made over the years is this; the more users dink and change the default settings, the more issues they have that do require last ditch efforts to resolve. :( I am just saying, in addition to self-healing, W10 and W11 are very good at keeping themselves secure and running optimally too.
