Is it normal for my ssd to be at 99% health?
21 (0.02/day)
Processor R5 5600x
Motherboard asus B550-f gaming (wifi)
Cooling arctic freezer II 280mm
Memory 2x8gb corsair vengeance 3600mhz
Video Card(s) gigabyte rtx 3070 gaming oc
Storage WD Blue SN550 1TB M.2 SSD
Display(s) AOC 24G2AE/BK 24" 144Hz
Case Lian li 011 air mini
Power Supply 750w gold v2 cooler master ATX
Mouse razer naga trinity
VR HMD Oculus quest 2
I built my pc a year ago but i had to reinstall windows fresh from a usb drive because my other installation of windows stopped working after a reset.
Should i be worried about this percentage?
21,662 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Yes, normal, that is just the measured warranty endurance counting down. Your health is otherwise perfect, nothing to worry about.
21 (0.02/day)
Processor R5 5600x
Ok, But why do all the videos on youtube make it sound like a big deal?
21,662 (3.40/day)
Olympia, WA
System Name Pioneer
It would be a big deal if it was an HDD or any stat other than Percentage used ticking up, but honestly theres nothing of note there in your screenshot.
Easy solution ~ don't watch them :toast:
You should watch them but understand what they mean, IMO. The smart counter on ssds is really more of a wear level counter.
1,395 (0.81/day)
Wear and usage will do that, though interesting there are the "unsafe shutdowns" - do you ever turn your computer off by holding the power button?
21 (0.02/day)
Processor R5 5600x
Ok, Thanks a lot
Yes, Is this bad for the pc itself or only the software if so... please explain why. thanks
1,395 (0.81/day)
Ahh, you really should not do that. The problem is that all the content from RAM or disk caches cannot be written if you turn your computer off so abruptly; it can/and has as it would appear also break your windows installation, so you had to reinstall.
If nothing else so much work for not shutting down those few seconds longer....seems unnecessary.
21 (0.02/day)
Processor R5 5600x
Thanks, could the reason for the percentage decrease on my disk info be the reinstall by any chance?
2,981 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
everything is fine as long as ID 01 and 0E shows a Zero.
21,662 (3.40/day)
Olympia, WA
System Name Pioneer
No, the unsafe shutdowns don't factor into the final health percentage. But it's still advisable to shut down properly.
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
Having data on a ssd does this
It's normal hell I have 5 year old ssd's showing 99%
Shut down is easy Winkey-x type uu for power and shut down.
I agree stop watching youtube :laugh:
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
I've had my SSD as a boot drive for 8 years now and used daily for many hours at a time, shows 94% in both CrystalDiskInfo and Hard Disk Sentinel and works just fine. Don't worry about it.
I'm surprised that there aren't any unsafe shutdowns though, because the PC has crashed quite a few times in the last 8 years (lockups and BSODs) especially when I had that bad RAM stick in it, forcing me to hit the reset button or the power switch when even that didn't work.
43,384 (6.75/day)
Use the tools by WD to monitor it
W1zzard
Administrator
28,130 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Your drive has an endurance of 600 TBW lifetime writes, you've written 16.5 TB so far, so 100/600*16.5 = 2.75%, so 99% is actually better than the 97% suggested by that calculation, and it's still A LOT of lifetime left.
AsRock
TPU addict
19,158 (2.98/day)
UK\USA
And more likely some thing else will fail before.
886 (0.64/day)
Ok, Thanks a lot
*facepalm*
You never do a hard reboot unless the system becomes stuck/unresponsive in such a way that you're unable to safely shut it down or restart it using the taskbar option. Even then, you should give it time to sort itself out if possible. Every time your system crashes or is forcibly shut down in the manner that you've been doing runs the risk of causing files to become corrupt. This can manifest itself in a variety of ways ranging from the operating system not being able to boot up properly to one or more hardware components not functioning.
Even forcing a problematic application to close can corrupt it's files. Whether its rebooting the OS or restarting a program, you always want to properly shut it down from within the software. Otherwise, you may find yourself re-intsalling everything more often than you like.
qubit
17,865 (2.85/day)
Quantum Well UK
Keyboard Yes
*facepalm*
Yes, quite. I've had situations where Windows was stuck for many minutes trying to sort itself out, or taking an age to start up or shut down. In almost every case that patience paid off with Windows eventually sorting itself out, no forced hardware reset required.
btw, a momentary press of the power switch triggers the same shutdown process as the Start menu shutdown and is that little bit quicker to do if it's within easy reach. I use it often.
886 (0.64/day)
Yeah, like in cases where I thought something might have gone wrong with a windows update that was seemingly taking forever to finish.
I'm not sure how that shutdown process works and never tried it myself. I close any programs I have running before shutting down, so a few extra mouse clicks on the taskbar is easier than reaching over 3 ft and pressing the tower button. I know on my old alienware laptop, holding the power button in seemed to do something similar.
qubit
17,865 (2.85/day)
Quantum Well UK
Keyboard Yes
Yeah, it's good practice to shut down the apps first, or it can get stuck on a prompt or something.
1,131 (0.81/day)
Bavaria ⌬ Germany
System Name ✨ Lenovo M75q-1 [Tiny]
Display(s) DELL S2722DGM
Software Windows 11 Pro (Debloated)
Welp, that's most likely the reason why your Windows installation was damaged. ;) Use the power & reset button only if everything fails.
Btw. there are solutions to fix a broken installation without the pain of a fresh install:
1,755 (1.16/day)
ID # 235 Power Recovery Count
A count of the number of sudden power off cases. If there is a sudden power off, the firmware must
recover all of the mapping and user data during the next power on. This is a count of the number of
times this has happened.
Just remember the threshold is a lower limit. In the case of POR Recovery Count it is zero,
therefor the closer the Current Value gets to zero the closer the drive is to failing. The Current
Value for Samsung solid state drives decreases from 100 or 200 to their respective lower limits.
The Raw Data is the count of actual events.
571 (0.29/day)
OP, a lot of good things have already been said. One thing I’ll add is that literally none of the above are things I pay attention to since even with only a minimal backup setup, a drive failure is more of an inconvenience that anything. One of my daily drives is more than 12 years old. So all that to say, get your backup situation sorted. An SSD can go from fine to irrecoverable brick in a moment.
1,755 (1.16/day)
That's what happened to me with my corsair MX500 256GiB NVME SATA SSD. It soured me greatly on SSD's and none of the data was recoverable.
