Is it OK to have some air bubbles in your water cooler pump ?
62 (0.02/day)
System Name Crash
Processor i7 7700k
Motherboard Asus strix z270E
Cooling Arctic freezer 360
Memory T force 16gb 3200mhz (8x2)
Video Card(s) Sapphire Nitro+ RX 580 8gb SE
Storage Samsung 850 evo 500gb
Display(s) Dell se2717h
Case Phanteks luxe tempered glass
Power Supply Corsair RM 650x
Software Windows 10 pro
hi
i have some air on my aio pump and its making a rather annoying ratling noise
is that bad for the pump ?
is there a way to remove the air from AIO PUMP ?
my cpu cooler is ARCTIC FREEZER 360
there a video for the noise test :
OneMoar
There is Always Moar
8,794 (1.65/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
with sealed AIO units there isn't really a good way the air has no way to escape
also older aio might be getting low on fluid
may be time to cut the lines off add a res and refill it
the res needs to be the highest point in the system to give the air someplace to go
I would cut the lines at the block/pump head/drain it, tie a reservoir into the system and seal it all back up with good clamps or maybe some epoxy/pvc cement if you are paranoid
sneekypeet
not-so supermod
29,547 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
You could try to "roll" the chassis to try to let air out of the head unit, which should then get trapped in the radiator. Although, with the way you have it installed, it should do this naturally! The real question for me is how can you tell it is air in the head unit rather than a bad impeller making that noise.
I would say this. Air in a head unit will reduce the thermal ability of the head unit, IE temperatures should be increasing if it is air. As to OneMoar's point, even if it were "low on fluid" the head unit is the lowest point, so for that to ring true the loop would have to be near empty, and again temperatures would show this too.
If you do not have any software to watch the pump speed I would sit in BIOS for a bit and see what happens with the RPMs of the unit. If you are seeing vast fluctuations in speed, it would point to the impeller dragging inside of the head unit.
If none of this is helpful, and you have recently purchased this cooler, I would contact ARCTIC and see if they have any helpful hints or offer an RMA!
62 (0.02/day)
System Name Crash
Processor i7 7700k
i tried roll and tilt the chassis but the noise became worse
thats the temperatures on LOAD
and the pump speed on 100%
1,486 (0.32/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
I have to agree with @sneekypeet it sounds more like the pump going bad or an impeller dragging, air trapped in a system normally is more of a gurgling sound than what I heard on your video. May be time to find a new AIO or rma
303 (0.11/day)
SoCal
System Name unnamed currently :*(
Processor Intel Core i7-5960x
Motherboard ASUS ROG RAMPAGE V EDITION 10
Cooling EKWB/Bitspower CPU, motherboard & GPU WB
Memory Corsair Dominator Platinum 4x4gb ddr4 2666
Video Card(s) nVidia GTX 1080 Ti FE 11GB
Storage Samsung 960 Evo 1 TB M.2 SSD & WD Black 5TB HDD
Display(s) Asus SwiftROG PG278Q & Asus PB277Q
Case Corsair 900D
Audio Device(s) Sound Blaster Zx
Power Supply Corsair Axi1200
Mouse Steel Series Sensei RAW
Benchmark Scores 4.8 ghz @ 1.37 - 5930k - old cpu 4.6 GHZ @ 1.3 - 5960X - current cpu
How old is the cooler? I do not recommend cutting an AIO cooler.
I'd use this as the perfect excuse to get a new AIO :rockout: :toast:
62 (0.02/day)
System Name Crash
Processor i7 7700k
8 months
41,897 (6.61/day)
I say either get a new AI o or build a custom Loop
I have to agree with @sneekypeet it sounds more like the pump going bad or an impeller dragging air trapped in a system normally is more of a gurgling sound than what I heard on your video. May be time to find a new AIO or rma
Sounds like a cheap aio, RMA it run air for time being
303 (0.11/day)
SoCal
Case Corsair 900D
Use a stock cooler for now, and submit a RMA to Arctic and send in. Warranty is good for 2 years. Sorry to hear your troubles. I've used Corsair AIO back in 2012-2014, and never had a problem.
IMO, I'd sell the arctic on Ebay or something and just get a new one. I've had bad experiences in the past with RMA's coming back and still having problems
As Eidairaman1 says, you can also go custom but you're looking at several hundreds of dollars. EKWB has a nice configuration tool to show you what you need.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Next question is... how long has it been making that noise?
In my experience with a custom loop, MCP655 pump, EK Res and 320 Radiator, air would be audible, but they sound wasn't quite as "grindy" as what i hear in your video. And for me, it would only happen for a few minutes after maintenance, while the Res had time to capture the bubbles. You could literally watch bubble moving in the tubes and entering the Res while it was purging.
I looked on the Arctic site, couldn't find anything about maintenance, filling purging etc. in manuals
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
this happened with the current Kreij memorial giveaway PC build i have recently finished. if it is layed on its side, etc, it makes a "gurgling" sound for a short time, until the bubbles are worked out through the pump. ive never had it happen so pronounced before, but its temps remained fine, and it stopped about 10 seconds after turning on.
OneMoar
8,794 (1.65/day)
Rochester area
I have heard air in pumps make some hideous sounds
had a water pump that sounded like metal on metal despite the pump being entirely plastic it was so bad
if its cooling adequately fawk it it will be fine
669 (0.23/day)
System Name Unimatrix
Processor Intel i9-9900K @ 5.0GHz
Motherboard ASRock x390 Taichi Ultimate
Cooling Custom Loop
Memory 32GB GSkill TridentZ RGB DDR4 @ 3400MHz 14-14-14-32
Video Card(s) EVGA 2080 with Heatkiller Water Block
Storage 2x Samsung 960 Pro 512GB M.2 SSD in RAID 0, 1x WD Blue 1TB M.2 SSD
Display(s) Alienware 34" Ultrawide 3440x1440
Case CoolerMaster P500M Mesh
Keyboard Corsair K75
Benchmark Scores Really Really High
Why would there be air in an AIO?... It's sealed. That video doesn't show that it has air. You have other issues and it's not air.
OneMoar
8,794 (1.65/day)
Rochester area
because no system is 100% sealed and water like anything else breaks down overtime
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
ive gotten air bubbles b4 in an AIO. if you shake an AIO , it can cause bubbles to form. if you have a sealed water bottle, and shake it, tiny bubbles form, id guess its similar. but i understand your reasoning.
10,690 (1.72/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.5GHZ 1.285v - 235W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
AIO's have air in them, they have space to deal with that as well... they also evaporate a bit over time...
the way that you have it mounted should allow the air to settle at the top and not cause any issues though.
3,622 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
That sounds like a failing bearing to me. If it got louder when you rolled the chassis it is likely from the centripetal force on the failing bearing...or it could have gunk/debris (likely chunks of bearing) in the bearing housing.
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
In The video it's kind a hard to hear the sound that the pump is making , theres so much hum from the fans and other white noise. Is it possible to disable your fans and just let the pump run by itself ,so we can hear it on its own?
As the video is now, I agree it sounds less like air bubbles and more like something else, but I've had air bubbles that sound kind of "funky" too, so I'd love to hear it and a more pure form
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
@OP
Have you been monitoring temps? This would tell you weather its a bad pump or just air, air will find a settling place. Also sealed units evaperate
43,602 (6.52/day)
Motherboard ASUS TUF x670e
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
62 (0.02/day)
System Name Crash
Processor i7 7700k
@OP
i get 18 C on idle and on load 19-20 C
with prime95 v294b5 i get 65 C max with small FFTs
my cpu is i7 7700k on 4.5ghz not delidding
The noise began two weeks ago
Today I rolled the chassis and the noise stopped completely, but after two minutes the noise returned
8,085 (1.35/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
You can save a lot of money by buying one of their kits. Best way to go when starting with custom water cooling.
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
Regardless of the source of the sound, I've never had a problem contacting manufacturers( while pump is still under warranty ) & telling them it's making the sound , they should offer you either an advanced RMA or a standard RMA.
It's better to be safe than sorry ,and wake up one morning and find water in your build, or have the pump fail
