Is it worth overclocking graphics cards?
Do you think it's worth overclocking graphics cards?
  • Total voters
    92
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Looking at reviews, articles and forum posts on TPU and elsewhere, graphics cards from the last few years seem to be engineered to hardly overclock at all. They give minimal performance gains, if any, and possibly at the cost of greatly increased power consumption and heat, therefore, do you think it's worth going through the time, effort and sometimes risk, of overclocking the card?
226 (0.05/day)
System Name Mixed Bag of OC
Processor AMD Ryzen 5800X3D
Motherboard Maxsun MS-iCraft B550M WIFI
Cooling CPU+GPU on Water with 3 X 420 Rad´s
Memory 32GB Patriot Viper RGB @ 3800 Mhz CL14
Video Card(s) XFX Merc 310 RX 7900 XTX
Storage 2TB Kingston Fury + 2TB Samsung PCIe 4 NVME
Display(s) Philips 48OLED806
Case Selfmade Huuuuuge *Case* :)
Audio Device(s) ifi Zen DAC + Monoprice M1060C & Burmester Replica AMP + Selfmade Huuuuuge Speakers :)
Power Supply Seasonic PRIME TX-750
Mouse Kensington Slimblade (main device) + Razer Basilisk V3 (for FPS)
Keyboard Sharkoon PureWriter RGB, Kailh Blue switches
VR HMD None
Benchmark Scores do not matter, my PC is fast :)
For my part, i only Overclock in the sense of Undervolting while also slightly raising the clocks so i get more efficency out of the GPU
2,450 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
overclocking these days not so much, now undervolting is where the real gains are :)
where undervolting might not net you extra fps but you use less power while maintaining same fps and making your gpu runs slightly cooler
8,567 (1.81/day)
Ovronnaz, Wallis, Switzerland
VR HMD Medion Erazer
in my view, AIB already drive to the utmost limits GPU that are already really close to these aforementioned limits when released by AMD and Nvidia
in the recent years, AIB models have little to no extra Oomph over a reference/foolers edition, tho they have better designs or cooling solutions which would be what i ask from a custom card, given the little potential OC yield nowadays, undervolting is indeed the new way of tinkering a GPU/CPU :laugh: (a bit sad tho, but i am glad i was born beginning of the 80s :laugh: good time good time ahah )
8,253 (1.17/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
maybe overclocking is a poor description.. fine tuning might be a better one.. doing something the manufacturers cant do..
trog
3,076 (0.82/day)
I voted others because I overclock, but mostly do it for fun and not running it for every day use. I oc for benchmark runs. Else the oc is only mostly giving small increases but for to much more wattage use. Specially in these inflation prices on electricity. I mostly undervolte and use power target to limit the cards power consumption so performance and power consumption fits for the current game used. There is no reason for to let my card use 380 watt if it can deliver enough performance for let's say 200 watt.
2,275 (0.97/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
nowa days na ,unless you're after beating a overclocking benchmark thingy but there mainly holded by commercial means overlockers who get the best of everything mostly for free so its very hard to compete for the average joe blogs.
2,023 (0.62/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Undervolt, and *downclock.
*I can live with up to -10% lower core frequency than stock (but, I expect 100% stability at this lower frequency - regardless of workload).
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
When you have this much (or more) headroom especially for the memory like my 1080 Ti has, why the hell not? Overclocked every card since GF2 MX.
8,567 (1.81/day)
that's relevant to the "last gen" that was worth OC ... my 1070 was OC'ed too (factory OC plus my own OC work, from a time where the AIB were doing mild OC and leaving quite a bit for the end user to play with) ... but gen past RTX 20X0 and RX 5X00 weren't that kind in term of headroom ... :D
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Well, looks that this year's "put your kidney on ebay" card has also some memory OC headroom, at least from TPU's review :D
8,567 (1.81/day)
that's not much nonetheless :laugh:
the OC induced gain is not that high compared to previous gens (10XX, RX 5XX and before)
and it does not perform better than lesser OC from AIB customs
end user OC is technically dead, outside "extreme **LOL**" overclocking competition (probably with highly binned chips, even tho the sponsored "pofessional **LOL**" overclocker will say otherwise ;) )
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
It was a thing, my Vega is one of the last cards worth touching though, I don't see much point on new cards due to boost algorithms.
3,621 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
Overclock (higher clocks at same voltage) + Undervolting (capping max voltage/clocks) = better gaming experience.
Ruru
S.T.A.R.S.
13,778 (3.05/day)
Jyväskylä, Finland
Sucks that TPU tests OC performance only with that ancient Heaven, hell, I remember running it with GTX 470 back in the day.
Outback Bronze
Super Moderator
2,196 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Razer
Keyboard Corsair
Software Win 11
Voted no. Casual gamer here. Prob not even that these days : (
ARF
4,677 (2.44/day)
Maybe there is a reason to use Heaven - as you can see despite being very old, it works with faster graphics and scales well.
To answer the question - No, of course not.
More reasonable is to undervolt and have cooler and quieter card with the same performance. As normal people should and would do..
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I undervolt with Afterburner, my 3060 was able to drop from 1.10V to 0.950V for same clocks, off the top of my head, the temperature under load is something like 20C lower and wattage 40 watts lower.
bug
14,337 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
This is not exactly how I see it.
In the past, power delivery was much simpler/crude. Because of silicone variance, different chips would clock very differently. Yet, in order to be able to offer a guarantee, manufacturers had to settle for the lowest sustainable frequencies, often leaving a lot of untapped performance on the table. And you could get that back by means of overclocking.
Over time, power delivery evolved significantly, so today little (if any) potential is left untapped. Everything scales dynamically until the silicon physically can't take any more. And that's a good thing: your shiny new GPU (or CPU, for that matter) is doing the best job it can do out of the box.
Sure, you can squeeze some extra juice if you really know what you're doing and you have something like an EVGA Kingpin (RIP), but for anything that's not a hardcore enthusiast, overclocking is effectively dead.
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
I have great thermals so in my case I don‘t see why not. That said I’m only using the AMD OC options available so its fairly limited but I’m able to max them out, undervolt, and still have great temps and get a fairly significant higher boost which does help.
15,675 (6.83/day)
Midlands, UK
Processor AMD Ryzen 7 7800X3D @ 45 W TDP Eco Mode
Case Corsair Crystal 280X
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
My opinion might not be the most popular one, but I think overclocking is and always has been overrated. If the performance difference isn't something that you feel without an FPS counter on screen, then why do it at all?
18,584 (2.63/day)
System Name AlderLake
For benchmarking perhaps, for gaming few extra fps , not so much...
bug
14,337 (3.95/day)
There were select few cards that had a lot of untapped potential. But that was years ago (remember the Radeon 9500?).
These days, you're just burning a lot more power for 5-10% more fps that do not translate into any improvement in gameplay.
Outback Bronze
Super Moderator
2,196 (0.44/day)
Walkabout Creek
Cooling w.c.
Case Corsair 460X
Mouse Razer
Keyboard Corsair
Software Win 11
