is my 3080 TUF OC a Golden Sample? (2160 Mhz while gaming)
  • Thread starter Deleted member 193596
  • Start date
so i have a 3080 TUF OC since around a week now and i am overclocking it every day (one 15 Mhz Bump every day after several hours of 1440p gaming)
i currently sit at +180 Mhz on the core which results in Cold boosts up to 2200 MHz with the stock fan curve.
my average Gaming Clock speed is 2145 MHz and it bumps up to 2160 Mhz.
In very demanding titles that are going to the max 352W non stop the card runs at around 2145 to 2160 Mhz.
btw the boost clock is 165 Mhz above the EVGA FTW3 Ultra
here is the clock speed at full power consumption and utilization 2145 to 2160 Mhz average.
3,050 (1.71/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 75C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (378W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSB 22631.3737)
You “measure” power draw by readings on HWiNFO?
Just curious... Does this sensor report the whole card (GPU+VRAM) or just the GPU?
I think that nVidia is not providing any info about VRAM other than clock. You may have to add another 30-40W for VRAM power draw on top of that 350W for total card power draw, given the fact that GDDR6X is more power “hungry” than GDDR6 which is around 25W max for a 8x1GB (14Gb, 1800MHz) VRAM configuration.
Very impressive clocks though... I was under the impression that 30series AIB cards have limited power draw, worst that the FE ones.
the 350W are board power of course.
in GPU Z the GPU pulls around 200W and the board power is 352W.
the 110% Powerlimit are the 352W.
3,050 (1.71/day)
Only 200W for GPU and the rest is 150W... it’s hard to believe.
May I see what short of sensors GPU-Z is reporting for the card?
I’m interested in such info.
that's completely normal for a 3080.
the memory alone pulls 70W
3,050 (1.71/day)
Screenshot of GPU-Z sensors?
3,050 (1.71/day)
Ok, I saw it now
2,207 (0.84/day)
btw the boost clock is 165 Mhz above the EVGA FTW3 Ultra View attachment 171613
here is the clock speed at full power consumption and utilization 2145 to 2160 Mhz average.View attachment 171615
Let's see your score with Superposition 1080P Extreme. ..Upload screenshot
Download Here https://benchmark.unigine.com/superposition
983 (0.21/day)
Memory 2x24gb Gskill 8800c38
Storage 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
Run time spy or port royal and see if it can hold the clock. If it holds, its very good.
wolf
Better Than Native
8,020 (1.28/day)
System Name MightyX
Processor Ryzen 5800X3D
Motherboard Gigabyte X570 I Aorus Pro WiFi
Cooling Scythe Fuma 2
Memory 32GB DDR4 3600 CL16
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Could be a golden sample, but I find my with 3080 TUF it really depends on what you have loaded the card with.
Could you spin up Quake RTX ? (first few levels are free), and a few heat soaked runs of timespy extreme? Those are the brutaliser tests. I have a feeling that after 10+ minutes of Quake RTX the clock will be a fair bit lower, but I could be wrong, would definitely show how much of a golden sample it is.
5,717 (0.96/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
RTX games is the real test. Fire up Metro exodus and play for a solid hour and report your clock
wolf
Better Than Native
8,020 (1.28/day)
System Name MightyX
VR HMD Meta Quest 3
Absolutely and more so even with non-RTX games, the older and 'lighter' they are, the higher the card can and will clock. I don't play either of the games he's shown screenshots for, but to my eyes it's wow and modern warfare?
i played battlefield V, Hitman 2, R6 Siege, NFS Heat and crysis remastered now.
in all games the clock speed hovers between 2125 and 2160 Mhz. except in Siege with everything maxed out..it runs at over 300FPS and the card drops down to 2085-2100 Mhz
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
My 3090 hit 2160mhz in bf5 but in time spy and port royal, it drops to stock clock. Cant hold it.
2,207 (0.84/day)
You & I ask the OP to do an benchmark test & has done neither test sofar. OP needs to show results, then we can judge if it's a golden chip.
ever heard of time zones?
i posted this at midnight, went to bed and i have a job.
i am home since a few hours and only replied in my lunch break.
here is a random time spy run
18,428 (2.72/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
When running this benchmark, run GPU-Z sensors in the background and post a screenshot of it afterwards a benchmark.
The GPU won't stay at maximum boost, you can try other benchmarks as well like superposition, heaven, valley or other.
983 (0.21/day)
Case Dynamic XL
Mouse Model O-
Only 1982mhz in time spy. Not that impressive.
wolf
Better Than Native
8,020 (1.28/day)
System Name MightyX
VR HMD Meta Quest 3
As said above - Average clock frequency 1,982 MHz - which aint bad but I don't think it's golden sample territory. Can you heat soak it and run Timespy Extreme specifically with your best clocks?
3,266 (1.16/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Ah why so harsh against OP, the fact that his 3080 can reach 2160Mhz means that the chip reach very high clocks.
Golden sample or good ASIC score means that the chip can reach high clocks, these chip tend to be leaky, meaning high power consumption for a given freq/voltage. These chip will do wonders when the PL is removed.
Vice versa a chip with low ASIC score tend to be less leaky for a given freq/voltage, so it might get higher Timespy score when locked to the same PL as high ASIC chip, but can't reach clocks above 2050mhz under no circumstance.
TL;DR OP has to shunt mod his card in order to get the most out of his 3080 :D
wolf
Better Than Native
8,020 (1.28/day)
System Name MightyX
VR HMD Meta Quest 3
Definitely not trying to be harsh, just trying to get a couple of things out of it, for one an apples to applies comparison against my own RTX3080 TUF.
The chip definitely can touch and potentially hold some very high clocks, but the 3080 is an interesting beast in the sense that, well, it is SUCH a beast and it takes a lot to load it to the maximum extent possible. Power draw / power limiting / holding boost clocks is wildly variable depending on, among other things, the workload. To really push into seeing what the GPU is capable of in terms of sustained boost clocks, you need to saturate it with the heaviest workloads imaginable. 4K with all the trimmings is one such avenue, and why I also recommend Quake RTX as it's fully path traced and will bring any RTX capable card to it's knees sustained clocks/power draw wise. It's more nuanced than any GPU I've ever owned before in this way and that for example two different games could show 99% GPU utilisation, but one pull 270w and another pull 350w of TDP when settings are a locked max clock/voltage, which is a bit different to OP using the core clock offset slider.
But at the end of the day I can appreciate that if these are the games OP plays, and he is getting 2100+ in those games, I mean that ain't bad by any means. My methodology is more to test and set profiles around my worst case scenario, rather than best case scenario. It does make me wonder however about my example of 270w vs 350w, if I take the game that only wants 270w from the card, I can probably tweak a profile with much higher clocks just for that game.
3,266 (1.16/day)
Software win11
The chip definitely can touch and potentially hold some very high clocks, but the 3080 is an interesting beast in the sense that, well, it is SUCH a beast and it takes a lot to load it to the maximum extent possible. Power draw / power limiting / holding boost clocks is wildly variable depending on, among other things, the workload. To really push into seeing that the GPU is capable of in terms of sustained boost clocks, you need to saturate it with the heaviest workloads imaginable. 4K with all the trimmings is one such avenue, and why I recommend Quake RTX as it's fully path traced and will bring any RTX capable card to it's knees sustained clocks/power draw wise. It's more nuanced than any GPU I've ever owned before in this way and that for example two different games could show 99% GPU utilisation, but one pull 270w and another pull 350w of TDP when settings a locked max clock/voltage, which is a bit different to OP using the core clock offset slider.
Actually the heaviest workload is not meant to test the ASIC of the card, it only test how far PL allows you to go :D. Meaning as you increase the PL, your scores improve accordingly.
OP's 3080 chip is definitely meant to go into the Strix OC version, which much higher PL so that it can stretch its legs better.
Think of it like this, for an average 3080, a 400W PL is enough for its maximum clock of 2050-2070mhz, however OP's can reach 2160mhz which requires 500W PL to sustain that clocks in all type of workload.
Nvidia was really clever to use Power Limit as the way to standardize performance, with Maxwell era and before, you could have chips that clock 100-200mhz apart, making performance between models wildly different. Vendors (EVGA specifically) was selling higher ASIC chip for way more money.
Now with a tight PL in place, higher or lower ASIC make little difference, they would generally end up around the same clocks under the same PL.
wolf
Better Than Native
8,020 (1.28/day)
System Name MightyX
VR HMD Meta Quest 3
Actually the heaviest workload is not meant to test the ASIC of the card, it only test how far PL allows you to go.
And this is more the angle/point I'm making anyway, given RTX3080's are held back by far the most by the PL, we try and maximise what we can get our of our silicone lottery 'win' within that ~375w PL, the lighter the workload the higher his clocks will be which can potentially give a false impression of an amazing ASIC quality.
The ASIC quality might be amazing, I'm not the judge of that, but in a normalised workload between our individual cards, restricted by an identical PL, It doesn't seem like it will hold clocks much higher. Golden sample? maybe, I suppose that's not my call to make, you seem pretty convinced. Unless he's willing to do hard mods like a shunt mod, we might not ever truly find out because the card can't draw an unlimited amount of power to see.
