lalalala44
- Jan 31, 2025
- 4 (2.00/day)
I wanted to get a little more power out of my laptop so I set the prochot offset to 15 in ThrottleStop (It is 25 by default/manufacturer). Doing that resulted in the temperature constantly being at 85 instead of 75 while gaming and of course more fps.
The problem is that after a couple of minutes I get lag spikes for 2-3 seconds and while that happens the temperature drops to about 67 degrees and then it rises again to 85 almost immediately. Then it repeats after a couple of minutes.
Is this even enough time to cool the CPU down to run again if it was throttling ?
Because another thing I noticed is that when I uncheck "prochot offset" in the settings and then go play again,
the temperature stays first at 85, then I get the exact same lag spikes with the exact same temperature drop to about 67 and then it rises to 75 degrees instead of 85.
So basically something resets the prochot offset at that point. (Prochot also gets set to 75 in TrottleStop)
Could it be that the prochot reset happens every couple of minutes causing lag spikes because the temperature is above 75 degrees ? But TrottleStop sets it back to 85 ?
Locking the prochot offset unfortunately didn't work and the lag spikes still happen. And checking only the "prochot offset" option is already enough to prevent the reset.
Unchecking BD prochot also didn't work.
My CPU is Intel i7 6600U with integrated GPU
