Is my GPU temps too high?
72 (0.01/day)
System Name Current
Processor AMD Ryzen 7 5800X3D
Motherboard Gigabyte Aorus X570 Elite
Cooling Full Waterloop
Memory 32Gb DDR4 3600 (4x8Gb)
Video Card(s) MSI RX6800XT Gaming X Trio 16Gb
Storage 2x SN850 1Tb & 1x Netac NV7000 2TB
Display(s) ASUS ROG Strix XG32V
Case NZXT H9 Flow
Audio Device(s) Dali Zensor 1 Speakers and Tangent Ampster BT II
Power Supply NZXT C850
Mouse G502 SE
Keyboard Currently: Monsgeek M1
Software Windows 11 64 Pro
Quick question for people who hopefully have more knowledge than me. I have a reference RTX4080 Super with a bykski waterblock, my hotspot temps hit nearly 70 degrees c and I am wondering if that is normal? I have seen RTX4090 under water with much lower temps with a waterblock (my old RX6800XT at a similar power limit also is cooler). I do think that this particular bykski block may have tolerance issues as in order to get temps under 70 i've had to use a 3mm thermal pad on top of the gpu chip using the back plate to apply pressure to make a better connecton with the main block. There is a couple of pics showing how the thermal compund spread out before I used a 3mm thermal pad to apply more pressure, all the thermal pads seem to make good contact tho.
Information on my card:
GPU is a Inno3D RTX4080 Super X3, it was returned to OCUK for not posting, at this time I had not touched it and it was still on stock cooling. It was sent back to me with no fault found, I decided when it came back to me to fit the waterblock. The card ran well with pretty decent temps for a couple of months until I noticed that the hotspot was slowly getting hotter and hit a max of 94+ degrees c before I decided to take the card out and apply new thermal compound, after that it would post but would crash trying to run any game. I panicked a bit and in removing it for the 3rd or 4th time I knocked off a capicator and damaged some traces (that was totally my fault) I brought it to a local electronics engineer and he was able to fix the broken trace and replace the capicator, but he also saw under the microscope that there was a cap/resistor that was cracked and shorting to earth (this was on the top of the gpu right above the core and I think may have been my original fault before I even put the waterblock on it), that was also replaced, the card has been working flawlessly since and even takes a bit of an overclock, but I am curious about temps.
Any help or info would be appreciated. Thanks in advance.
3 (1.50/day)
Cyprus
System Name MCH-PC
Processor i5-13600KF @ 5.5P/4.3E
Motherboard Gigabyte Z790 GAMING X AX
Cooling Corsair H115i
Memory 32GB DDR5 6400MTs
Video Card(s) Asus RTX4070 DUAL
Storage WD SN850X 2TB
Display(s) Odyssey G5 27" 1440p 144Hz
Case NZXT H5
Power Supply EVGA SuperNova G6 750W
70°C on the hotspot is fine and your thermal paste application and pads look good to me. Going forward I would suggest keeping an eye on it considering its... adventurous life.
