Is my video card too hot?
notagamer
5 (0.00/day)
System Name My second build
Processor Intel Pentium 4 541 Prescott 3.2GHz 1MB L2 Cache LGA 775 84W Single-Core Processor
Motherboard Foxconn 945P7AA-8EKRS2 LGA 775 Intel 945P
Cooling Thermaltake CL-P0220 100mm CPU Cooler
Memory 2 Kingston 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300)
Video Card(s) SAPPHIRE 100164L Radeon X1650PRO 256MB 128-bit GDDR3 PCI Express x16
Storage 3 sata
Case Thermaltake VC3000BWS Black Chassis
Audio Device(s) Creative Sound Blaster SB0570 Audigy SE 7.1
Power Supply AcBel API4PC23 500W ATX 12V v2.0/Intel EPS 12V v2.1 SLI Certified CrossFire Ready Active PFC Power
Software Windows XP Pro SP2
I found this site while trying to figure out what's causing my motherboard to beep while in Windows.
This is my video card:
Here's some pics of what various tools show for its temps:
This seems hot to me for just running the browser
Also, isn't the fan a bit slow?
Thanks for any help.
Fitseries3
Eleet Hardware Junkie
15,508 (2.52/day)
Republic of Texas
wow! thats too hot for sure.
install rivatuner and turn that fan up asap!
The_Real_DeaL31
692 (0.11/day)
canada
System Name Smooth as silk
Processor Phenom II x4 940 BE oced, 3.6ghz 1.5250v
Motherboard Asus M4A79 Deluxe 790FX
Cooling Cooler master v8
Memory OCZ 1066 MHz Platinum Series 4GB kit 5.5.5.15 2T 1141mhz
Video Card(s) Evga ssc 8800gt at stock p.o.s to hot to o.c
Storage Wd 76gb Raptor/Wd 500gb blue sata II, Wd 160gb sata II
Display(s) 20" Acer 2016wBdb widescreen 1600x1050
Case 120mm back/3x 80mm neon front/250mm side fan
Audio Device(s) realtek/logitech x540
Power Supply Corsair vx550 41amps 12v single rail
Software Winxp pro sp3/vista who lol?
Benchmark Scores 3dmark06 15216k
thats crazy i have a 1600pro, and its never got that hot
take your side panel off put your hand on top of the card in the middle where the core is, if it feels to hot to touch then its reading right, check to see if the fan is dirty or clogged. take your video card out, and blow in the pci-e slot, also look over the card itself, and see if the heatsink is making good contact with the core, is this card fairly new, did this problem just start now
Deusxmachina
526 (0.09/day)
Look up what the card is rated to run at. I doubt a wimpy 74 degrees is too hot. Something like a 2900xt doesn't even throttle itself until like 105, and it's rated for like 115. People get too excited.
Your motherboard manual may tell you what the beeps mean. Could be the CPU overheating, or the memory being funky, or whatever else.
The_Real_DeaL31
692 (0.11/day)
canada
still to hot, how come my 1600pro never broke 65c tops at load
3,527 (0.57/day)
UK
System Name Dream Weaver
Processor Ryzen 5600
Motherboard B450 MSI Gaming Pro Carbon AC
Cooling NH-D14
Memory 16GB Flare X @ 3200MHz CL14
Video Card(s) Sapphire Vega 64 Nitro+
Storage 500GB evo 970 m.2 + 4TB HDDs
Display(s) ASUS 27" 1440p 144hz FreeSync
Case Fractal Design Define R3
Power Supply Corsair 850W
Try removing the cooler cleaning the heatsink and fan, clean the old TIM off, re-apply thermal paste and bump fan speed up a bit via rivatuner (if you can be bothered, if not then just bump fan speed up using rivatuner)
notagamer
5 (0.00/day)
Storage 3 sata
Yeah I've had the side of the case off for awhile. The board beeps while it's in Windows, not during post so that's been hard to figure out. I have an enormous fan on top of the processor and would have to remove the motherboard from the case in order to re-apply thermal paste to the cpu and heatsink.
I disconnected everything and blew all the dust out from the case with a can of compressed air. It seemed to me there was a lot of heat wafting out of the case.
I used ATITool and set the fan to run at 45%. I'm still playing with Riva Tuner which says my driver is unsupported.
GPU temp is now 64c
GPU ambient is now 47c
Cpu temp 29c
I built this pc in January, 2007 so the card isn't new. Beeping's been going on for a couple of months. Bios is Phoenix/Award so it's hard to know which code to look up. Machine will do a single long beep once in a while, not everyday. I've tested the ram it it comes up as ok.
Thanks.
The_Real_DeaL31
692 (0.11/day)
canada
there look at, u should turn your fan speed higher
3,527 (0.57/day)
UK
Cooling NH-D14
GPU temp is now 64c
Cpu temp 29c
Thanks.
I meant to re-apply thermal paste to the video card, not the CPU. Should give you a nice temp drop because thermal paste dries up after a while and isn't as effective.
notagamer
5 (0.00/day)
Storage 3 sata
I didn't know you could do that to a video card! Where would it go, under the fan just like a processor? Would arctic silver be ok? :)
The_Real_DeaL31
692 (0.11/day)
canada
994 (0.15/day)
SoCal
Processor Intel C2D E6420 (3.2 gHz @ 1.365v)
Motherboard Gigabyte 965P-DS3
Cooling Zalman CNPS9500 LED
Memory 4 x 512mb Corsair XMS2 DDR2 667
Video Card(s) Visiontek HD 4870 512mb
Storage 200gb Maxtor SATA, 400gb WD SATA
Audio Device(s) Audigy 2 ZS
I'd go for Arctic Silver Ceramique just in case you accidentally get some on the PCB (remember, AS5 is slightly conductive). If you have a steady hand though, AS5 is fine (I've always used Arctic Silver 5 with no problems).
notagamer
5 (0.00/day)
Storage 3 sata
Yeah I found some links that say watch out for anything conductive.
I'll try some OCZ Freeze Extreme instead.
notagamer
5 (0.00/day)
Storage 3 sata
Ok, did the thermal paste on the video card and installed one of these:
http://www.thermaltakeusa.com/product/dcfan/Slot/a2426/a2426.asp
GPU temp is down to 59c from 74c, according to ATI Tool.
Everest reports 138F down from 163F.
I hope this puts a stop to the motherboard squawking.
Thanks for the help everybody.
