Is there any difference between 3200mhz with 2933mhz
lovegood
9 (0.01/day)
Hello
Please guide me about Ram Speed ,
Ryzen 3400g Support 2933mhz Correct ? But its seems Intel 10400 support 3200mhz
for some reason i want order Intel 10400 because its support 6 core and for video editing its better because have more core
Now only z490 motherboard support 3200mhz for Intel 10400 But z490 is expensive so i want order H410 And H410 support only 2933mhz
So please tell me is there many difference between 3200mhz and 2933mhz ? for example for video editing or rendering ?
because i want order cpu that have integrated graphics for budget
Thank you
Deleted member 202104
On any board other than a Z490, the 10400 only supports 2666.
As for difference in performance between 2666 & 3200, check out W1zzard 's review and compare the brown and green results such as these:
825 (0.43/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
The memory doesn't have much affect on performance.
I'm supposing you need a CPU with integrated graphics so 10400 or even 4750g would be a good choice.
29,256 (6.89/day)
Yes, but generally it the motherboard that will be the determining factor on RAM speed compatability. With that Ryzen APU, you really should be aiming for DDR4 3400 or 3600 to get the most out of it's available performance.
This is incorrect. RAM speed with Intel CPUs is less important. With Ryzen APU's it is a critical variable in overall system performance.
825 (0.43/day)
Taiwan
Processor i5-9600K
I don't really see much performance increase in these test results
29,256 (6.89/day)
Yeah, try games... and try a review of the Ryzen APU in question not a review of a Ryzen 9 CPU with a dedicated GPU...
See the reason why that is important is that the 3400g depends entirely on system ram for the Radeon GFX and faster system RAM directly equals faster video performance. This is proven fact not theory or opinion.
825 (0.43/day)
Taiwan
Processor i5-9600K
Why should we consider gaming performance when the OP is asking for video editing?
21,795 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK)
Case Thermaltake Core X31
Software Windows 11 Enterprise
Yes. Use case is relevant here. The OP is considering integrated graphics for a reason: The GPU will sit largely unused.
29,256 (6.89/day)
Simple, GPU performance will play into video editing performance as most editing software uses GPU resources to assist in rendering.
Additionally, the difference in overall performance is drastic depending on the speed of ram. While the review below is for the 4650g, the differences are similar for the 3400g.
newtekie1
Semi-Retired Folder
28,473 (4.05/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Please at least go with an B460 or H470 motherboard. The B460 boards aren't that much more, in fact they can be cheaper than H410 boards.
In reality, if OP is worried about GPU acceleration they would be better off just grabbing a GTX1650 than worry about iGPU performance. The iGPUs might help, but not that much. And if he's using Premier, the iGPU won't be used at all.
54 (0.02/day)
System Name The Berserker Armor
Processor Ryzen 7 7700x
Motherboard Asus TUF Gaming X670E Plus Wifi
Cooling CORSAIR ICUE H150i RGB ELITE
Memory Corsair Vengeance DDR5 2x16GB 6000mhz
Video Card(s) ASUS TUF Gaming RTX 4070 Ti
Storage Samsung 980 Pro 1tb, Samsung 980 1tb
Display(s) LG 27GL850-B 144hz
Case Corsair 5000D Airflow Black + 3x SP120 fans
Power Supply Seasonic Focus Gold GX-850
Mouse Corsair Harpoon Rgb Pro
Keyboard Corsair K60 Rgb Pro
I see budget is one of your main reason. I would say pick whatever platform that fits to your budget.
In real world, that 250hz ram speed advantage wont make it a big difference anyway. They're probably like 8s faster render or maybe +8 fps in games.
2,963 (0.82/day)
Long Island
Well yes, video editing van take advantage of more cores, that doesn't always mean that more cores = better performance.
The 9600k (6/6) scored 248 seconds in Video editing / the 3700x (8 / 16) scored 253 seconds ... foirget die size, forget cores ... when evaluating number in yur primary application, just see which one is faster in that applications. Performance in benchmarks using other applications might not always transfer to the particular application of interest
I. start at the bottom here and work my way up until I hit what meets budget
$300 5600 XT = 194 seconds
$350 2700 = 286 seconds
$172 10400F = 267 seconds
$223 3600 = 263 seconds
As for the RAM... I don't see it having much of an impact
newtekie1
Semi-Retired Folder
28,473 (4.05/day)
Indiana, USA
You're not wrong, but the OP might only be able to afford the 3400g.
For now, but it isn't hard to save up enough for a GTX1650.
Not everyone uses Adobe products.
They's why I said "if". But even the other popular modern video editing softwares don't really benefit that much from the weak sauce iGPUs. A inexpensive dedicated GPU, even if bought a little while down the road would blow the iGPU performance out of the water. So the point is we really shouldn't be concerned that much with iGPU performance and minor affects RAM speed has on it.
And when it comes down to it, the real question isn't even about RAM speed, it's about 10400 vs 3400G and the answer to that is each for the purpose of video editing, 10400 is the one to go with. It doesn't matter that the 10400 supports slower RAM, it's still faster for video editing.
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
It depends on the editing program the OP is using. Lots of editing programs will use Cuba cores from Nvidia to edit much faster than any processor.
Antikapitalista
2 (0.00/day)
FYI, it is about (-)5 % for Ryzen APUs for GPU-intensive workloads; video rendering can be GPU intensive, depending on nature the workload.
I do not know much about Intel CPUs, but a cursory glance at the specifications reveals that the top supported memory speed of your prospective piece is DDR4-2666, which makes the choice irrelevant.
Besides, the Ryzen 3400G is of the Picasso microarchitecture (i.e. Zen+), its supported memory speeds therefore top at DDR4-2933 for a single-rank module per memory channel, which makes the dilemma a moot point, i.e. it would be meaningless to go above DDR4-2933 in either case.
While you could probably overclock the Infinity Fabric of Ryzen 3400G—this is possible because Ryzens all have the advantage of being unlocked, whereas Intel charges you extra for that and your prospective Intel piece is definitely locked—but your mileage may vary: your computer could either run faster, or not at all, i.e. it would not even boot in the latter case.
Here are a few side-by-side comparisons, just for your reference:
29,256 (6.89/day)
That is incorrect. The 3400G fully supports XMP profiles. I have built systems with that APU and DDR4 3800 and the RAM ran at advertised speeds perfectly stable.
