Is there any displaycard for Mac Pro 5.1 that supports 5120 × 2880 displays ?
Kludrik
2 (0.06/day)
I try to find a card that supports a 5K monitor and fits in my mac Pro 5.1. Any suggestions? Even better if it supports two displays.
41,577 (6.59/day)
Have you used the serach engine like lycos?
1,076 (0.70/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 sumpin'
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) PColor 6800 XT / PNY RTX 4060 Ti
Storage 4TB Team MP34 / 2TB WD SN580
Case Corsair 4000Air / TT Versa H18
Audio Device(s) Dragonfly Black
Power Supply EVGA 650 G3 / EVGA BQ 500
Mouse JSCO JNL-101k Noiseless
Keyboard Steelseries Apex 3 TKL
Software Win 10, Throttlestop
A Mac firmware-flashed RDNA2 GPU will work in the macpro5,1. RX 6600/XT, 6700/XT, 6800/XT 6900 XT and their 6x50 variants. I assume flashed RDNA1 (RX 5500/XT, 5600/XT, 5700/XT) also works and I know that flashed Polaris (RX 460, 470, 480, 550, 560, 570, 580, 590) does as well. I know nothing of this procedure and it's something I've been following with mild interest for over 15 years as I used to have Mac Pros from the 1,1 to 5,1 versions which I struggled to find a decent use for.
Kludrik
2 (0.06/day)
Then I would need to find info aborut these Flash prosedures. The reason for using an old macpro 5.1 is the use of the old macromedia Freehand program. Its the best vectorbased graphics program ever made, bar none. Adobe bought it many years ago an put it in the drawer and tries to force us to use their Adobe Illustrator (or irritator). I also run the photoshop C6 with a permanent lisence on it, and find the mac more than quick enough for regular use.
6,293 (4.54/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
For your use case, the Radeon VII is probably the best choice all around. But that is also a difficult to find, expensive graphics card.
It has the same Vega 20 GPU design from the last generation of Intel-based Mac Pros, and should also be the easiest to get to work. OpenCore Patcher should be able to spoof it into being detected as the Mac Radeon Pro Vega II with near full functionality, but that's where about my knowledge about it ends. It may require a lot of work, and most of us here at TPU are Windows or Linux PC users. Good luck and keep us updated!
