Z690 Somewhat slow boot vs previous Z170 built
18,584 (2.69/day)
System Name AlderLake
The windows install seems to have created 3 partitions, weirdly enough a 611MB partition at the end?
After the windows installation I used samsung magician to set over provisioning.
Edit:
I like windows 11 sofar, no issues overall, just a bit of a slow boot.
Mind you , I don't make use of "fast boot" setting since that was causing issues in the past so not using that anymore.
It's just that it is booting somewhat slower than my previous Z170 built.
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Post another full disk management screen shot like this one
51 (0.04/day)
System Name Tiny Tim
Processor i5-8500
Motherboard HP Elitedesk 800 G4 65w
Cooling Stock copper 65w rated
Memory 2x8gb HMA81GS6DJR8N-XN SK HYNIX 3200MHZ DDR4
Video Card(s) Intel UHD 630
Storage Samsung SSD 970 EVO Plus 500GB + SAMSUNG MZVLB512HAJQ-000H1 500GB
Display(s) NEC EA224WMi
Case Stock 1L case
Audio Device(s) Synaptics HD Audio
Power Supply 130W external PSU
Mouse Corsair Katar Wireless
Keyboard Generic Dell Wireless
Yup, totally normal. Windows hides some stuff there for recovery afaik, not sure what - must be smuggling drugs or something.
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
The windows install and samsung magician created the partitions
Okay you're on an old upgrade install
100mb ouch that means you have other system reserved "really system restore plus recovery tools" partitions created when large windows updates are installed and they must be on different disks and why your startup is slower than it should be except when you're in bios
Bottom line you need to increase the 100mb partition to 750mb so next large update install recovery info on it and not on another one somewhere other than C disk.
Then remove any system restore partitions anywhere else.
Also helps if C is disk 0 not 3...
18,584 (2.69/day)
Disk 3 (C:) is a samsung 980 pro which is installed between de CPU and GPU.
Toothless
Tech, Games, and TPU!
9,604 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Why do you have so much space not used? Like, just combine the unused into the partitions.
18,584 (2.69/day)
Samsung magician did that (over provisioning)
42,260 (6.64/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
Been like that since Vista
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Well
Usually efi is only 16mb and is first so good it is a efi paprtition because old windows creaded a 100mb system reserved to lol which imagine my surprise to see it there :laugh:
2nd is usually a system reserved of various sizes
3rd C
I increased my system reserved just for kicks
You might turn off and get rid of the over provisioning partition it might be slowing boot.
18,584 (2.69/day)
Well it was a clean windows 11 install from USB STick and for the install I only had the samsung 980 1TB installed on the motherboard.
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
That's odd because 100mb is to small for all recovery stuff And you say sammy created the other system recovery partition.
18,584 (2.69/day)
Samsung Magician created the unallocated 93.15GB partition between it.
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Just ran into this but it's better to have system reserved larger and before C I've found
But face it recovery partition increases 24mb per update lol so maybe 1gb would be best :laugh:
This change is also why ms screws up linux grub if dual booting with linux.
Toothless
9,604 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Welcome to the newer version of magician lol
18,584 (2.69/day)
I've never had that on any of my Samsung SSDs. That's weird.
It's not that samsung magician just created that itself without me knowing.
I just used the over provisioning option in samsung magician for all my SSD's.
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Since it's unallocated guessing it won't stop windows from increasing system reserved when it wants to.
Disk 0, which m.2 slot is that or is this a sata port ?
18,584 (2.69/day)
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Which exact sata ports are you using now.
Think sata 1 and 2 are best for os disks
If not using them as such maybe try using other sata ports instead and leave 1 and 2 unused
18,584 (2.69/day)
Would it matter?
I have bought the 980 pro M.2 for OS.
Toothless
9,604 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Okay, like, which ports are being used isn't going to change anything.
To the thread question, yes it's normal.
ARF
4,670 (2.64/day)
Ex-usa | slava the trolls
That "over-provisioning" is quite controversial, if you need it or no.
I would vote for no and delete it. You don't need so great amounts of free space sitting there doing nothing, maybe if your drives get full, that will be used to optimise the performance...
After reading this, no.
SSD Over-Provisioning And Its Benefits | Seagate UK
9,340 (5.35/day)
Louisiana
Keyboard G710+x3
Would it matter?
On a asus board they color shade different sata ports
1 & 2 are Darker that 3-6 or how ever many there are
But as I said 1 is usually an os port even if you use an m.2 as it shows a sata as disk 0
This is why I asked
No big deal to switch to 4-5-6 and leave 1 and 2 unused.
Might help boot.
Toothless knows nothing of the slow boot issue
27,853 (6.69/day)
I always preconfigure partitions before installing Windows. A small partition for temp files and the pagefile followed by a larger partition for the main install. Keeps things simple and forces Windows to keep all files in folders where they belong for user inspection/management.
Toothless
9,604 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
This is why I asked
Might help boot.
You're not even close to answering the thread question and keep going on about other things. Don't even try the "know nothing" bs.
You even ignored that they're using M.2 NVME for boot, and STILL go on about SATA ports.
