ISSUE ABOUT XMP PROFILES
furkandurdu
15 (0.01/day)
hello, hello, im using clevo pa71hs-g model laptop and i wanted to boost my rams a little bit, i have ddr4 gskill 2*8 gb 2133 mhz rams and my motherboard supports maximum 2400 mhz,
so i decided to check the bios in order to not to make the changes on my own and leave it to the motherboard via xmp profile 1
and i saw this..
both of xmp profiles are full of 0's, the question is WHY ? and how can i fix it...
thanks!!
1,327 (0.37/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | QKZ x HBB
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Windows 10 Education 22H2 x64
Aren't XMP profile stored on the RAM?
1,896 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Can't you just pick/change [Memory ratio] to "9" ?
furkandurdu
15 (0.01/day)
Zeros mean that there is no such XMP profile.
RAMs need to introduce themselves to the rest of the pc somehow, you know.
There is a small chip that contains information about them:
oh okay now i get it, thank you very much!
well i can do that but i have no idea what to do with other numbers you know timings and voltage value so i thought maybe the bios itself would help me but seems like it wont.. thank you very much for the reply!
1,896 (0.61/day)
System Name BOX
Keyboard HP KB-9970
Don't do anything to them.
Just pick "9" and check if it works.
14,062 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
For Memory Profile, you have custom selected.
If changing the ratio as suggested doesn't work, change that setting to select XMP.
825 (0.45/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
There's no XMP profile
Just increase the ratio, if it's unstable, try adding some voltage. Usually you don't need to change the timings until voltage doesn't help.
14,062 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
825 (0.45/day)
Taiwan
Processor i5-9600K
Why would there be a XMP profile when it is a 2133 Mhz ram
14,062 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
1,327 (0.37/day)
Nowy Warsaw
System Name SYBARIS
All those 0 means your RAM doesn't have XMP profile and isn't OC'd. It's base spec.
If you can OC it (by changing memory reference clock or memory ratio) then do a custom OC. Ofc if you want more Mhz that is. If you want to less latency you can tighten the timings (tCL, tRCD, tRAS etc.) while keeping 2133 Mhz.
You can try googling common XMP profiles and use them as reference.
furkandurdu
15 (0.01/day)
Can you set those values to "auto"?
you mean if i set the ratio to 9 which makes 2400 mhz in my case and for the others if i select auto, then the timings and voltage would be set automatically to feed this 2400mhz?
well i saw a video, a laptop basically has the same bios (prema bios) with mine and when overclocking didnt work the guy had to take off the bios chip(those look like a coin, i dont know the name) and make it wait like 20 seconds and then put it in again and so he had the chance to fix the values that he gave before. its okay for now, but the problem is, i dont hace this kind of bios chip like i cant take it off and make it wait so its kinda creepy that what if i give the wrong numbers and laptop doesnt turn on which is not odd, but then i wouldnt have the chance to fix it via open it you know what i mean ?
there is no xmp profile as i showed in the picture, its not greyed out since i selected custom settings, i tried to select those xmp1 and xmp2 but when i select one of those, it seems as DEFAULT automatically. i think my rams doesnt have xmp profiles as the guy above said. thank you!
thank you very much, its very clear
18,584 (2.70/day)
System Name AlderLake
A right, that chip...
silentbogo
5,538 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Have you bought any Ram recently that doesn't have XMP?
Since when did XMP become mandatory? There are tons of generic RAM kits out there that have no XMP profiles whatsoever.
Speaking of which, I think I have a stick of G.Skill DDR4-2400 on my desk, similar to the one OP has - no XMP, Kingston in my deskmini - no XMP, and I'm pretty sure my generic Kingston DDR3 Udimm in second workstation has only JEDEC profiles as well. Some uninventive OEMs may occasionally throw in an XMP profile that's just a clone of the highest JEDEC profile, sometimes they fill it in with random JEDEC profiles in-between, sometimes those slots in SPD EEPROM are just blank.
