georger
- Jun 16, 2018
- 2 (0.00/day)
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Hello guys
As the title states and you can see on my images, I have an Alienware Aurora R5.
CPU-Z (latest version) detects my GPU in the graphics tab, but it doesn't display my clock speed or memory
Why is that? Is something wrong? Anything I should be worried about?
Thanks!
System Name | Good enough |
Processor | AMD Ryzen R9 7900 - Alphacool Eisblock XPX Aurora Edge |
Motherboard | ASRock B650 Pro RS |
Cooling | 2x 360mm NexXxoS ST30 X-Flow, 1x 360mm NexXxoS ST30, 1x 240mm NexXxoS ST30 |
Memory | 32GB - FURY Beast RGB 5600 Mhz |
Video Card(s) | Sapphire RX 7900 XT - Alphacool Eisblock Aurora |
Storage | 1x Kingston KC3000 1TB 1x Kingston A2000 1TB, 1x Samsung 850 EVO 250GB , 1x Samsung 860 EVO 500GB |
Display(s) | LG UltraGear 32GN650-B + 4K Samsung TV |
Case | Phanteks NV7 |
Power Supply | GPS-750C |
System Name | BOX |
Processor | Core i7 6950X @ 4,26GHz (1,28V) |
Motherboard | X99 SOC Champion (BIOS F23c + bifurcation mod) |
Cooling | Thermalright Venomous-X + 2x Delta 38mm PWM (Push-Pull) |
Memory | Patriot Viper Steel 4000MHz CL16 4x8GB (@3240MHz CL12.12.12.24 CR2T @ 1,48V) |
Video Card(s) | Titan V (~1650MHz @ 0.77V, HBM2 1GHz, Forced P2 state [OFF]) |
Storage | WD SN850X 2TB + Samsung EVO 2TB (SATA) + Seagate Exos X20 20TB (4Kn mode) |
Display(s) | LG 27GP950-B |
Case | Fractal Design Meshify 2 XL |
Audio Device(s) | Motu M4 (audio interface) + ATH-A900Z + Behringer C-1 |
Power Supply | Seasonic X-760 (760W) |
Mouse | Logitech RX-250 |
Keyboard | HP KB-9970 |
Software | Windows 10 Pro x64 |
System Name | Lenovo ThinkCentre |
Processor | AMD 5650GE |
Motherboard | Lenovo |
Memory | 32 GB DDR4 |
Display(s) | AOC 24" Freesync 1m.s. 75Hz |
Mouse | Lenovo |
Keyboard | Lenovo |
Software | W11 Pro 64 bit |
System Name | Americas cure is the death of Social Justice & Political Correctness |
Processor | i7-11700K |
Motherboard | Asrock Z590 Extreme wifi 6E |
Cooling | Noctua NH-U12A |
Memory | 32GB Corsair RGB fancy boi 5000 |
Video Card(s) | RTX 3090 Reference |
Storage | Samsung 970 Evo 1Tb + Samsung 970 Evo 500Gb |
Display(s) | Dell - 27" LED QHD G-SYNC x2 |
Case | Fractal Design Meshify-C |
Audio Device(s) | on board |
Power Supply | Seasonic Focus+ Gold 1000 Watt |
Mouse | Logitech G502 spectrum |
Keyboard | AZIO MGK-1 RGB (Kaith Blue) |
Software | Win 10 Professional 64 bit |
Benchmark Scores | the MLGeesiest |
Could be because your motherboard is Dell & isnt reporting as well as others. CPUZ likely works by reading information from the GPU through the motherboard, and Dell isn't exactly known for sharing, its likely the board. notice the readings on your motherboard tab arent all the way filled in either
should look like this
