Issue with Fortnite and NV clean install 1.9.0
11 (0.01/day)
Processor Intel Core I5-13600KF
Cooling Noctua NH-D15S
Memory Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6400 CL32 (Command Rate 1)
Video Card(s) ROG Strix GeForce RTX™ 2080 Ti White Edition
Storage WD Black SN850X NVMe SSD (2 TB)
Display(s) Pixio PX277 Prime
Case NZXT H510 Flow ATX Mid Tower Case
Mouse Logitech G504
Benchmark Scores Cinabench R23 (Multi Core): 24451 pts
After installing the latest nvidia driver for an RTX 2080TI on NV Clean Install 1.9.0 (with the 3 experimental tweaks selected), it fails to lunch and says:
"A D3D11-compatible GPU (Feature Level 11.0, Shader Model 5.0) is required to run the engine", and:
"Easy Anti Cheat, Untrusted system file (C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7c3c24d7235d00ca\nvldumdx.dll).
Reverting to 1.8.0 and installing the same way fixes this problem.
W1zzard
Administrator
27,263 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Yeah, some tweaks in NVCleanstall modify nv_dispi.inf, which EAC catches as "untrusted system file".
For now, no choice other than to install without the experimental tweaks
11 (0.01/day)
Mouse Logitech G504
As I said before, 1.8.0 works fine with the experimental tweaks on Fortnite so I'll have to revert for the time being. Thanks for letting me know.
W1zzard
Administrator
27,263 (3.70/day)
Memory 48 GB
Oops, I misread. Will research what the difference is and how to work around it :)
11 (0.01/day)
Mouse Logitech G504
Thank you.
W1zzard
Administrator
27,263 (3.70/day)
Memory 48 GB
how interesting, looks like NVIDIA is signing that file with an expired signature
exadeci
1 (0.00/day)
I have the same issue with Easy Anti-Cheat after upgrading to NVClean 1.9 and it was fine with 1.8
Using 1.8 to re-install the driver with all checked works fine I can launch it again.
And the dll still has the same 2019 validity
Eriol
1 (0.00/day)
Same issue with fresh install off Windows 10 Pro + 466.11 nvidia driver installed with NVCleanstall 1.9.0.
Game is Gears 5, Easy Anti-Cheat blocking nvldumdx.dll then game try to start with Microsoft Basic Render driver.
Reinstalled with NVCleanstall 1.8.0, during installation Windows ask if untrusted driver can be installed but then the game starts properly.
Previous NVCleanstall versions (don't remember which one I used, maybe 1.7.0) doesn't have either issues.
W1zzard
Administrator
27,263 (3.70/day)
Memory 48 GB
1.7.0: uses a very slow signing method
1.8.0: uses a faster method
1.9.0: uses another method to avoid the "untrusted driver" popup
long learning process :)
Deleted member 205776
Same thing happens to me when trying to run Paladins, EAC error about the same .dll. Gonna keep using 1.8.0 for now.
heliormarques
1 (0.00/day)
I have the same issues with the 1.9 version, the game was Enlisted, and the same dll got flagged by easy anti-cheat.
Installing the previous 1.8 and re-installing the same driver with expert tweaks I always used without problems didn't fix my problem, I had to uncheck all expert tweaks in order for it to work.
paz
1 (0.00/day)
An option to choose between these signing methods would be nice, since I need my driver to be "trusted" by these anticheats
W1zzard
Administrator
27,263 (3.70/day)
Memory 48 GB
Yeah that's the plan, if I can't figure out a better way
11 (0.01/day)
Mouse Logitech G504
Late reply, but this test build works, thanks.
