Issue with PCIe Bus Interface on GPU-Z
SnacksLord
7 (0.01/day)
I am having this issue now. The Bus interface field is showing the wrong information.
My Specs:
H570M-ITX/ac
Intel Core i5-11400F
Zotac Gaming RTX 3060ti
Windows 10-64bit
Things I have tried:
- uninstalling and re-installing the nvidia drivers
- uninstalling and re-installing gpu-z
- removing and putting back the graphics card.
- changed the PCIe bus link speed to/from auto/gen3/gen4 in BIOS.
- two separate riser cables (one is gen3, one is gen4).
Any ideas as to what could be causing this?
Anything else I should try?
Thanks in advance.
1,069 (0.22/day)
Botevgrad, Bulgaria, Europe
System Name Main PC/OldPC/3rd PC
Processor Intel Core i7-3770K Ivy Bridge/Core i5-3470 Ivy Bridge/Core i3-4330 Haswell
Motherboard ASUS P8Z77-V/ASRock Z68 Pro3 Gen1/ASUS H81M2
Cooling Cooler Master Hyper 212 EVO/Intel Box cooler/Intel Box cooler
Memory 32GB Corsair Vengeance/32GB ADATA/16GB ADATA
Video Card(s) SAPPHIRE R9 290 Tri-X OC 4GB/MSI RX 480 8GB/SAPPHIRE R9 390 8GB
Storage 2x1TB ADATA SSDs in RAID0+3 HDDs/2xCrucial 1TB SSDs in RAID0+3 HDDs/Samsung 1TB SSD+8TB+4TB HDDs
Display(s) Philips 274E5QHAB@HDMI + Philips 273EQH@DVI (both 27")
Case Fractal Design Define R4 Titanium
Audio Device(s) Kenwood Mini HiFi system/Microlab speakers/Philips HDMI (main)+LG TV monitor HDMI + Apple headphones
Power Supply Cooler Master Silent ProM 600 W (modular)
Mouse Microsoft Ergonomic Sculpt Desktop 2.0 (combo)@Razer Goliath mousepad (Medium speed)
Keyboard Microsoft Ergonomic Sculpt Desktop 2.0 (combo)
Software Win10 64-bit (Main PC v.1809 RTM Enterprise/2nd PC v.1903 Insider Preview Pro/3rd PC - same as 2nd)
If you put some load on the card via the ? mark button -- Start Render Test, does anything change?
What PSU brand & model do you use?
Without any riser cables, is it still that way?
SnacksLord
7 (0.01/day)
1- It is around x2 1.1 and it goes as high as x2 3.0 when I start the render test.
2- I have an EVGA Supernova 550GM
3- I have yet to try this but after trying two different riser gens I assumed it was something else.
izy
950 (1.25/day)
Did you try to change the GPU slot? edit: nvm your MB has only one.
izy
950 (1.25/day)
There is only one
Any bios updates available maybe? worth a shot.
Edit: What i would do is search for a newer GPU and MB BIOS and install them , test the GPU in some other motherboard (or some other GPU in that MB) and go from there.
Check if the PCIE slot is clean.
3x0
935 (1.42/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
Is the card bought new or used?
3x0
935 (1.42/day)
Did you notice the issue after placing all the components in a new case?
I'd first check the performance in 3DMark and compare to the other 3060Ti scores to see if there's any performance difference. If the card really is running in x2 3.0 mode there should be a noticeable difference.
Also check the PCIe slot (and riser cable) for any damage or dirt just in case as @izy mentioned.
I asked if you were the first owner, since sometimes the card gets damaged by previous owners which could result in a cut down PCIe lane.
SnacksLord
7 (0.01/day)
Yes. I noticed the issue after moving to the new case. But I also remember having to upgrade GPU-Z after the move. It was showing what was expected before migrating.
I got a 10838 when I ran Time Spy. Will compare to others.
I am not the first owner but I've had the card for over a year without issues until now.
2,219 (1.07/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
i know you have tried 2 riser cables bud i went through 3 before i got a good one mine was stuck on x8 for the first 3 thay was all thermaltake but i got a coolermaster ultra flexible one and its worked prefect since.
SnacksLord
7 (0.01/day)
Thanks. I think I have a third I can try but out of the other two I tested, one was working fine before moving to the new case and the other one was brand new.
W1zzard
Administrator
27,279 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Try without riser cable, also inspect your card's slot connector area for damage to components, like a knocked off resistor or capacitor
another card works at the correct lane width using one of those riser cables?
SnacksLord
7 (0.01/day)
Same result with third riser. I will try without riser next but I I am going to have to take everything out the case for that.
