Issues with drivers 566.36 and NVCleanstall v1.17
7 (0.00/day)
Latest nvidia driver update seems like have introduced some difference in its files. Now with driver 566.36 and latest NVCleanstall it gives an error the moment you press "Install" to start Nvidia installation prompt (see screenshot below). It basically says "unable to find the specified path".
Just to be sure I tested with previous 566.14 and it works fine.
33 (0.01/day)
System Name CyberDyne Systems
Processor AMD 7800X3D
Motherboard Asus ROG STRIX B650E-E Wifi
Cooling Alphacool Eisbaer Aurora HPE 360 mm
Memory 32 GB G Skill Flare X5 F5-6000J3038F16GX2-FX5
Video Card(s) Nvidia 4090FE
Storage WD Black SN850X 1 TB, WD Black SN850X HS 2 TB, WD Black SN770 2 TB
Display(s) Alienware AW3821DW 3840x1600 144 Hz
Case ThermalTake Core P3 TG Pro
Audio Device(s) Onboard Realtek ALC4080 Corsair SP2500
Power Supply Asus Thor 1000W
Mouse Razer Viper Ultimate CyberPunk 2077
Keyboard Corsair K65 LUX RGB
Software Win11 Pro
Same here.
2,336 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
Same experience, also tried v1.16.0 and same negative.
AAF Optimus
Audio Modder
1,215 (0.43/day)
Rio de Janeiro, Brazil
System Name NEW AAF OPTIMUS RIG
Processor AMD Ryzen 5 5600X (6C/12T)
Motherboard ASUS TUF Gaming B550M-Plus
Cooling DEEPCOOL Gammax L120T
Memory CRUCIAL Pro Gaming 32GB DDR4-3200 (2x16GB)
Video Card(s) NVIDIA GeForce RTX 3060 12GB MSI Ventus 2X OC
Storage ADATA Legend 710 PCIe Gen3 x4 256GB; ADATA Legend 800 PCIe Gen4 x4 2TB; GoldenFir SSD 1TB
Display(s) AOC VIPER 27" 165Hz 1ms (27G2SE)
Case DARKFLASH DK100-BK
Audio Device(s) ALC S1200A with AAF Optimus Audio (Sound Blaster + Dolby Audio [Dolby Atmos For Built-In Speakers])
Power Supply REDRAGON RGPS 600W 80 PLUS Bronze Full Modular
Mouse CLAHM CL-MM386 7200DPI
Keyboard MOTOSPEED CK-108 Mechanical Keyboard
Software Windows 11 Pro x64 23H2 (24H2 has many abnormalities)
Confirmed. They are bundling NvApp now instead of GFE.
I've gotta update NVCleanstall for this
The "NVApp" feature is nothing more than the NVIDIA app, which has already left the Beta phase and will be integrated into the driver installer instead of GeForce Experience.
Everything is fine here. Driver 566.36 installed successfully, but I compiled the self-extracting tool itself before installing the driver.
  • NVIDIA System Information 12-05-2024 15-11-56.txt
Aphix
2 (0.29/day)
@AAF Optimus Any chance you could post your settings? I've tried unattended vs not and a few variations of the 2nd screen settings (ansel tweaks, etc) and am getting the same issue, even with the bundled self-extracting executable on v1.17.0
bossman
1 (0.14/day)
Just mark 4 last components - everything works after that.
PapaSmurf-FUN
1 (0.14/day)
Smurfland
You can get round the issue by selecting "NvApp" and "NvApp.MessageBus" on the "Select components to install" step of the process. I first click "Recommended" and then add those 2 components from the unknown Components section. Then the error doesn't occur.
As part of the driver install process you can choose just to install the driver or driver and App if you want. Smurfingly I just choose driver only.
Papa
AAF Optimus
Audio Modder
1,215 (0.43/day)
Papa
I did exactly this.
Aphix
2 (0.29/day)
Cheers, that was the trick, thanks guys.
Note to anyone else who didn't read the above: Unattended won't work if you don't want NvApp, but it's only a couple clicks so no biggie for a single machine.
jaybeee
3 (0.43/day)
Thanks for the tips, I've been having the same issue. One question only, shouldn't we select all 4 new components instead of only NvApp and NvApp.MessageBus? One of the others appears to be the Control Panel, and I'd like to have it too.
W1zzard
Administrator
27,891 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
If you want the NvApp, then yes, select all four (not sure if you might need more, from the GeForce Experience section)
Nightmarian
1 (0.14/day)
Selecting all four components at the bottom then manually going through the install doesn't let me unselect the NVIDIA app, only physx and the HD driver. What did I do wrong?
oliv_r
5 (0.71/day)
For the minimalists like me:
Just select Driver in the main category and NvApp in the unknown category - I ignored the other 3 unkwown and still a perfect minimalist installation. It still installed NVCP which is all I need in my gaming life.
If anyone can shed light what NVDLISR , MessageBus and NVCpl is - that will be much appreciated
cat_fire
3 (0.43/day)
Hello i have a fix that you need add in NVCleanstall auto delete this line in setup.cfg for remove this error
Open setup.cfg with notepad and scroll full down after delete this 3 lines and dont have a space in a line
2,564 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 2X D5T Vario, XSPC BayRes, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Thermaltake Xaser VI
Mouse Logitech
Keyboard Logitech
Software Win11PRO
So, if we only want the driver, it does not work?
cat_fire
3 (0.43/day)
It works. You just have to make sure to check ✅NvApp in the Unknown Category. When the actual installation starts you will be given a choice whether to install Driver+NVIDIA App or just the Driver. Click on just the driver.
don't need check NvApp check minimal after click button open folder and open setup.cfg in notepad delete 3 lines finish all don't need check telemetry app
cat_fire
3 (0.43/day)
NvSlimmer have this function to delete 3 lines in a software
W1zzard
Administrator
27,891 (3.71/day)
Memory 48 GB
Yup, this will be my approach in next version. Thanks for pointing this out
Dhry
1 (0.17/day)
Latest NVCleanstall doesn't connect to some sort of server or bring any info up at all. Previous one works to load existing drivers.
W1zzard
Administrator
27,891 (3.71/day)
Memory 48 GB
