ITX PC Intake/Exhaust Design: Is Intake Needed?
7,066 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Just built this:
Do I really need an intake fan? I tried running a 92mm intake on the right side but it just added noise. No cooling benefit at all.
GPU: Getting 70*C load Max 30*C Idle
CPU: Getting 65*C load Max 25*C Idle
My power supply sucks in air and exhausts out the top, is this enough to cool my VRMs on the Z77E. My main concern is whether the motherboard can handle overclocks in the long term without an intake. The power supply is close enough to the side panel (sits directly above the itx) that it draws in air from that side and exhausts it out the top. The CPU has an AIO Cooler that dumps exhaust down to the bottom below the case. So the only real intake fan is the two on the GPU, and obviously that only benefits the GPU.
Runs a lot quieter and the temps seem the same side intake or not. I'm going to remove the Xeon and put the 2550k in soon enough. I just want to make sure I don't burn out my motherboard or something.
529 (0.13/day)
Processor Ryzen 7 3700x 8 Core - No All Core OC, just PBO.
Motherboard Asus Prime B450M-A II
Cooling AresGame River 5 Single Tower Air Cooler
Memory 16GB DDR4 @ 3200MHz
Video Card(s) PNY Blower 1080TI - Undervolted 800mv 1700mhz effective.
Storage 1TB Silicon Power A60 Boot Drive / 1TB HDD 7200RPM / 256GB Plextor SATA SSD
Display(s) 27'' Sceptre 165Hz 1080p
Case Zalman Z3 ATX Mid Tower
Power Supply Thermaltake Toughpower GX1 600W
Mouse Razer Deathadder V2
Keyboard Steelseries Apex 3 Membrane Keyboard
Well, experience would say you do need a intake to bring in cold air. But, if it doesn't add any cooling benefit to your hardware and you haven't had any overheating problems then its ultimately your choice.
7,066 (1.01/day)
USA
Mouse Zowie EC3-C
I am thinking that the two exhaust fans (power supply fan and radiator fan) serve as intake as well because of the large open hole and that running intake fans just disrupts the air flow. I just want to make sure I am not gonna kill my mobo. The mobo sensor temps are all pretty good, 35*C.
344 (0.05/day)
Georgetown, Ontario, Canada
System Name Dirty Bitch
Processor Intel Core i5 2500K Quad Core LGA1155 @ 4.6GHZ Sandy Bridge 6MB
Motherboard ASRock Fatal1ty Z77 Professional-M "Micro-ATX"
Cooling Raystorm & Evga Full Blocks, Single & Dual 120mm Radiator With Push/Pull Config, All Noctua fans
Memory 12GB G.SKILL Ripjaws DDR3 @1600 CL9-9-9-24
Video Card(s) 2X SLI EVGA GTX 480
Storage PNY XLR8 PRO SSD 256GB - 1TB WD Black @7200RPM
Display(s) LG 40" LED 1080p & ASUS VE278Q LCD Black 27"
Case Lian Li PC-V354B Aluminum Mini Computer Case mATX
Audio Device(s) Integrated out to Marantz Receiver 4.0 Klipsch Speaker Setup
Power Supply OCZ ModXStream Pro 700W ATX
Software Windows 7 Ultimate, G15 Keyboard, Cyborg R.A.T 7 Mouse, IceMat Mouse Pad
If it were me I would buy a new quiet fan just to be on the safe side. I personally like Noctua fans but there are other more affordable quite fans.
Or just pull it, stress everything on the system for at least a few hours and see where the temps are at for all the internals and the case itself. I use HeavyLoad & CPUID HWMonitor but again lots of options out there.
