Jonsbo Intros the TW Series AIO Liquid CPU Coolers
47,203 (7.56/day)
Jonsbo rolled out the TW-120 and TW-240 all-in-one, closed-loop, liquid CPU coolers. The two are differentiated by radiator sizes - 120 mm x 120 mm, and 240 mm x 120 mm, respectively; and characterized by a rather tall hexagonal pump-block that's illuminated by RGB LEDs. The included 120 mm fans feature RGB LED diodes along fan-frames as well, and lighting on the fans and the block are kept in sync.
You can control the RGB LED color, brightness, and lighting patterns by either plugging the cooler into a standard 4-pin RGB header on your motherboard (and using software such as ASUS Aura Sync or MSI Mystic Light); or use an included module to switch between 7 color presets. The LEDs otherwise support 16.8 million colors. The TW series coolers support most modern CPU socket types, including AM4, AM3(+), FM2(+), LGA2011(v3), LGA2066, and LGA115x. The company didn't reveal pricing.
8,197 (2.17/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
really hope there is 45 degree option on those elbows.
5,821 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
That is one of the ugliest things I have ever seen.
Ruru
S.T.A.R.S.
12,646 (2.91/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, EKWB Vector TUF
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
Mouse Logitech MX518 + Asus ROG Strix Edge Nordic
VR HMD Oculus Rift CV1
First with a quick look I thought that there is a fan on the block-pump unit.
2,149 (0.34/day)
Austin TX
Processor i9 11900k
Motherboard Maximus XII Apex
Cooling Custom Liquid W/ 360x60 Radiator
Memory 32Gb Team XTREEM ARGB 3600 b-die
Video Card(s) Waterblocked MSI RTX 4070
Storage Intel 900p 480Gb + 4tb Intel 670p
Display(s) LG C2 evo 42"
Case Geometric Future Model 8
Audio Device(s) HD58X + Sennheiser GSX 1000
Power Supply Corsair RM 750x
Mouse Steelseries Aerox 5 wired
Keyboard Akko Mod 007b HE
VR HMD Samsung Odyssey+
5,543 (0.96/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Now if ONLY this thing would be a new step forward for these prebuild watercooling solutions
714 (0.19/day)
where in the states can you even get their cases?
Sorry I don't know, I live in Europe and bought my Cooltek Jonsbro W2 from Quiet PC.
they are the japanise equivalnt to lian-li
Having owned numerous Lian-Li cases over the years I can attest that the Cooltek/Jonsbro cases are leagues ahead, the build quality and general design aspects are noticeably higher.
2,149 (0.34/day)
Austin TX
Processor i9 11900k
I expected as much with the design layout but I'm also intrigued by the build quality. Have you ever tried any of lian li's V or X series cases with the 3mm aluminum parts? I like mine :)
113 (0.03/day)
Toronto
Goddamit! They closed jonsbousa.com, just in time for me to buy VR1. F***!
Anyone knows who is the new NA distributor? They talked about it in that reddit post. I emailed their contact person listed on jonsbo.com, but they are chinese so it might take ages to get a reply if at all...
