Jonsbo-Jonsplus Z20 Chassis Build
429 (0.52/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
I just did an AMD Ryzen 5 7500F build with the Jonsbo/Jonsplus Z20 Chassis. The chassis is packed in a heavy wall box with soft foam packing material, and the accessories packed in a smaller box the same way. It took a little over a month to get the chassis and shipping was free. Link to the store I bought it from. The chassis is well made, and I would say it is on par with Lan-Li in quality.
Temps are a bit higher than my A3 Chassis. With the AMD Raith Prisum Cooler, temps would hit 78C to 81C with a 29.5C Room Temp. With the 240 AIO, it runs around 65C to 68C, and I would recommend using an SFX size supply if you plan to use an AIO or you will be stuck using a short video card (280MM). My 7900XT is 312MM long for reference. Also, the 7900XT runs a few C (3C to 5C) higher than the LAN Li A3, which surprised me that it was not higher.
Here is a comparison of the size of the two chassis side by side.
Lan-Li A3 (D) 443mm x (W) 194mm x (H) 321.5mm
Jonsbo Z20 (D) 382mm x (W) 198mm x (H) 335mm
Front
Top and Tray
Fan-AIO Tray
Back Side With Cables
Accessory Kit
CPU Fan Cooling
AIO CPU Cooling
With Side Glass Panel
3,259 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Don't forget the Jonsbo ram cooler ...
garoliman
6 (0.02/day)
Which one do you recommend? I can´t decide :(, I like both and my components fits in both
bug
13,732 (3.97/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Meh, white cases... They'll never look the same once the dust starts settling in.
And Aliexpress... not my cup of tea.
429 (0.52/day)
Some Where On Earth
System Name Spam
Case Lan-Li A3
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
What CPU and Video card do you plan on using in your build?
429 (0.52/day)
Some Where On Earth
System Name Spam
Case Lan-Li A3
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
Like a 5600 cpu and 7700 xt/7800 xt gpu, cpu cooler thermalright peerless assassin 120
Eather will work for you. I do like the Jonsbo because it is smaller, and you can get the black ones in the us from Amazon or Newegg. If you can wait a month, AliExpress would be cheaper, and you can get the white ones.
On a side note, the Lan-Li A3 does have a side window you can order separately.
2,109 (1.07/day)
Hungary
Mouse Canyon Puncher GM-20
Thats pretty nice!
Btw Jonsbo is actually a pretty well known brand with a decent quality and I can even buy their products in my country from some of our bigger etailers. 'they come with 2 years of warranty usually which is normal around here'
Just thought I would mention that in general before ppl instantly thinks that meh its just another Aliexpress garbage..
ss9918
1 (0.02/day)
Both nice choice of case. For the Jonsbo could you fit a 280mm cooler ? looks like it's long enough
10,702 (1.72/day)
Austin Texas
System Name Stress Less
Processor 9800X3D @ 5.42GHZ
Motherboard MSI B650 PRO Wifi
Memory 48GB DDR5 6400 / 3200 / 2133
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
I love my Z20 -- nice build!!
429 (0.52/day)
Some Where On Earth
System Name Spam
Case Lan-Li A3
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
You could do 2 140mm fans without the radiator and with a 240mm radiator and two 120mm fans, you are just about against the FET heatsinks on the motherboard (It's the width that is the issue.).
