Keep my 850 evo as boot drive or upgrade?
315 (0.15/day)
Italy
System Name The Worker/ Laptop
Processor Ryzen 5 3600/ i5 1035g1
Motherboard MSI b450 Tomahawk Max / Lenovo proprietary
Cooling Arctic Freezer 33 eSport One
Memory 16Gb DDR4 3200 Mhz Corsair vengeance LPX / 12gb ddr4 3200Mhz (4gb are soldered :( )
Video Card(s) Gigabyte gtx 1660 Ti OC @2030Mhz core and 7400Mhz memory / Intel G1 UHD
Storage 1 970Evo plus 500gb, 2x250Gb Samsung 850 Evo,3 TB HDD / 250gb WD SN530
Display(s) Asus mx259h / 15.6 FHD TN
Audio Device(s) Onboard / Onboard
Power Supply CoolerMaster G750M
Software W10 64bit
Hi all, in the recent times I started wondering to buy a nvme ssd to change my Samsung 850 evo m2, connected via a m2 to sata converter.
The main reason is to have faster boot times and load stuff like davinci more quickly
Is it the right time to upgrade or should I just stick with it?
Also do you have any suggestions about a good nvme that doesn't cost a fortune? I was aiming for a 970 evo plus or something similar but prices are high.....
8,226 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
No. connecting an NVME drive to Sata means you are still being limited to Sata speeds.
12,333 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
Its a little faster but not that noticeable. If you can go to a larger drive it would be a good upgrade but otherwise no
315 (0.15/day)
Italy
Software W10 64bit
but i have the slot
to me comparing that with a medicore nvme that I have on my laptop (wd sn530) is noticeably faster, at least in booting tims. it's like 3 seconds vs 15
12,333 (2.25/day)
Oregon
but i have the slot
It's another reason then. I've upgraded quite a few and its maybe a few seconds faster if that. The board and software is a bigger factor on boot times
But if you want to then just do it
18,584 (2.67/day)
System Name AlderLake
I was on windows 8.1 on a samsung 850 pro 512GB before and then bought a NVMe PCIe drive and installed windows 10 on it, glad that I did.
9,642 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
NVME drives wont really get you faster boot times, buy one if you actually need the higher read/write speeds.
315 (0.15/day)
Italy
Software W10 64bit
ok so any suggestions on which one to take?
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
Evo is a good data drive pro is a good os drive seeing read and write speeds are more equal.
I do have a evo plus is okay ended up getting one after returning 3 adata 8200 pro that none of them came close to advertising read/ write spec's
970 evo plus along with all sammy ssd's exceeded spec's
315 (0.15/day)
Italy
Software W10 64bit
sabrent is also popular and wd black is about the same price of the 970 evo plus. Opinions about these two?
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
Gigabyte has some interesting ones seeing they are pci-e 4 compatible
Had to look back and find my 970 evo plus CDM test they do run warm
2,555 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
but i have the slot
B450 Tomahawks are confirmed to have NVMe support. I would go for NVMe!
You likely have to move that standoff on the left, which is for the M.2 screw! Installing NVMe SSDs are tricky, because of the M.2 screw!
I recommend the 970 Evo Plus.
315 (0.15/day)
Italy
Software W10 64bit
9,340 (5.17/day)
Louisiana
Keyboard G710+x3
that's only 6 times faster.... BIG JUMP
Yeah
When testing use hwinfo too it shows read/ write also and is good to confirm that CDM or what ever is also showing the same read/ write speeds after a test as it does
You'd be surprise how inconsistent ssd test software are
Don't bother with "as ssd" it's a total waste of time using it.
Here's a current run I only really care about main read/ write QDM along with other testing software as I said is wonky at best lol
Notice the C partition is only 130gb's too 500gb 970 evo plus
12,333 (2.25/day)
Oregon
Samsung 970 EVO 1 Tb
Intel 665p Series M.2 1 Tb
315 (0.15/day)
Italy
Software W10 64bit
So quick update, a friend of mine has a discount on samung's website so i'm gonna pick the 970 evo plus 500gb.
then the most annoying part... should I just clone my current windows installation from one ssd to another or just reinstall it?
12,333 (2.25/day)
Oregon
If its a good install with no issues go ahead and clone it with the Samsung Data Migration software. You can always clean install later. You do not need a new license to clean install
315 (0.15/day)
Italy
Software W10 64bit
Really good news, this one is one of the cleanest installation I've ever done
12,333 (2.25/day)
Oregon
Samsung Data Migration software is easy to use and I've never had a bad clone with it
And I was a die hard clean install guy for years
315 (0.15/day)
Italy
Software W10 64bit
Probably i'm gonna go with it
18,048 (2.44/day)
Do check and see which size of whatever drive you're getting gives the best performance, as smaller size SSDs tend to be slower, sometimes significantly so.
315 (0.15/day)
Italy
Software W10 64bit
just a regular 2280
Should I also buy a heatsink for it or am I just good to go as it arrives?
12,333 (2.25/day)
Oregon
18,048 (2.44/day)
just a regular 2280
Not the physical size, the amount of flash.
Each SSD or at least controller generation there's a certain size where you get the optimal performance.
Once you go below that, performance drops significantly and once you go above it, it drops a little bit.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
over traditional SSD, boot times wont be that much different. nVme SSD's are good , but they have a place. IMO if the only deciding factor for going nVme is speed increase, id suggest to just buy a Sata SSD, like an 860, or whatever the modern model is. in my PC now, i have an 850 Evo & a 970 Evo, they arent really much different, outside of bench tests ofc.
