- Mar 14, 2014
- 1,438 (0.36/day)
Processor | 11900K |
Motherboard | ASRock Z590 OC Formula |
Cooling | Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas |
Memory | G. Skill Trident Z 2x16GB 3600MHz |
Video Card(s) | eVGA RTX 3090 FTW3 |
Storage | 2TB Crucial P5 Plus |
Display(s) | 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz |
Case | Lian Li Lancool MESH II RGB (I removed the RGB) |
Audio Device(s) | AKG Q701's w/ O2+ODAC (Sounds a little bright) |
Power Supply | Seasonic Prime 850 TX |
Mouse | Glorious Model D |
Keyboard | Glorious MMK2 65% Lynx MX switches |
Software | Win10 Pro |
Hello, I have been searching for a way to keep a certain application running at the max CPU frequency without throttling down because the load is not enough. Something similar to Nvidia's options where you can select certain application profiles to "Prefer Maximum Performance". Don't really want to have to mess with Windows power profiles every time.
Trying to keep my 4790K at 4.4GHz for certain applications despite load. I know its probably a repost but I've looked everywhere and just can't seem to find what I'm looking for. Thanks
