[Case Gallery] Kid's First Build
Clocked
284 (0.04/day)
Toronto
System Name Evil Eye POS
Processor Intell Q6600 G0 @ 3.6Ghz
Motherboard EVGA 680i
Cooling DangerDen/SwiftTech water cooling
Memory 4GB OCZ SLI 800mhz @ 1260mhz
Video Card(s) 8800GTX x 2
Storage WD Raptor74GB in RAID/ 160GB Maxtor/ 80GB WD
Display(s) Samsung 740n 17"
Case SunBeam Evil Eye
Audio Device(s) Onboard POS
Power Supply PC Power n Cooling 1000W
Software XP Home/Vista Pro
Specs:
P4 630@ 4,0Ghz,ATI X700Pro 256@ 475/525,Enermax
Liberty 620W PSU,OCZ 1GB Dual Channel kit,74GB WD Raptor(Game Drive),250GB Maxtor,PC Partner MOBO, Power Cooler light tubes all around, Enermax fan controler. 4 Power Cooler 80MM blue LED case fans.
Mods:
P4 630 from 3.0 to 4.0Ghz... ATI X700Pro from 425/430 to 460/510
My very first build, and i am 14! I am very happy with it and there will be more mods coming, Arctic Cooling ATI Sliencer1 Rev2 is no it's way, After that will be a TT cable sleving kit and a total rebuild, going to paint the inside of it a lime green and blue pattern. It does about 5000 3D Marks in 05, dont even wana try 06 lol!!
wazzledoozle
5,358 (0.73/day)
Seattle
Processor X2 3800+ @ 2.3 GHz
Motherboard DFI Lanparty SLI-DR
Cooling Zalman CNPS 9500 LED
Memory 2x1 Gb OCZ Plat. @ 3-3-2-8-1t 460 MHz
Video Card(s) HIS IceQ 4670 512Mb
Storage 640Gb & 160Gb western digital sata drives
Display(s) Hanns G 19" widescreen LCD w/ DVI 5ms
Case Thermaltake Soprano
Audio Device(s) Audigy 2 softmod@Audigy 4, Logitech X-530 5:1
Power Supply Coolermaster eXtreme Power Plus 500w
Software XP Pro
Could have saved a few hundred $$$ by going AMD and gotten a good video card with the savings. Case is nice...
4,994 (0.71/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
Clocked said:
Specs:
P4 630@ 4,0Ghz,ATI X700Pro 256@ 460/510,Enermax
Mods:
P4 630 from 3.0 to 4.0Ghz... ATI X700Pro from 450/430 to 460/510
My very first build, and i am 14! I am very happy with it and there will be more mods coming, nexthing coming is a sleve kit then a pair of 6800s in SLI.
Hmm, i wish i hadn't waited til i was 16 to build mine :(
Awsome job on it!
Your using the stock CPU cooler with a 1ghz overclock!?!? i found the stock cooler was crap for overclocking, even with some decent thermal grease. I could get a decent overclock, but was getting up to like 75c to 80c, as prescotts are notorious for running very hot. You need to have that as a priority, get yourself a decent cooler, and don't skimp out on the grease. You wanna get some nice Arctic Silver 5, trust me its worth it! Also, havn't you tried lowering the vcore? I got my 640 idling at 37c @ 4ghz on a 1.3125v vcore, but i run it @ 3.85ghz w/ 1.25v vcore for general use and get 34c idle, and 48c max load.
I like the fan control panel, where'd you get it?
Anyway, have fun with it! =D
Solaris17
Super Dainty Moderator
26,591 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
nice set up me likes :)
Clocked
284 (0.04/day)
Toronto
The CPU idles at 37, when running BF2 it gets up to 55ish. an Artic Frezzer 7 pro and Vantec cable sleving is coming next. I got the fan control from a local shop. www.canadacomputers.com , Enermax makes it.
4,994 (0.71/day)
South of England
cool, thanks.
wow, 37c idle with stock cooler... that's impressive! What's the vcore at?
Solaris17
26,591 (3.81/day)
Alabama
VR HMD Quest 3
is that a dvd burner?..how much does a decent everyday dont really care bout speed maybe 12x dvd burner go for anyways and i dont wish to hijack so pm me or just post 1 answer pertaining to my ?'s it is a very solid machine u have their.
Clocked
284 (0.04/day)
Toronto
Yup, thats a DVD burner! You can get a OEM dvd burner for about 40bucks at any local computer shop.... dont go to bust buy or something like that as it it about 100 there.
chopperdan88
46 (0.01/day)
Glendora,CA
ok, so i think something's a foot
i know that most p4's are pretty good with the whole heat problem. but i hardly doubt that you are able to run a 1GHz overclock and still maintain a reasonable heat number. i know that many of the people that run watercooling even run just as warm as a stock heatsink when they overclock. but if you have developed a way to overclock to that extreme and still not fry your pc, then all the power to you.
4,994 (0.71/day)
South of England
The P4 prescotts are good overclockers, you can run an extemely high overclock with a very low vcore. I can get my P4 up to 4ghz (800mhz overclock) on 1.28v, which is colder that using stock voltage and clocks. To get to 4.2ghz (1ghz overclock) I have to up the vcore to 1.32v, which still stays well below 60c. Getting up to 4.4ghz (1.2ghz overclock) I have to ramp the vcore right up on mine, so the temperature is pretty hot.
But, it is possible to keep nice temperatures with an "extreme" overclock. To be honest, i don't think 1.2ghz overclock is fast enough for me!
My cooler's nothing particulaly special, my p4 idles at 34c @ 3.85ghz. So i don't understand why the prescott has such a bad rep. It can 'withstand' higher temps, but i honesty don't think it generates more heat than any other.
Clocked
284 (0.04/day)
Toronto
Infrared said it all.... not much for me to add really.....
But yea, P4s are great to overclock, as long as your mother board can support it. Infrared started off with a 3.2Ghz and i started with a 3.0Ghz CPU, They are the same chips, so really He has got a 1.4Ghz overclock where i have an 1.0Ghz overclock. Wizzard, a very respected guy on this fourms got his 3.2Ghz to a mind blowing 4.5Ghz..... it is all possable....
2,489 (0.35/day)
Ohio
System Name Onus
Processor E8500 @ 3.95ghz ~1.25v
Motherboard ASUS P5E Deluxe
Cooling Scythe Orochi cpu, 5x 120mm Zalman red LED case fans, stock GPU coolers
Memory 8gb (4x2gb) G.Skill PC8000 5-5-5-15
Video Card(s) 2x ASUS 3870x2s
Storage 4x160gb RAID 0 Main, 2x 500gb RAID 0 media storage.
Display(s) LG W2600H
Case Lian Li PC-A70B, painted black and other modded aspects :)
Audio Device(s) HT Omega Striker. Klipsch RF-3II fronts, Yamaha NS-A222 rears, Klipsch RC-3II center, Klipsch SUB12
Power Supply Corsair CMPSU-750TX
Software Windows 7 Ultimate x64, lots of games, photoshop n stuff.
If by "any other" you're wrong. I'm running a 1ghz overclock idling at 23 with load at 38. Not that I'm trying to diss intels or anything, the overclocks you guys are getting are amazing.
And Clocked you have a very nice system, I started to get into custom PCs at about 13 or 14 as well.
Clocked
284 (0.04/day)
Toronto
UPDATE
Arctic Cooling ATI sliencer1 Rev2 is on it's way!!!
3,654 (0.52/day)
Little Rock Arkansas, United States
Sweet. I have only gotten my prescott up to 3.7 from 3.0. I thought that was high, now I know I can push it harder since my temps are still ok. Especially if I get the cooler I want.
4,994 (0.71/day)
South of England
sweet! Go for it!
KennyT772
3,572 (0.52/day)
System Name Raptor
Processor Intel E8400 Wolfdale @3600
Motherboard Asus P5Q-Pro LGA775
Cooling Zalman CNPS9700
Memory 1024mbx2 Crucial Ballistix DDR800
Video Card(s) XFX 9600GT
Storage Seagate 7200.11 500GB
Display(s) Acer AL2216Wbd and Acer AL1717
Case Gigabyte 3DAurora Black
Audio Device(s) Creative X-Fi Extreme Gamer Faitality
Power Supply OCZ GameXStream 500w
on the intel heat issue in my moms comp i oc'ed the 3.2 to over 3.8 on intel hsf and value ram. no loose timings no high heat. it also was in a cabnet in the kichen. ran around 40c idle 45c load thx no no airflow but in open space it got 28c idle 32c load. better then what i get with my northwood and an xp-90. nice case man i envy you!
4,994 (0.71/day)
South of England
Umm, i think perhaps the temperature was reading incorrectly, or you live in alaska!
There is no way it's running @ 28c on the stock heatsink while overclocked to 3.8ghz. I'm running a very low vcore @ 3.85ghz with a very nice heatsink and a windy case and only just getting down to 32c in a 24c room.
The temp sensors aren't usually very far out though, so it's gonna be pretty cool even if it isn't 28c. Nice 1 ;)
KennyT772
3,572 (0.52/day)
System Name Raptor
it definatly could be but the cooler it came with looks a little better made the ones ive seen before. its a copper/aluminum design with a quite powerful fan. also the ambient temp is around 25 in my house
4,994 (0.71/day)
South of England
cool, it's a different cooler? Might be around 28c then... that's pretty awsome! :D
Clocked
284 (0.04/day)
Toronto
Arctic cooling ATI sliencer1 Rev2 has been put in, in less then 5 min... very starght foward! good job ARCTIC COOLING!
Now.... gota save up for an other GB of ram...
Also, new pics added
4,994 (0.71/day)
South of England
Cool! :D good job!
What cooler did you get? It should have come with a backplate passive cooler for the ram. Anyway, how much further can the core go with that lovely cooler on it? :D
Clocked
284 (0.04/day)
Toronto
it is that Arctic Cooler ATI sliencer1 Rev 2, i got ram sinks so i dont need the back plate. when up to 475/525..... lol still cant get it over 45!!! lol it ran about 65 before the cooler under full load. So yea... went up 15more on the core... so that is 50core 95 mem from stock...
4,994 (0.71/day)
South of England
Cool :D Good job!
Clocked
284 (0.04/day)
Toronto
went up an other 10 on mem, making a 475/535... i am very impressed, even with this overclock the card never gets above 50C.... before it would get to 65ish...
4,994 (0.71/day)
South of England
Yep :D
I remember my core getting up to 65c, now it rarely goes above 42c. I didn't get anything more out of the memory, but i'm not too worried about that. 560mhz is fine with me! :D
I'm looking at the x1900xt though. It's identicle to the xtx, and could easily be overclocked to the xtx speeds! The only prob is i've heard the cooler on it is very noisy. And the AC Cooler for that card doesn't exhaust the hot air, instead, it blows it directly onto the chipset... Definatly not their best cooler =/
I'm wandering how much i could sell my x800xl for. The 3dmark05 score it got is very impressive, and it has the ATI Silencer on it.
