Kingston HyperX FURY 8GB 1600MHz Owners Oc ?
66 (0.02/day)
System Name my Budget :)
Processor AMD FX-6300
Motherboard Gigabyte 970A-DS3P
Cooling Zalaman CNPS10x Optima
Memory Kingston HyperX FURY 8GB 1600MHz CL10-10-10@1.5v
Video Card(s) 280x Vapor 3Gb Dualfan
Storage 1T Barracuda Black
Power Supply XFX 550W
Software Windows 7 64bit
Hello There
i would like to ask if someone owns this ram http://www.amazon.com/dp/B00J8E92M6/?tag=tec06d-20
And if someone overclocked it could give me a guide on how to set it up ? I got this ram today since my 1333MHz that i owned 5 years started giving me bsod.Any ideas how to overclock it ?
Grimm
66 (0.02/day)
Guys any ideas or any tips on how to overclock the ram ? Any help would be realy good
4,666 (0.71/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
I'm not familiar with that memory myself, but typically you'd either just raise your timings and/or add voltage (be very careful if you do) to get stability at higher clock speeds.
The datasheet shows this memory running at CL10-10-10@1.5v, but looking at your system specs, looks like you have it at CL9-9-9. If you raise the latencies back up, you should (in theory) be able to get some more speed out of it via FSB overclocking (or a different memory divider, if your mobo supports it). If you can find a similar product from Kingston that rated at a higher speed (using the same chips), you could probably manually copy over the specs from it. For example, the 1866 MHz kit runs CL10-11-10@1.5v. I'd suspect your memory could probably run at those speeds too.
66 (0.02/day)
Okey thanks for the information.Sadly i totaly forgot to update this websites pc specs*.Any ideas what tool show i use to test the ram speed ? i use Aida64 Extreme to see the speed.
4,666 (0.71/day)
Washington, US
System Name Rainbow
AIDA64 is the generally recommended program. The benchmarks there should give you a decent idea of what the speed increase is doing for you, although I wouldn't expect big improvements.
66 (0.02/day)
So i must put in timmings this CL10-11-10@1.5v. and then select 1866 MHz speed ?
4,666 (0.71/day)
Washington, US
System Name Rainbow
If it uses the same chips, I think it should work. It's worth a shot, at least. As with all overclocking, results aren't guaranteed. There's a lot of other timings that aren't getting changed, unfortunately. I think you'll just have to roll the dice and try it.
66 (0.02/day)
but i have a problem when i set the timmings and new ram speed i get something that in bios wasnt set right and i then need to reverse back to 1600 ram speed
274 (0.07/day)
System Name My-Best-So-Far
Processor Intel Core i5 12600K Boost @4.8GHz
Motherboard MSI Z690 Edge WiFi DDR5
Cooling Noctua NH-U14S - Air cooler
Memory XPG Caster 32GB DDR5 6000 MT/s CL40-40-40-77 | But running STABLE @ 4800 MT/s CL40-40-40-77
Video Card(s) Asus Strix RTX 3060 Ti 8GB
Storage SSD 250GB EVO...NVMe S40G 256GB & MP600 1TB LPX...HDD Barracuda 1TB & 2TB
Display(s) MSI Optix MAG Series MAG272CQR 2560x1440p 165Hz
Case Corsair 750D (Still one of the BEST for AIR cooling)
Audio Device(s) Realtek Audio
Power Supply SilverStone Strider 650W Platinum (ST-65F PT)
Mouse A4tech Bloody V3M
Keyboard HyperX Alloy Elite RGB - Mechanical
Benchmark Scores http://i.imgur.com/0O79u7Z.jpg
well i got the same ram last month but sold recently. kingston HyperX FURY @1600mhz can easily OC to 1866 @ 9-10-9
how you do it.
  • Select your desire speed you want i:e 1866
  • Goto DRAM Config/Timings
  • Set timings as 9.10.9 or 10.11.10 which ever stabled for you RAM.
Dont touch volts. 1.5v enough for it. or if you face BSOD then try for 1.60v for DRAM.
66 (0.02/day)
how you do it.
okay thanks alot i will try it tommorow and report here :)
