Koolance Intros Full-Coverage Water-Block for Radeon HD 6990
47,243 (7.55/day)
Water cooling expert Koolance is ready with its full-coverage water-block for the dual-GPU AMD Radeon HD 6990 graphics card, which was launched a little earlier this month. The VID-AR699 from Koolance covers the obverse side of the PCB, cooling critical components there, including the two AMD Cayman GPUs, memory chips, the 450W-capable VRM, and the PEG bridge chip. Internally, the block is partitioned into three distinct bases, one over each GPU, and one over the VRM. The portions over the GPUs feature ribbed micro-fin structures to improve heat dissipation. The three bases are conjoined by a middle-plate that channels coolant through the three bases. The block is then topped off with acetal.
The VID-AR699 measures 10.1" x 4.8 " x 0.8" (25.7cm x 12.2cm x 2cm), and weighs 2.25 pounds (1kg). Its primary material is copper with nickel-plating that minimizes corrosion over time. Its nozzle threading is standard G 1/4 BSP, though the package doesn't include nozzles. Koolance is pricing it at US $159.99 on its online store, it will be taking orders and shipping only after the 28th of this month. In related news, Koolance also announced that it's working on a full-coverage water block for the NVIDIA GeForce GTX 590, the VID-NX590, though there are no specifications or photos out, yet.
8,521 (1.38/day)
Kansas City
System Name The Dove Box Rev 3.0
Processor i7 8700k @ 4.7GHz
Motherboard Asus Maximus X APEX
Cooling Custom water loop
Memory 16GB 3600 MHz DDR4
Video Card(s) 2x MSI 780 Ti's in SLI
Storage 500GB Samsung 850 PCIe SSD, 4TB
Display(s) 27" Asus 144Hz
Case Enermax Fulmo GT
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1200W
Keyboard Logitech G510
Software Win 10 64x
EK blocks are sexier. :p
EK fanboi out...
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
I've never come across a Koolance product that sucked. They really do pump out some good hardware, though not always the best.
3,016 (0.53/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
LOL so you never used a koolance fitting?? because up untill like a year ago they all used to rust out, along with their RADS and it has been like 3 years now since they fixed their blocks but all their blocks used to rust out as well.
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Yep, you just jogged my memory... I did have a rust issue with some of their barbs. And the 345 block I'm using hasn't been taken out since it was installed. I think it's plated copper, so I'm safe - I hope.
43,606 (6.50/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Koolance used to abide by the brilliant idea of using both copper and aluminum. Corrosion time!
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
The rust on the barbs was defintely poor steel and/or shitty job of chrome or nickel plating.
My first watercooled rig was a Koolance PC2 and for it's time, excellent. Gold plated copper or steel and very durable, never had an issue and used it for 5 years! Year 5 ... one of the pumps started to go. :wtf:
bear jesus
1,534 (0.29/day)
Britland
System Name Gaming temp// HTPC
Processor AMD A6 5400k // A4 5300
Motherboard ASRock FM2A75 PRO4// ASRock FM2A55M-DGS
Cooling Xigmatek HDT-D1284 // stock phenom II HSF
Memory 4GB 1600mhz corsair vengeance // 4GB 1600mhz corsair vengeance low profile
Storage 64gb sandisk pulse SSD and 500gb HDD // 500gb HDD
Display(s) acer 22" 1680x1050
Power Supply Seasonic G-450 // Corsair CXM 430W
I have to say i really dislike the broken up blocks, I'm just about to get in to water cooling so i have no experience but to me it seams like the more seals and joints you have the higher the risk of a leak.
This has at least 4 seals and i would be much more comfortable with either one or two max.
2,667 (0.43/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
is a great waterblock is a very sophisticated engineering, we need a key to tighten the bolts with the right amount of pounds, such as those that use mechanical when tightening the wheel nuts. And the risk of loss is averted
9,899 (1.70/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Don't worry about it man, how often have you had leaking pipes in your house for example ( in my house NEVER, leaking taps loads though :laugh:)
So many joins between pipes yet no leaks : ]
Stationary seals last for years and years and years.
Wile E
Power User
24,318 (3.67/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Koolance has really turned their water cooling quality around. Their gear is in the top tier these days, and their customer service is fantastic.
bear jesus
1,534 (0.29/day)
Britland
Very true although part of my reasoning was to do with cleaning, for one the more parts the longer it takes to clean but it is after cleaning that i would worry about the seals the most as they are all factory tested but once i start screwing around with it the more seals there is the more likely i would be to screw up causing a leak.
I'm pretty sure if i opened all the seals on the pipes in my house then put them back together i would find a leak :laugh:
9,899 (1.70/day)
Essex, England
System Name My pc
Don't open it up to clean it, just run a clear loop for 24 hours : ]
bear jesus
1,534 (0.29/day)
Britland
OK you win :p
But i would still choose a solid block like the EK one for the 6990 as i guess that's just my preference as i like the look more than the broken up blocks and more so as i like the clear acrylic or Lexan/Delrin tops so can see the block under it.
