Koolance Intros Water Blocks for GeForce GTX 400 Series
46,892 (7.62/day)
Koolance is ready with water blocks designed for NVIDIA's GeForce GTX 480 and GTX 470 graphics cards. The Koolance VID-NX480 and VID-NX470 are full-coverage water blocks that cool all vital heat-producing components on the obverse side of the PCB, including the GPU, memory and VRM areas. Both measure 6.25" x 5.75" x 0.62" (15.9cm x 14.6cm x 1.6cm), weighing 1.5 lbs (680 g), slim and light enough to make the card occupy a single expansion slot. The block makes use of nickel-plated copper, with an acrylic top. The area over the GPU has an array of 0.5 mm micro-fins that increases surface area for heat dissipation. While the VID-NX480 is priced at US $119, the VID-NX470 goes for $109, as listed on the company store.
396 (0.07/day)
System Name Just A Gaming Rig.
Processor AMD FX-8320 @4.1GHz, 1.268V
Motherboard ASUS M5A97 Evo R2.0
Cooling Cooler Master Hyper 212 Evo
Memory 8 GB Crucial Ballistix Sport 1600MHz
Video Card(s) Club 3D R9 280X 3GB royalQueen, @1115/1615MHz
Storage OS+Often used stuff: Kingston SSDNow V300 120GB, Mass storage: WD Blue 1TB
Case Zalman Z3 Plus
Audio Device(s) Integrated
Power Supply Corsair CX600M
Software Windows 8.1 64-bit
Probably still going to have temps over 60 :laugh: A Vapor-X Radeon card can achieve the same temps.
1,971 (0.35/day)
Bulgaria
System Name penguin
Processor R7 5700G
Motherboard Asrock B450M Pro4
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
Wouldn't the GTX480 one fit the 470 as well?
396 (0.07/day)
Case Zalman Z3 Plus
GTX480:
GTX470:
It looks like the PCBs are different to me. I'm not sure though.
5,226 (0.86/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
That 480 block looks badass with the blue acrylic.
HillBeast
407 (0.08/day)
New Zealand
System Name Kuja
Processor Intel Core i7 930
Motherboard Gigabyte X58A-UD3R
Cooling Corsair H50 HB.o Special Edition with Koolance CHC-122 NB Block
Memory OCZ Extreme Edition 4GB Dual Channel
Video Card(s) Sapphire Radeon 5870 Vapor-X Rev. 2
Storage 2x 1TB WD Green in RAID
Display(s) BenQ V2400W
Case Lian Li PC-A17 HB.o Special Edition
Audio Device(s) Onboard Realtek 889A
Power Supply Gigabyte Odin Pro 800W
Software Windows 7 Professional
Benchmark Scores 93632 sysPoints in sysTest '09 47 FPS in Star Tales Benchmark
Personally I think their Radeon 5870 blocks look nicer, but that's just me. Most likely these will need a pretty beefy radiator to keep them cool, especially if you SLI them (or go with EVGAs new 4 way SLI :p). I think you will be steam cooled rather than water cooled. :laugh:
HillBeast
407 (0.08/day)
New Zealand
System Name Kuja
Depending on how the mounting works it might work. I know they made the 5870 block work on the 5850, but that's mainly because ATI did the PCBs really similar.
MKmods
Case Mod Guru
5,697 (0.95/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
great job on the pricing, I am not a fan of acrylic, I would like to see how the top is made..
Those definitely should to go into a BTX style case
EDIT:"The top stainless steel cover plate protects an LED illuminated acrylic lid."
ACEkombatkiwi
17 (0.00/day)
System Name Average Joe
Processor Core i7 975 @ 4.6GHz 1.2v
Motherboard Asus Rampage 2 Extreme
Cooling EK Supreme HF - EK FC6970 - XSPC RX480 - XSPC RX240 Dual loop
Memory 6x2GB Dominator GT 2000Mhz 7-8-7-20
Video Card(s) CFX Asus 6950s 840c/ 1325m MAX in CCC
Storage 3x OCZ Vertex 2 E 120GB raid0
Display(s) 3x ViewSonic VP2650wb 25.5" 5760x1200 Eyefinity
Case Silverstone TJ07 Black custom
Audio Device(s) Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Power Supply Silverstone Strider 1500w
Software Windows 7 Ultimate x64 retail
Wile E
Power User
24,318 (3.72/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Meh, take out the cheesy LED crap and give us a delrin version please.
46,892 (7.62/day)
