Laminar SF60
8 (0.00/day)
System Name Laminar SF60
Processor i7 4770K at 3.7 all the time :P
Motherboard ASUS Sabertooth Z87 (1803 BIOS)
Cooling Silverstone Fans x 3, Thermal Right CPU Cooler, Noctua Fans x 3
Memory 8gb Corsair XMP 1600mhz 2x4gb CMZ8GX3M2A1600C8
Video Card(s) 2x Gigabyte HD5850 1gb in crossfire (one bridge)
Storage 1x Samsung Pro 840 256gb SSD
Display(s) 2x ASUS ML248 - 1080p/LED
Case Silverstone FT02
Audio Device(s) Roland Quad Capture + DBx PA+ Loudspeaker Management System + Alesis M1 Active Mk2
Power Supply Corsair HX750
Software Windows 8.1 Pro 64bit
Specs:
i7 4770K at 3.7-3.9ghz at idle/load, speedstep disabled and XMP enabled.
Asus Sabertooth Z87
2xGigabyte HD5850 in Crossfire - standard clocks
1x Samsung 840 Pro 256Gb SSD for Everything
Silverstone FT02 Case
Corsair HX750 PSU
Cooling:
3x 180mm Silverstone Case fans (stock positive pressure)
1x Noctua PWM NF-F12 for CPU cooler
1x Noctua PWM NF-S12A for Top Exhaust Fan
1x Noctua NF-A4x10 for motherboard cooling
LG Blue Ray Drive
Sound-card/Sound Setup:
Roland Quad-capture, Dbx PA+ Loudspeaker Management System, Alesis M1 Mk2 Monitors, Custom XLR/TRS Cables all around.
Mods:
Noctua NF-A4x10 installed for Asus Armor - exhausting out the top instead of there stupid "intake" recommendation noisy POS - new fan runs at full power and can't be heard.
Deleted central assist fan.
Full Software controlled fan speed for 7x fans (6 channels) via SpeedFan.exe - GPU, CPU and SSD all control and maintain fan speed - completely automated like a HP server cooling system or such.
CPU cooler chosen for constant physical characteristic that all the heat-pipes go horizontal or up - nothing against physics, the cooler is set back design that was a clear winner.
Case also chosen to aid in HD5850 cooling, by just rotating them so they hang has dropped temps by 10°C as the heat-pipe now "rises" from source to heat-sink at the top, gaming at 30% fan speed with crossfire with 60°C no matter what (30°C ambient temps)
Sleeving of most cables where possible to hide stock colored fan wiring.
All Cables hidden as much as possible
8 (0.00/day)
Please Note:
1) Second Crossfire Bridge Removed some time ago
2) Stock Silverstone golf ball and Thermalright fans in full picture are replaced as of today with Noctua
3) Central Asus Assist Fan Deleted
12,307 (2.31/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
I think Silverstone knows how to set up cooling
8 (0.00/day)
Definitely :) i was so glad i purchased this case, its cool to think even new today it is already 5 year old tech from silverstone yet so visionary
