LAN-Party Laptop 2015
105 (0.02/day)
Specs:
Motherboard: ASUS A8N-SLI EAYE Rev 1.02
Chipset Cooler: Cooler Master Northbridge Chipset Cooler
Processor: AMD Athlon 64 3000+ 1.8 GHz 64 bit 512KB 67 Watt Socket 939
Memory: elixir PC3200U 512MB DDR-400MHz CL3 Kit of 2
Graphics Card: ATI CGA-928PTVD Radeon 9200SE 128Mb DVI TVout PCI 3.0
Hard Drive: WD Green WD60EZRX SATA 6 Gb/s 3.5 Inch IntelliPower 6 TB 64 MB
Power Supply: be quite! DARK POWER PRO 750 Watt
Case Fan: Cooler Master 80mm Fan LED Silent Blue TLF-S82-EB
Case Fan: DELTA DC BRUSHLESS BFB0712H Fan MILL
HDD Cooler: Cooler Master 70 mm PCI Slot Fan
CPU Cooling: be quiet! SHADOW ROCK TOPFLOW CPU Air Cooler
Monitor: Acer T230H Touchscreen
For my “LAN-Party Laptop 2015 - Portable High-end Gaming Case Mod” I have use an Aluminum Suitcase and cut out some holes so it is possible to mount the hardware inside the case and making it possible to ventilate the case as well. I have used some Cooler Master Case Fans to keep it "COOL".
I have build it up with an OLD MB & VGA CARD but maybe later on I will upgrade it to some more powerfull. For this reasone I have installed parts of an motherboard tray so it's easy to upgrade the hardware.
4,267 (0.68/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Cool stuff.
For bonus points, can you store the keyboard and mouse inside during travel? :D Looks like you could add a couple rubber straps to the lid to secure the keyboard. When closed it would be over the add-in cards and hard drives.
105 (0.02/day)
Cool stuff.
Hi Jizzler,
Thanks for coming back to my Case Mod!
No, There is no space for keyboard and mouse it is really packed - there is not match space left.
But better Motherboard and Graphics Card would be nice and some SSD.
It is also really heavy. There are not that many holes in the suitcase - I want it in this way so it is more portable.
I need to run it open otherwise it gets to hot but this is no problem for me. I built it for the Cooler Master Case Mod contest.
VIDEO:
658 (0.18/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl16 - 32gb
Video Card(s) 6800xt
Storage nvme 1TB + ssd 750gb
Display(s) xg32vc
Case hyte y60
Power Supply 1000W - gold
Software 10
lol
i dont know who can give 10 for this garbage ?
some silly case and inside staff 15 years old. WRONG PLACE WRONG TIME
AND WHY FOR THIS MEGA BUILD NEED 750W PSU ?
105 (0.02/day)
lol
I plan to upgrade the MB & VGA that is the reason for the 750W.
Please note:
