Laptop Fan Control
33 (0.04/day)
System Name Dreki (https://pcpartpicker.com/b/ZDCLrH)
Processor AMD Ryzen 7 2700
Cooling ID Cooling SE-224-XT Basic
Memory Corsair Vengeance LPX 4x16GB DDR4-3200 (Running @ 2133 Because of MOBO Issues - Documented on PCPP)
Video Card(s) MSI Radeon RX 6800 XT Gaming X Trio
Storage WD SN770 2TB NVME SSD
Display(s) Viewsonic VP2768 27" 1440p Calibrated Display
Case Cougar MX330
Audio Device(s) Zoom AMS-24
Power Supply Corsair RM750X (2017) 750W
Mouse Cougar Minos X3
Keyboard Cougar Attack X3
Software Windows 10 Home, Davinci Resolve Studio, ON1 Photo Raw 2023
I have an Asus ROG G15 AMD Advantage Edition Laptop. 5980HX with an RX 6800M. I would like a way to set a custom fan curve without using Armoury Crate. It seemed to really bog the system down and was overall overkill for a hardware monitor / configuration tool imo. If you think I am mistaken in that conclusion, let me know please. One thing it did have was a fan control option where I could set a curve. Having removed it completely from my system and disabled it in the BIOS, I would now like to find a simple fan control software that won't bloat my system.
Any suggestions? The fans ramp up pretty much immediately upon startup and don't slow down until I turn it off. Just scrolling in task manager with all other apps closed is enough to get them rolling pretty good.
Upon googling, I have found plenty of suggestions - but I am unsure which ones would actually be good, from reputable suggestions, and which ones are potentially malware/ransomware. I do have Norton, so not a massive risk - but I still like to avoid such things.
198 (2.57/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
31 (0.41/day)
System Name Lenovo Legion 5 17ach6h
Processor AMD Ryzen 7 5800H
Cooling Standard + PTM7950
Memory 32GB DDR4-3200
Video Card(s) NVIDIA GeForce RTX 3060
Storage 2x 1TB Samsung NVMe
Display(s) 27" ASRock FHD IPS
Mouse EVGA X20
Keyboard Redragon K530 Pro Draconic
Sounds like a thorough cleanup and repaste is in order. Unless you were monkeying around with settings that have the fans running full tilt all the time?
If you're certain it isn't the latter, then I suggest the former be done first.
33 (0.04/day)
Case Cougar MX330
I have never done that to a laptop before. I have had this just over a year and it has done it pretty much from the start. I have the laptop set to balanced in Windows Power settings.
I like this. I've used it on quite a few laptops of varying sorts.
https://github.com/Rem0o/FanControl.Releases
its just called FanControl, works well.
there is also this
https://github.com/LibreHardwareMonitor/LibreHardwareMonitor
If you really need nitty-gritty control of things, but be prepared for a more complex setup process with Libre Hardware Monitor.
I tried both, but my laptop doesn't seem to allow any control of the fans manually. No fan controllers come up to manipulate the speeds. Guess I am stuck with vanilla settings.
31 (0.41/day)
Mouse EVGA X20
It isn't hard, and I'm sure you could find a teardown video online. If you're skiddish, you could probably find someone local.
Your fans shouldn't be doing that all the time. Do you have any temperature monitoring software installed? I would be interested to see what temps look like under load.
6,375 (1.12/day)
Midlands,UK
System Name Ultraman
Case Alienware X16
33 (0.04/day)
Case Cougar MX330
I use this on my Zephyrus g14:
A light weight version of armoury crate.
I'll look into this. I had armoury crate running before to control stuff and silent mode was the only thing that ever made them slow down. Even on silent mode it would still crank the fans sometimes. It seemed like AC was taking a lot of processing power a lot of times. If it was open, it would show like 3-4 different related tasks running in task manager and collectively they could be bumping the CPU up to 20% or even more sometimes. Seemed dumb and unnecessary. Especially with a 12-core 5980HX.
