T0@st
- Mar 7, 2023
- 2,925 (3.79/day)
- South East, UK
Cooling | DeepCool AS500 |
Mouse | Roccat Kone Pro Air |
It was reported earlier this morning that Leadtek was preparing a new custom design NVIDIA GeForce RTX 4070 graphics card - Tom's Hardware pointed out that South Korea's National Radio Research Agency had uploaded a registration for a "RTX 4070 AI BLOWER" VGA card on behalf of "Leadtek Research Inc." The article delves into a possible scenario, based on the model name alone, of Leadtek producing a cooling solution that reflects NVIDIA's blower-style reference design. Team Green has gained quite the reputation for being protective of that blueprint, despite its Founders Edition lineup of gaming-oriented cards shifting to a traditional cooling solution (back in the RTX 20-series days). Board partners are normally expected to devise their own/unique cooling solutions, and NVIDIA has mostly reserved the blower + vapor chamber combination for its professional GPU model lineups.
Leadtek has created a product page for their new custom card this afternoon, and it is immediately clear that this morning's prediction was somewhat correct. The WinFast RTX 4070 AI BLOWER 12G sports a "streamlined" yet boxy black cooling solution that appears to be closer in appearance to an NVIDIA RTX A-series professional card, although a flash of silver trim and logo on the fan provides a bit of "gamer" visual language. Leadtek's specification info states that their AI Blower cooler features an aluminium die cast housing alongside a copper finned vapor chamber. The lone mounted fan is said to have a 50,000 hour operational lifespan thanks to a special internal arrangement: "WinFast double ball bearing fan provides better reliability, higher dust resistance levels, and moreso keeps friction and noise to a minimum." Tom's Hardware posited that Leadtek's custom card would be marketed as an enterprise product (for AI processing) - the freshly uploaded product page does position it for those purposes, but the rundown also mentions its supposed gaming performance prowess.
Graphics Processing Unit (GPU): NVIDIA GeForce RTX 4070
Bus Interface: PCI Express 4.0
Memory Configuration: 12 GB GDDR6X
Core Clock Base clock: 1920 MHz
Boost clock: 2475 MHz
Memory Speed: 21 Gbps
Output Ports: 1x HDMI (2.1), 3x DisplayPort 1.4a
Maximum Digital Resolution: 7680x4320
Memory Interface Width: 192-bit
Memory Bandwidth: 504 GB/sec
CUDA Cores: 5888
HDCP Support: Yes
Microsoft DirectX Version: 12 Ultimate
NVIDIA RTX NVLink: No
OpenGL: 4.6
Maximum Power Draw (Watts): 200 W
Dimensions:
265 mm (length) x 111 mm (height) x 38 mm (thickness)
Package Contents:
Requirements
CUDA Cores: 5888
HDCP Support: Yes
OpenGL: 4.6
Dimensions:
Package Contents:
- WinFast RTX 4070 AI BLOWER 12G Graphics Card
- Quick Installation Guide
- Power Cable
Requirements
- Microsoft Windows 10, Windows 11 and Linux operation system (64 bit)
- PCI-Express compliant motherboard with one four-width x16 graphics slot
- One 8-pin PCI-Express supplementary power connectors
- 8 GB system memory (16 GB or higher recommended)
- 1.5 GB of available hard disk space
- A DP or HDMI compatible monitor
- Minimum 650 W Power Supply
