Leakers Record 90°C+ VRAM Temperatures on Unnamed Radeon RX 9070 XT Custom Cards
T0@st
2,580 (3.53/day)
South East, UK
Cooling DeepCool AS500
Mouse Roccat Kone Pro Air
The Chiphell forum has provided a steady flow of AMD RDNA 4-related leaks—going back to early December; members believed that "Radeon RX 8800 XT" GPUs were imminently entering into a mass production phase. Since then, Team Red and board partners have officially revealed a full deck of Radeon RX 9070 XT and RX 9070 models—complete with a "modernized" naming scheme. By Christmas (2024), insiders appeared to have working units in their clutches—denizens of Chiphell have continued to dole out pre-release info; even deep into launch week. UNIKO's Hardware picked up on the latest signals; with owners of unnamed custom Radeon RX 9070 XT cards: "calling out bad cooling on GDDR6 VRAM."
As highlighted by Wccftech, NDA-busting disclosures have alluded to commendable GPU thermal measurements—when driven at full load—but several leakers have noted less than stellar results from VRAM temperature readings. Chiphell-sourced GPU-Z screenshots indicate a maximum recorded VRAM temperature of 94℃, with the involved GPU's hotspot hitting a top temp of 79°C. This leaked candidate seems to be a 329 W TBP-rated model. Wccftech observed inconsistencies with the other evaluated sample: "under full load, the GPU temperature at the hot spot reaches a max of 63°C but the memory temperature touches 88°C. The surprising thing to note in the first case is that the TBP is only 237 W, which seems weird considering the Radeon RX 9070 XT (reference spec) starts at a TBP of 260 W. This might be a bug...The user has confirmed that the first one isn't the RX 9070 as one would think, but it is the RX 9070 XT as well." The "guided" upper limit for newer VRAM standards is 95°C, so one of the anonymous custom cards is dancing dangerously in close proximity to the proverbial flame. Certain hardware news outlets reckon that GDDR6X memory will succumb to damage once a 120°C ceiling is hit. Hopefully, these issues are limited to a handful of review samples—a couple of AMD's trusted board partners have opted for Honeywell PTM7950 thermal pads and robust heatpipe formations. Stay tuned to TechPowerUp for W1zzard's incoming RDNA 4-related verdicts.
According to Uniko's translation, the founder of Chiphell commented (in full) on the VRAM cooling situation(s): "previously, I only paid attention to the GPU temperature and ignored the video memory. The result is good... The video memory of several brands I have is extremely hot... One is 88℃ and the other is 94℃... It's really like going back to the mining era overnight...I suggest that you don't rush to pay attention to the evaluation of No. 5 to see if it is a common phenomenon or an individual case. If it is an individual case, you can avoid it when choosing a card."
freeagent
9,976 (4.22/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Some things don't change I guess.
Lazy.
228 (0.14/day)
Probably an early version of an engineering sample...unlikely to be those temps with proper cooling...
743 (1.11/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
Eh isn't GDDR6 rated at something like 110c and usually runs high 80's/90's in most cases, the NDA hasn't even been lifted and all the negative nellies are rubbing their hands with glee and declaring them a failure already
:kookoo:
11,043 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
i remember my HD 4800 crusing at 115C vrm - and them being like - "it's fine bro, they're good up to 120C then it will throttle"
AFAIK 90-100C under load for VRM is actually pretty normal.
9,738 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
90-95C is fine for memory but what even is the point of having those gigantic 3 slot gazillion heat pipe, flow through, optimized fan blade blah blah if it amounts to nothing ? My reference 7900XT had similar temps but it was a compact 2 slot cooler. AIBs are charging massive price premiums for nothing.
77 (0.03/day)
Fan speed seems low at 1200 RPM for full load. Then again, the GPU core is pretty low in temp considering the fan is operating at a low RPM. Maybe this is some sort of alternate "quiet" BIOS on a card.
438 (0.15/day)
Processor Ryzen 5700X
Motherboard Gigabyte B550 Arous Elite V2
Cooling Thermalright PA120
Memory Kingston FURY Renegade 3600Mhz @ 3733 tight timings
Video Card(s) Sapphire Pulse RX 6800
Storage 36TB
Display(s) Samsung QN90A
Case be quiet! Dark Base Pro 900
Audio Device(s) Khadas Tone Pro 2, HD660s, KSC75, JBL 305 MK1
Power Supply Coolermaster V850 Gold V2
Mouse Roccat Burst Pro
Keyboard Dogshit with Otemu Brown
Software W10 LTSC 2021
thats literally normal lol, some even get close to 105, cause guess what its fine, most people are more likely to ruin the vrm from using shit psus than from the caps dying
1,229 (0.73/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Ventus 3060 / Challenger B580
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
Look at the core clocks.
Look at the fan speeds.
I'll bet they're running a memory-intensive benchmark which doesn't challenge the cores much so the fan speed stays low and the memory heats up more than under a typical load.
Besides those temps being within the safe range anyway.
743 (1.11/day)
Here's your
Hungry Food GIF
To go sir :rolleyes::laugh:
freeagent
9,976 (4.22/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
100c is pretty gross though.
1,229 (0.73/day)
These are even more useless screenshots that I initially thought.
237W used at only 0.71V with 1693 MHz clock speed? Yet with a 45% memory controller load. Please explain the conditions under which a card does that. Never in a game, maybe when running other loads?
And the same for 329W at a mere 0.73V and 2028 core clock, but somehow with a 60% memory controller load. Again, in no game that exists.
These screenshots are irrelevant until someone can explain how to generate this type of load.
1,766 (1.09/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Honestly, I see no reason for concern. GDDR6 gets hot when pushed.
The highest I've seen on my stock MBA 7900XTX (355 W) was 71 - 89 - 94 C for edge, hotspot and VRAM respectively. According to HWinfo, the limit is 110 C for hotspot and memory. The fans were going up to 68% on the default curve. With a more aggressive profile the temps could have been lower.
This was pretty much a worst case scenario, tested in a 28 C room with the card pumping 350 W all the time, with a reference cooler.
Judging by the low memory used I suspect Furmark.
2,278 (1.22/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
Drip, drip, drip, time to go look at a bunny.
32 (0.01/day)
Earth
System Name Main
Processor Ryzen 5800x
Motherboard Gigabyte Aorus Pro rev1.1
Cooling Alphacool Eisbaer 280 w/ 2x Noctua NF-A14 industrialPPC-2000 PWM
Memory Crucial Ballistix 32GB 3600@CL16 (2x16)
Video Card(s) Power Color Red Dragon RX 6800 XT @2600
Storage NVME: A-data SX8200 PRO 512 GB M2 +Gammix S11 Pro 1 TB M2 +Patriot 1 TB; 1 TB;HDD 3TB+2TB+4TB+8TB
Display(s) Lenovo Legion Y27q-20
Case Thermaltake Core X9
Power Supply Seasonic FOCUS GX GOLD 850W /UPS Mustek 1000 VA @600W
Mouse Steelseries Rival 110/Logitech G203
Keyboard HyperX Alloy Core RGB
Software W10 Enterprise
GDDR6 is rated at 120° C max (critical). I've run benchmarks with my VRAM going up to 115° C.
1,229 (0.73/day)
It's been a long time since I last used Furmark as it's so useless. But I should try it out again on a few cards just for familiarity's sake.
7,780 (5.08/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Big bunch of nothing. RTX 3090 had VRAM temps in the range of 100 regularly, the cards can take it. Warm memory (up to a point) is no cause for alarm.
1,839 (0.60/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
freeagent
9,976 (4.22/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Like people making assumptions based on absolutely zero empirical evidence?
All one has to do is look to the past.. in this case, we don't have to look far.
743 (1.11/day)
Yea, I mean I would take melting connectors, 600w consumer GPU's, less ROP's, no/less performance/$ upgrade over last gen, black screens, 30% higher real world prices vs MSRP over silly high 95c vRAM, stupid AMD, no wonder they are going bankrupt, they are so dumb, I hate them so much, YAY NVIDIAAAAAAAAA the way you're meant to get bummed :laugh:
Costume Party Laugh GIF by Halloween Party
freeagent
9,976 (4.22/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Lol you are such a tool :laugh:
