[Case Gallery] Lego PC 1.0
10 (0.00/day)
Specs:
AMD Athlon II 605e(2,3 Ghz, quad-core)cooled by Hiper Low-profile full-copper cooler
Asus M4a88T-I Deluxe, Mini-ITX, AMD 880g, WiFi-AP, Bluetooth, Sata3, USB 3.0
2x4GB Kingmax SODDR3-1333
2x250GB Samsung 2,5", 7200rpm, 16MB cache, RAID 0
Optiarc slim slot-in DVD-RW
ATI Radeon HD 5570 1GB DDR3
Enermax Enlobal 120x120mm adjustable fan on top
2x10cm Revoltec white CCFL neon
Mods:
The entire casing is made of LEGO bricks, there isn't a single screw, or soldering, or glue. It's completely deconstructable. The fan is blocked by 4 silicon fan mounts, which also provide vibration absorption. All the hardware components are blocked, once it's closed there isn't a single piece free to move (except for the fans :) )
This is how my previous case mod should have been in the first place, last time i just started putting lego bricks together, and the outcome was unpredictable. This time i had my previous work to learn from, and i made some adjustments. The case isn't on a platform anymore, it measures 26x26x13 bricks ( roughly 207x207x116 mm ) and with better wire placing and disposition of the components (expecially the dvd burner and the disks) i was able to squeeze in a 120x120x25 fan, and 2 small 10 cm white neons. The hardware is the same of the previous mod ( still comfortably below 120w of total power consumption) but this time i managed to make it more... solid. this time the on/off switch module is perfectly blocked by the bricks, the same goes for the power plug and the VGA port of the discrete video card. The drilled bricks this time help the air flow, letting air come out from the side since the fan is sucking the air in from the top, and the neons have a O/I switch so they can be turned off. I provided some pics in a dark room, and the effect is quite something :)
With the big fan set to minimum, the noisiest thing is... the external power supply, and Everest tells me it runs pretty cool.
Last but not least, this time i retrieved enough bricks to give the case a more rational layout, the first 4 layers are intentionally whole, the upper layers are drilled for air flow, each layer maintains the same color... if you liked the last one, hope you'll like this even more :)
1,644 (0.31/day)
I'm roomates with Corey Feldman
Processor W3520 Xeon
Motherboard Asus Sabertooth X58
Cooling Cool it Vantage
Memory 6gb Dominators
Video Card(s) GTX 460
Storage 60Gb Vertex II 500Gb storage
Display(s) LG 42LH40 42" 1080P
Case 932 HAF
Audio Device(s) Voices in my head
Power Supply Raidmax730/
Software Win7Pro64
Benchmark Scores Pretty High one's. but it's not a contest/ I just read them for the articles.
original and nice!
Edit: How can i Post here while on a Points Vacation.... Gerald Devides by ZERO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
10 (0.00/day)
Hi, thank you!
No, legos don't get hot, in fact they don't even get warm except for the ones on the left side, near the gpu heatsink... you can feel the air flowing out of the drills on the other 3 sides, and since the fan is manually adjustable, even if things might get hot, with a couple of minutes of maximum fan speed the system will definitely cool down... i tried playing Starcraft II (1920x1080, medium details), and temperatures were definitely below warning, with the fan at minimum speed.
Since i have a spare 32 gb SSD, i'm going to switch the 2x250gb 7200rpm raid 0 hard drives with a 32gb SSD + 640gb 5400 rpm single hard drive... all in 2,5" form factor, so the difference on the storage disk won't be much worse, but the OS partition wil get an amazing boost, and the SSD draws even less power and will always run cooler :)
EMObang
1 (0.00/day)
California
What kind of keyboard is that, looks cool. Nice use of Legos, wish I could do that.
10 (0.00/day)
hi, the keyboard is this one
http://www.trust.com/products/product.aspx?artnr=14909
it has an integrated trackball, and the mouse buttons are on the upper left and right corner of the keyboard chassis; it is cool, but the keys could be a little too close if you use it for serious typing(i can't type well on that, but maybe it's just me :) ) ... in my ideas its purpose was to be placed in the living room, witht the pc attached to the tv, and to be used on the couch while watching some movie/internet/playing some game, so it's perfect :)
Funtoss
588 (0.12/day)
New Zealand
System Name My Heater
Processor Intel Core 2 Quad Q6600 @ 3.2ghz
Motherboard Asus P5B-E Plus
Cooling Zalman CNPS 9700 NT
Memory Patriot 4GB 800MHz DDR2
Video Card(s) EVGA GTX 460 1GB
Storage 2x Western Digital 640GB (1.28TB)
Display(s) Viewsonic VX2349wm 24"
Case Raidmax Hurricane
Audio Device(s) C-Media 8738
Power Supply Aywun Megapower 650w 80+
Software Windows 7 64 Bit
Tutorial for this please!!!! Very very nice! :)
1,555 (0.26/day)
Shepparton, Victoria, Australia
System Name Toaster!
Processor Intel Core i7 10700KF @ 3.8/5.1GHZ
Motherboard ASUS Prime Z490-P Motherboard
Cooling Noctua NH-D15 CPU cooler.
Memory G.Skill Trident Z RGB 64GB (4x16GB) 3600MHz CL16 DDR4
Video Card(s) ASUS ROG Strix GeForce RTX 3090 OC 24GB
Storage Samsung 970 PRO M.2 NVMe SSD 1TB
Display(s) Asus ROG PG43UQ 4K UHD 144Hz G-Sync HDR 43in + 2 x ASUS VG258Q FHD 144Hz Freesync 25in Monitor
Case Corsair Obsidian 900D
Audio Device(s) EPOS Sennheiser GSX 1000 V2 amplifier + EPOS Gaming GSP 601 Headset
Power Supply Corsair AX1000 Titanium Modular
Mouse Razer Deathadder
Keyboard Corsair K70.
Software ALL HAIL WINDOWS 10.
Benchmark Scores Old system: http://www.3dmark.com/fs/6805248
Did u insulate the lego against the heat somehow?
manofthem
WCG-TPU Team All-Star!
10,960 (2.18/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Pretty awesome, Legos FTW
10 (0.00/day)
no insulation needed, the rig itself runs cool (once i added the 120x120 fan :D), keep in mind that overall the system draws less than 120w, the athlon x4 is a 45w cpu, the gpu draws 20something w tops, ram is SODDR, hard drives are 2,5"... cpu heatsink is full copper (i never said the pc was lightweight :) but since it's not near the brick there's no issue...
My first attempt, with no case fan, overheated and went in heat protection shutdown after about 2 hours due to chipset temp issues, no air circulation at all... the cpu and the gpu, however, have both active cooling, and they didn't reach high temps even in a "still air" case...
with that in mind, for this version i added the big fan (and i have to admit i got very lucky, a 120x120mm fan is exactly 15x15 bricks, so blocking it was much more easier than i thought :D ) and everything is cool even with the fan at minimum speed, as i said above the fan sucks the air from the top and the drilled bricks provide the exhaust, you can feel the air flow through your fingers if you put the hand close to one of the sides, and in normal use the system is almost inaudible, in long gaming sessions the gpu fan becomes a tad noisier, but it's a small price to pay for a discrete gpu (ati 5570 1gb ddr3) over the integrated one (ati 4290 shared memory from 880g chipset) :)
HookeyStreet
Eat, sleep, game!
7,122 (0.97/day)
Great Yarmouth, England
WOW! it's the first time I've seen one of those...........an original Windows 7 disc I mean :D
Seriously, great stuff :)
10 (0.00/day)
3 negs? i'm flattered :)
@marcello: it's built from scratch, and needs no tools to be assembled... maybe we disagree on "worthless"
@bambolina: it is a real pc, please write a real comment, man!!!!!
@bendtner: there are pics and a description, and you still don't know what this is... a hint: it's a pc.
unknown
1 (0.00/day)
Great Pc!!!
Extremely fascinating how far human creativity can go... Nice job Gi0v3, well done ^_^
To the 1/10's people... Are you jealous this pc runs better than yours??? XD
bobbys
1 (0.00/day)
f**** awesome! can u pls send me one for my bday?
cannot believe someone vote 1! shame on u!
10 (0.00/day)
my bad, i'm editing the description... anyway, there isn't a single screw that needs actual screwing, because silicon "screws" just need to be pulled... my point was: you can assemble it with your bare hands, no tools needed :)
btw, love metalocalypse \m/
970 (0.18/day)
Granby, Qc. Canada
System Name Loose nuts & bolts
Processor FX-8350 - EK Supreme HF full nickel
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Water EK goodness all around 2xBlack Ice X-280
Memory 2 x8G HyperX Fury 1600 @ 9-9-9-24-1T
Video Card(s) 2 x XFX RX 480 w/EK-FC RX 480 nickel+Acetal
Storage Samsung 850 Evo + 2xWD Black 500GB in RAID0
Display(s) Crossover 27" 2560x1440 110Hz OC
Case Cooler Master HAF XB EVO
Audio Device(s) on board
Power Supply Corsair HX850
Software Win 10 Enterprise x64
Excellent work gi0v3, I like the originality of it
2,047 (0.37/day)
Republic of Texas
Processor R9 5950x
Motherboard Asus x570 Crosshair VIII Formula
Cooling EK 360mm AIO D-RGB
Memory G.Skill Trident Z Neo 2x16gb (CL16@3800MHz)
Video Card(s) PNY GeForce RTX 3090 24GB
Storage Samsung 970 EVO Plus 1TB NVMe | Intel 660p 2TB NVMe
Display(s) Acer Predator XB323QK 4K 144Hz
Case Corsair 5000D Airflow
Audio Device(s) Objective2 Amp/DAC | GoXLR | AKG K612PRO | Beyerdynamic DT880| Rode Pod Mic
Power Supply Corsair AX 850w
Mouse Razer DeathAdder Elite V2
Keyboard Corsair K95 Platinum RGB "Cherry MX Brown"
VR HMD Oculus Rift
Software Window 11 Pro
epic win in my book, makes me wanna build mid size case lol, my son got crap load of lego
9,888 (1.86/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
wow that nice especially it aint glued at all, so if you go bored of this just make it pieces and build a brand new case again. very creative
1,221 (0.24/day)
Canada
System Name Brutus
Processor i5 4690k @4.7Ghz (Watercooled)
Motherboard z97 MSI Gaming 5
Cooling NZXT Kraken x61 AIO watercooler
Memory Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24
Video Card(s) MSI Gaming GTX 980ti x2 (sli)
Storage 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0
Display(s) YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440
Case NZXT Phantom
Audio Device(s) ASUS Xonar DX
Power Supply Antec TPQ 1200w
Software Windows 7 (64 bit)
I voted 3/10 because:
A square
10 (0.00/day)
2 times i have already told the moderators that there were several users posting negative comments and giving negative votes, and it seemed a little suspicious because they happened to post roughly at the same time, giving roguhly the same opinions... and 2 times the moderators told me they canceled multiple accounts from the same IP... but not once they canceled the multiple votes given by these multis, even if in one of the cases there are 6 votes from the same person... i asked the moderators to delete at least 5 of the 6, leaving the worst one... but i didn't even get an answer to that.
i understand that some people, many people in fact, may not like this kind of mod, and i'm fine with that... what i'm not fine with, is letting some people vote 6 times, and with multiple accounts, deleting the accounts and leaving the votes is quite useless... since this is far from fair, and nothing seems to be done even with evidence of biased votes, and it's been more than a month, i think i'm not going to post any new mods here anymore, lego or not lego, because there's no such thing as justice here.
i think there might be at least one more multiaccount within comments and/or votes to this case mod, but frankly this time i didn't even feel like PMing the moderators, seeing the old (but still illegit) votes still there made it look like a waste of time.
