LG Releases 34WP550-B Monitor: 34" IPS, 2560 x 1080, 21:9, 5 ms, 75 Hz, FreeSync
Raevenlord
3,755 (1.23/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
LG today announced a new addition to its productivity/entertainment-geared monitor lineup. The 34WP550-B monitor seems to be a pretty standard affair for any user that only casually games and isn't looking for the best refresh rates, but wants a solid, ultra-wide monitor to work and consume content in. The 34" diagonal presents images in 21:9 aspect ratio across an IPS-enabled 2560 x 1080 resolution. The refresh rate settles at a pretty standard 75 Hz, albeit with the support of FreeSync - hence the eventual casual gaming scenario for this monitor. The 5 ms response time is nothing to write home about either, but again - this isn't geared for gaming, and is more than sufficient for spreadsheet-processing.
Brightness is quoted at 250cd / ㎡ with a 1,000: 1 contrast ratio, 95% RGB coverage, and typical IPS viewing angles of 178º. I/O is assured by 2x HDMI in and 1x earphone. The LG 34WP550-B is expected to be available for $299/€299 - if you're looking for something to game on, you'd be much better served looking elsewhere, though this is a very nice aspect ratio.
982 (0.22/day)
System Name Poor Man's PC
Processor Ryzen 7 9800X3D
Cooling Thermalright Phantom Spirit 120 with Arctic P12 Max fan
Display(s) Xiaomi G Pro 27i MiniLED
Case Asus A21 Case
Mouse Logitech MX Anywhere 3
VR HMD Meta Quest 2
Nearly 2 years since 34UM69-G and no improvement been made? Basically just another rebadge eh?
17,433 (4.68/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
75hz? what century is this.
519 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
LOL it is not a gaming monitor ...
1,195 (0.27/day)
Processor AMD Ryzen 3700x
Cooling Deepcool LS520 SE
Video Card(s) RTX 3070 FE
Display(s) LG GL850
Case Dan A4 H2O
Power Supply Corsair SF600
Mouse MX master 3
Keyboard Master Key Mx
Software win 11 pro
The century of: "if it's not for PC gaming, it doesn't need high refresh rate" (phones are a different story)
4,679 (0.94/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
It's positioned as a replacement for business dual monitor set up and for $299, it's pretty solid
7,762 (2.78/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
75Hz as a new baseline is purely a good thing though, regardless of the use case. Even scrolling through web pages and text documents is noticeably smoother.
17,433 (4.68/day)
Reply
once you scroll on a 390hz monitor from Acer, there is no going back. 144hz looks blurry after 390hz.
Willy Wonka Reaction GIF
4,679 (0.94/day)
Reply
I have my monitor refresh rate set to ludicrous speed
Hello Kitty Adventure Island runs Butters smooth
7,762 (2.78/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
I would take a 60Hz non-PWM over 120Hz PWM display any day.
You must either have had some very poor pwm displays or be very sensitive to flicker. Even above 1kHz pwm should be unnoticeable, but of course going to 2k or even 10k isn't particularly difficult - and at 10k no human will ever be able to notice flicker...
Reply
Pretty sure diminishing returns kick in at some point there :p
2,508 (0.78/day)
I agree that it makes a noticeable difference at that end of the spectrum, but at the same time most 60Hz displays can end up doing 75Hz anyway. What we really need more of is displays pushing for a 90Hz to 96Hz baseline standard that would be a more pronounced difference.
