Lian Li Announces PC-V33 Compact Cubical ATX Chassis
47,171 (7.56/day)
Lian-Li Industrial Co. Ltd today announces the PC-V33. Available in 3 choices: brushed aluminum in silver or black, or internal black with a tempered glass side door. The PC-V33 does not restrict PSU, GPU or main board choice due to size or power consumption: it's designed to accommodate full-sized gaming hardware in a compact form-factor. Its cube styling makes it a companion you can take with anywhere you need full-sized computing and still have room for a 240 mm water cooling radiator to be mounted inside. The most unique feature is the canopy top that opens the whole cube for easy building.
The newly designed illuminated power button is now made out of the same high grade brushed aluminum as the whole case. The pop-out side doors detach and reattach effortlessly, yet remain firmly in place. The front and top panels form a canopy as a single fold of aluminum, adding strength and beauty to the cube case. When hinged open, the case internals become accessible in the same manner as a test bench, allowing system builders to install the components and change them with ease without any walls in the way. Dual 120mm case fans or up to a 240mm water cooling radiator can fit internally on the front bracket that also holds the magnetically attached air intake filter.
Dual Compartment Air Flow Management
The PC-V33 uses vents and internal compartments to manage heat and dust inside the case. The floor of the main board compartment acts as a barrier so CPU and GPU heat does not affect the PSU or drives. The included 120mm fan vents the top compartment through the newly designed rear vent. The bottom compartment filters air for the PSU that is vented right out the back. The drives have their own 120mm exhaust fan with the aggressive new vent hole pattern.
New Shock-Absorbing Drive Cage
The PC-V33 uses a new drive cage with the same rubber dampening system found in Taipei 101 to eliminate vibrations, ensuring the drives do not produce any noise. This cage can be half removed or fully removed for added flexibility. Horizontal mounting ensures air flow and correct alignment for long life.
Full ATX sized Hardware Compatibility
The PC-V33 supports up to a full ATX motherboard in the top compartment with pre-installed standoffs that fit mini-ITX, mATX and ATX motherboards. It can house CPU coolers up to 190mm in height and VGA cards up to 330mm long. The bottom compartment can fit up to a 300mm long PSU and any combination of 4 3.5" or 2.5" drives on the anti vibration cage.
Optional Adjustable RGB Interior Lighting
DIY enthusiasts can adjust the interior lighting through the optional RGB lighting kit complete with LED strips, cord clip, dimmer and controller. The rear mounted controller allows instant analog color selection. Guaranteed to fit and show off your custom interior.
Price and Availability
The PC-V33 will be available in the USA in early September for the MSRP of PC-V33A/B USD 199, PC-V33WX USD 229.
Random Murderer
The Anti-Midas
6,974 (1.07/day)
Florida, A.K.A. the Sweatbox
System Name TOO MUCH RADIATOR! | The TV Box a.k.a. The Shoebox
Processor Core i7 4930K @ 4.5GHz | Core i5 6600K @ 4.5GHz
Motherboard Asus X79 Rampage IV Extreme | Asus Z170i Pro Gaming
Cooling Custom water on CPU and GPU, dual 360mm radiators | Corsair H80i
Memory 4x 8GB G.Skill TridentX DDR3-1600 | 2x 4GB G.Skill RipJaws 4 DDR4-3000
Video Card(s) Sapphire AMD R9 295x2 | PowerColor AMD HD7970
Storage Samsung SSD 830 256GB, various others | 2x 1TB Seagate Barracudas in RAID1
Display(s) Dell U2713HM 2560x1440 IPS | Panasonic TC-L32E5 1080p IPS TV
Case Thermaltake Suppressor F51 (stripped down to hold two radiators) | Cooler Master Elite 130
Audio Device(s) RM-DAC -> Xiang Sheng 708b -> Sennheiser HD650 | HDMI sound device on 7970
Power Supply LEPA G1600-MA 1600W | Corsair CX750M 750W
Software Win 10 64
Benchmark Scores over 9000 BungholioMarks, "Bitchin' Fast"
This would look great in my cubicle.
152 (0.04/day)
Columbia, SC
Processor Intel 2500k OCed at 4.6ghz
Motherboard Intel Z77
Cooling Thermalright Macho Rev.A
Memory 8GB G.Skill 2133
Video Card(s) Gigabyte GTX 670 Windforce 3X OCed at 1050mhz base and 1600mhz vram
Storage Mushkin Enhance 256gb SSD, Western Digital 750gb and 3TB HHDs
Display(s) Asus 24" 1080p
Case Lian-Li Mid Tower
Audio Device(s) Mobo sound
Power Supply SeaSonic 560 watt gold
Mouse Logitec 3 button laser mouse
Keyboard Das Keyboard Model S (the blank key model)
Software Windows 8.1 64 bit
really like it. Wish it was $50 cheaper though. :(
Toothless
Tech, Games, and TPU!
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
I wouldn't pay that much but man I want that case.
798 (0.22/day)
Processor I5 4690K @ 4.8 Ghz
Motherboard Gigabyte Z97X Gaming 7
Cooling Swiftech H140X
Memory 16GB Crucial BallistiX 1866Mhz
Video Card(s) GTX 1070 G1 Gaming
Storage 850 PRO 1TB SSD, 840 EVO 500GB SSD, 850 EVO 500GB
Display(s) Nixeus EDG 27-Inch IPS 1440P, 144HZ 16:9
Case NZXT H440 Red/Black
Mouse G600
Keyboard G710+
Software Win 10 64B
270 (0.06/day)
Canada
System Name custom
Processor intel i7 9700
Motherboard asrock taichi z370
Cooling EK-AIO 360 D-RGB
Memory 24G Kingston HyperX Fury 2666mhz
Video Card(s) GTX 2080 Ti FE
Storage SSD 960GB crucial + 2 Crucial 500go SSD + 2TO crucial M2
Display(s) BENQ XL2420T
Case Lian-li o11 dynamic der8auer Edition
Audio Device(s) Asus Xonar Essence STX
Power Supply corsair ax1200i
Mouse MX518 legendary edition
Keyboard gigabyte Aivia Osmium
VR HMD PSVR2
Software windows 11
is there any dust filter?
i look and dont see any on the front panel. :confused:
nvm, got it! it fix and dont move with the panel. pretty nice :toast:
944 (0.20/day)
Slovenia
System Name PC.
Software Windows7 64....
The dust filter is well see the front page, along with the upper mask in one piece, what here is not clear .. aglmast you really can not buy.:banghead:
4x120 mm are available-options for liquid cooling. I like beams. and it would be better to put the glass windows on top and also second side of the casing. (my thoughts).:) Nice 1.
6,760 (1.39/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Wow, most matx cases are almost that big!
4,368 (0.95/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
Hmmm... I kinda like it... Suddenly, I am starting to feel weird. Almost like someone just told me they like Lain-li.
:confused:
5,766 (0.80/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
$199 and a fan with a Molex connector? How about no.
9,900 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
too bad lian li miss its nice point
i may pay more with all steel material, just using screws less plastic and rubber like for hdd tray, fan mounting
just give us more steel and solid case
152 (0.04/day)
Columbia, SC
If it used steel, it wouldn't be a Lian Li case.
9,900 (1.85/day)
Jakarta, Indonesia
Case Icute Super 18
517 (0.09/day)
You are here.
System Name Prometheus
Processor Intel i7 14700K
Motherboard ASUS ROG STRIX B760-I
Cooling Noctua NH-D12L
Memory Corsair 32GB DDR5-7200
Video Card(s) MSI RTX 4070Ti Ventus 3X OC 12GB
Storage WD Black SN850 1TB
Display(s) DELL U4320Q 4K
Case SSUPD Meshroom D Fossil Gray
Power Supply Corsair SF750 Platinum SFX
Mouse Razer Orochi V2
Keyboard Nuphy Air75 V2 White
Software Windows 11 Pro x64
Those are adapters. The fans have normal 3 pin connectors. Those are then connected to the molex adapters. Lian-Li always gives you those.
